Question about Olympus ? DIGITAL 600
My olympus mu 600 digital camera will not focus -
Camera steady
white balance is on auto
ISO is on auto
subjects are paintings
available light is average to low
macro is off
flash is off
quality is set high
5 Suggested Answers
Jeap
  • 114 Answers
SOURCE: olympus c755
well the battery can´t be replaced by the user, the battery it´s on the mainboard and is weldded to the mainboard, i don´t know if u can find this type of batteries on the shops. it´s a kind of watch battery but it´s recharchable. good luck
Posted on Feb 24, 2007
Noggin
  • 944 Answers
SOURCE: manual for olympus digital 600 camera
Heres the link; http://www.olympusamerica.com/cpg_section/cpg_support_manuals.asp?id=1190 Enjoy your camera:)
Posted on Apr 15, 2007
SOURCE: olympus evolt 410 flash
Turn of "AF Illumination" and it will get rid of it and not cause you other shooting problems.
Posted on Apr 17, 2008
  • 4090 Answers
SOURCE: grainy pictures...iso problem for olympus stylus 820
Without ISO you will not be able to take pictures.
ISO is the old ASA which is related to film speed
ISO 50 is very slow film speed and may result in blur and some grainy appearance , same as if you PUSHED ISO up to 800 in low light.
Try setting it to ISO 100 and see if that helps.
You can still select auto, but its related to either shutter or aperture priority in relation to the set film speed ( now ISO 100)
Posted on Sep 10, 2009
MY OLYMPUS DIGITAL CAMERA FE-230 IS OUT OF FOCUS? PICTURES TAKEN ARE ALL BLURRED.
Try one of these tips:
>Hold your camera steady using both hands
>Hold your breath just before you take a hand-held shot
>Use a tripod, or a set your camera on a steady surface
>Set your camera's self-timer
Set the dial mode to auto ;
Turn off macro mode;
Turn on the camera's flash.
At the link below you will be able to download the instruction manual for Olympus FE-230 Digital Camera:
Click HERE
Jul 26, 2011 | Olympus Cameras
I have a new SP-800UZ that will not focus sharply on distant objects using the 30 X zoom. Do you know how i can get rid of the problem or get rid of the camera. I have tried all settings but mostly on P...
Look within the settings within the camera's setup menu (I am not too clued-up with this model but I'll try) Look for things like sharpness, photo effects, ISO modes and resolution. make sure the sharpness is set toward the sharper end of the scale, that there no added effects enabled and that the ISO mode (if not in auto) is set between 100 and 600.
Also, if you are using digital zoom you will reduce picture quality.
Finally, using maximum zoom requires a very steady hand (or a tripod) as the slightest shake or twitch will be amplified many times at the target - end of the shot.
Good luck Bill, hope this helped a bit.
Apr 05, 2011 | Olympus SP800UZ Digital Camera
Pictures turn out to be blurred and white. ISO has alr set to auto
ISO has to do with the speed of the film (or sensitivity of the semiconductor in a digital camera)    fuzziness has to do with weather you focused     If you had a closeup of a flower for instance  different parts of the flower would be in or out of focus if that is what you desire  or if the sensor adjusts automatically for one part or another   To keep the background and the foreground both in focus you need to have the smallest aperture possible to simulate a pinhole camera (increases depth of field)   if your white balance is wrong your picture will be too white or blue etc  that can be readjusted in a 'lightroom' (digital photography software equivalent to a darkroom)
Nov 09, 2009 | Casio EXILIM Card EX-S770 Digital Camera
Settings for indoor business presentation
you need to set for fluorescent lighting..... look in settings to find best match..do a test before event ..good luck
Jan 13, 2009 | Olympus EVOLT E-500 Digital Camera
Not really sure if this is a problem? I have an Olympus E-500 and E-510. When I changes settings on the E-500 (ISO, White Balance, Auto-Focus Mode etc.) it remembers them when I switch it off. The E-510...
If you are shooting in the Auto mode and make the changes when power the camera off it will reset back to factory defaults. If you change the dial to P mode, make those same adjustments and power the camera off and then on again it should maintain those settings. Auto just uses the factory defaulted settings.
