Question about NetGear WGR614 Wireless Router
Win7 driver for wgr61v54
Not been able to install my cd wgr614v5 to windows 7.as it seems to be not compatible to win7
  • 8,404 Answers
If it is not on the windows 7 compatability list ... you probably will not find a driver ...
Please dont kill the messenger ...
http://www.microsoft.com/whdc/hcl/default.mspx
If this is the case ... it may be time to replace your 'legacy' hardware.
Posted on May 01, 2010
Sir i have win7 and my tv tuner is not working...in driver cd there is only windows xp driver..there is no driver for windows 7...
windows xp drivers will work in 7... right click in install exe goto properties and click on compatability, and run as admin also so it will install
Feb 18, 2011 | Computers & Internet
Tip
Windows 7 Drivers for Printers and other accessories
As it is known to everyone that Win 7 is the latest Operating System from Microsoft and that lacks one of the best thing which Windows XP was having embedded inside it. Yes the in-built drivers which were automatically detected and installed without any rush for chasing drivers. Till date there are many computer peripherals like (printers, scanners, webcams, tablets, sound cards, NIC or Ethernet or LAN card, laptop, notepad GPS devises, Routers, Switches, Modems, Mobiles and many more) for which MS has not yet released the drivers or the publisher has not yet released drivers for Win 7. Hence,ultimately the user is suffering as they cannot use the peripherals which they were able to use with XP but after installing Win7 those devices don't work anymore because of the lack of drivers inside Win7 Operating
System.
The good news
Win 7 has a very good feature inbuilt on this problem that is compatibility driver installation mode. One can try and install the existing Win XP driver in Win7 with compatible mode. If an XP driver is installed in Win7 with compatibility mode then that particular peripheral gives out the efficiency upto 90% .
In order to install the driver first connect the device to pc and then select have disc in the wizard which pop-ups and then follow the wizard and look out for the word compatibility mode. Just select compatibility mode and your device isready to be used in Win 7. Otherwise you can also install the driver through control panel add new hardware and simply select have disc instead of search automatic and don't forget to select compatible mode while following the wizards instructions.
on May 03, 2010 | Computers & Internet
While I try to install the drivers from the cd it says "An error occured while installing the webcam. The device may not work properly."
What is your Operating System ? Is it Windows 7 64 bit? Check specification in driver CD, is it support Windows 7 or not, if it doesn't support Win7 then there is the problem. You need other driver that compatible with your OS. Search via Google to get proper driver to download.
Hope this help and if helpful RATE please.
Feb 03, 2011 | Cameras
Need a driver for Visioneer OneTouch 8700 Flatbed Scanner
The drivers for supported OS versions are available here: http://support.visioneer.com/products/8700/downloads.asp . The supported OS versions are: Windows XP SP 1 / 2000 Professional / Me / 98SE and the additional software that was bundled on the CD is not included.
If you have a different Microsoft OS, you can check the Microsoft compatibility center for either Vidat or Win7. A check of the Win7 compatibility Center http://www.microsoft.com/windows/compatibility/windows-7/en-us/default.aspx showed some Visioneer OneTouch scanners work with Win7. However, the 8700F is not in the list.
I hope this helps.
(Dual boot with XP or a virtual computer with an older valid OS version will work. The Win7 Pro and Ultimate let you use Virtual PC and XP mode to run an XP virtual computer for free.)
Jan 03, 2011 | Visioneer OneTouch 8700 Flatbed Scanner
Sir i have window 7 installed in my pc. but my pc is not installing the scanner in window 7 instead i have original dirver cd for scanner which works well in window xp. tel me the soultion
The version of driver is citical - if the scanner has Win7 drivers available use those, if not then it's not supported. If you have Pro or Ultimate you could try running setup with compatability mode.
Aug 06, 2010 | Computers & Internet
I am unable to listen sound in windows 7 , and it is not accepting sound drivers of mother board cd, but the same is accepted in xp sp-3
The driver on the CD may be too old (or an unsigned driver which can't be loaded in the 64-bit OS) to be compatible with Win 7. Try downloading the latest driver from the Intel site for the on-board sound:
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%C2%AE+945+Express+Chipset+Family+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+D945GCCR
Select your Win7 version. I saw 3 different updates of the Realtek Sound drivers under Win7 32 bit.
Alternatively, set Windows 7 to look for hardware driver updates and install them (they might end up in the Windows Update section until you go there and install the update). I did this in Win7 by going to the Device Manager (Start > Control Panel > Hardware and Sound > Device Manager). Right click on the audio device and choose Update driver (or Properties and the Driver tab). If the Device Manager shows a triangle with an exclamation point, this is an easy solution most of the time.
I hope this helps.
Apr 27, 2010 | Intel D945GCCR Motherboard
Hi i have a KT4V motherboard and recently got a radeon 9800 pro graphics card - and upgrade form a radeon 9250 (which worked fine on xp but when i upgraded to windows 7 it wasn't supported). when i first...
Yes and No. Let me explain. You have taken an older board that worked with XP and tried to make it work in Win7 (which is not supported by the board). Add in your graphics card switch, and you have a real mess.
You can upgrade your motherboard (for one that is compatible with Win7 - (ie. a brand new model with Win7 certification) and use a graphics card that is also Win7 compatible, or
Go back to a configuration that worked
Dec 16, 2009 | MSI KT4V (MS-6712) Motherboard
My toshiba L310 laptop webcam dosenot work & that happend after i upgradded my OS from Vista to win7
1. It's a driver compatibility problem with Windows 7.
2. Install the driver for web camera which is compatible on Windows 7 using the bundled CD/DVD.
3. Update the web cam driver using Windows Update!
4. Restart the system.
please rate this advice if it hepls...tc! :)
Nov 01, 2009 | Toshiba Satellite Pro L300-EZ1501 Notebook
Intel 865 graphic drivers for windows 7
hi there
as windows 7 is still in beta stages most drivers are not available for it yet......
are you running the 32bit or 64bit version ??
i ask this because either version is compatible with windows vista so you could try obtaining these drivers from intel.......
hope i helped
Feb 23, 2009 | Intel D845GVSR Motherboard
NetGear WGR614 Wireless Router Logo
105 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