Oct 18, 2008 | Olympus Cameras
My camera won't auto focus
in low light or low contrast situations, the camera will not focus...press the [---] and change the point to center focus and increase the iso
Aug 25, 2008 | Olympus EVOLT E-500 Digital Camera
Sequential shooting modes
There are four sequential modes: Sequential shooting, High-speed Sequential shooting, AF Sequential shooting and Auto Bracketing. Sequential shooting modes can be selected from the CAMERA menu: Sequential shooting: A maximum of 11 frames can be shot sequentially at approximately 1.7 fps in HQ mode. Focus, Brightness (exposure) and White Balance are locked at the first frame. High-speed Sequential shooting: A maximum of 4 frames can be shot sequentially at approximately 3.3 fps. Focus, Brightness (exposure) and White Balance are locked at the first frame. AF Sequential shooting: Focus is individually locked for each frame. The AF Sequential shooting speed is slower than for normal sequential shooting. Auto Bracketing: When Auto bracketing is set, exposure is changed automatically for each frame when you start shooting. The exposure differential can be selected in the menus. Focus and white balance are locked at the first frame.
Sep 04, 2005 | Olympus Camedia C-8080 Wide Zoom Digital...
Difference between the D-460 and the D-450 Zoom digital camera
The D-490 Zoom shares the following features with the D-460 Zoom: •Olympus 5.4mm to 16.2mm (equiv. to 35mm to 105mm on a 35mm camera) lens: all-glass, 8 element, 6 groups, 2 aspherical lenses •Automatic TTL focus system •Macro mode allows the camera to auto focus as close as 8 inches •Automatic aperture selection: f2.8 to f8.0 wide, f4.4 to f12.6 tele •3x image magnification inspection mode •Panorama mode: Allows multiple pictures to be "stitched" together to create wide views •NTSC video output to TV •12-second self-timer •8MB SmartMedia card included •Built-in, pop-up intelligent flash: Auto low & backlight, red-eye reducing, off, fill-in, slow-sync •Automatic white balance control or 4 manual settings (daylight, cloudy, tungsten light, fluorescent light) •Automatic ISO sensitivity or manual selectable ISO settings •Uses 4 AA size batteries. AC Adapter is available as an optional accessory In addition, the D-490 Zoom has the following functions and features: •2.1 megapixel resolution (1600 x 1200) •Sequence mode - up to 5 shots in HQ and up to 45 shots in SQ mode (1.3fps) •Motion picture mode - up to 60 seconds of QuickTime movie (.mov) format (w/o audio)
Aug 31, 2005 | Olympus D-460 Zoom Digital Camera
Difference between the D-460 Zoom and the D-490 Zoom digital camera
Aug 31, 2005 | Olympus D-400 Zoom Digital Camera
The D-460 Zoom shares the following features with the D-450 Zoom: •1.3 megapixel resolution - 1280 x 960 pixels •Olympus 5.4mm to 16.2mm (equiv. to 35mm to 105mm on a 35mm camera) lens: all-glass, 8 element, 6 groups, 2 aspherical lenses •Automatic TTL focus system •Macro mode allows the camera to auto focus as close as 8 inches •Automatic aperture selection: f2.8 to f8.0 wide, f4.4 to f12.6 tele •2x digital telephoto mode •3x image magnification inspection mode •Sequence mode: Up to 10 images at 2 frames per second intervals (SQ mode only) •Panorama mode: Allows multiple pictures to be "stitched" together to create wide views •NTSC video output to TV •12-second self timer •8 MB SmartMedia card included •Built-in, pop-up intelligent flash: Auto low & backlight, red-eye reducing, off, fill-in, slow-sync •Automatic white balance control or 4 manual settings (daylight, cloudy, tungsten light, fluorescent light) •Automatic ISO sensitivity or manual selectable ISO settings (125, 250, 500) •Uses 4 AA size batteries. AC Adapter is available as an optional accessory In addition, the D-460 Zoom has the following functions and features: •Industry standard icons for button labels and operation menus •Easy to use jog dial and button design allows easy menu navigation •2 compression ratios are now selectable in SQ mode •Selectable Sharpness: Normal or Soft •Selectable Memory Mode Setting: Reset camera settings at power-off or Retain all camera settings •2 Olympus brand CR-3V long life lithium batteries included. Provides 20-30 times the power/life of alkaline batteries
Olympus ? DIGITAL 600 Logo
32 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
