Question about Canon ImageClass D861 Printer
Canon pc720 makes "crackly" sound, randomly shuts off mid-print, and displays error code E240
  • 1,110 Answers
Your scan lamp is going bad. It is the flourecent type lamp that lights up under the glass. You can try making a copy with the top cover open and watch it. You will see it flickering before the code comes up.
$75 from precisionroller.com Part#L5180 or the canon # FH7-3272-000
Posted on May 01, 2010
My frigidare affinity shuts down mid cycle , and has to be restarted many times in order to finish a load of clothes
Remove top of washer by removing screws in back of top. You should see the tech sheet. Use this to retrieve any error codes.
A common problem with these is a bad door switch. (The part the strike goes into. If this is the case you should come up with error code for it.
Mar 11, 2014 | Frigidaire Affinity ATF7000E Front Load...
E240 error in ir7200 m-c
E240error code can be caused by excessive side to side movement of the Transfer / Separation Corona Assembly. To resolve this issue, check and make sure the Transfer / Separation fixing latch bracket is properly installed. This is the latch which secures the Transfer / Separation corona assembly.
Has been noted that the registration clutch can load down the DC Controller and cause anE240error code. The clutch can spin if the pin holding the clutch is not inserted correctly and damage the registration clutch wire harness. The clutch can also intermittently short out through the clutch housing.
Mar 04, 2014 | Canon Office Equipment & Supplies
E240 error code
Unfortunately, an E240 designates a problem with the Main Controller of the machine. It could be the memory, the boot ROM chip, or the board itself. In most cases it ends up being that the Main Controller PCB is the culprit.
Apr 13, 2011 | Canon imageRUNNER C3200 Copier
Copier is Canon PC 720 Copier turns on, but makes
You said you unplugged your copier, did you unplug it for 10 to 15 minutes before plugging it back in, plug it into a differed
outlet that you know works and plug it directly into a wall outlet instead of a power strip. Check to see if your copier reaches stand-by mode then make a test sheet.
If this does not work then you have probably have an internal processing component which requires attention.
Apr 02, 2017 | Koutech Systems PC720 (IO-PC720) (IOPC720)...
I need a technical manual for a Canon Copier PC720
Scroll Down put in the 4 digit code, click download
http://www.devicemanuals.com/guide/Copier/Canon/Canon-Personal-Copier-PC720-User-Guide-TkRBNU9UYz.html
Oct 20, 2009 | Canon PC150 Personal Copier (PC 150,...
Canon imageRUNNER C2058 Color Copier/Printer service manual have error e240-0000
E240 Error in communication of controller
0000 Error in communication data Check connector, check connection of sub PCB in the
controller box, check / replace DC controller PCB /
main controller PCB
0001 There is no response when 3 sec passed since the main controller had sent the pickup
request to DC controller during printing.
0002 There is no response when 4 sec passed since the main controller had sent the request
for image output to DC controller during printing.
0003 The engine is activated when jam occurs.
Jul 09, 2009 | Canon C2058 Color Copier
Canon PC720 copier
Looking at the copier where the paper comes out of, there is a switch to open and close it. Pull up and look on the left side in the back. There is a little spring that comes off, or breaks, or the plastic that holds it on breaks. THIS CAN PAPER JAM THE MACHINE AND SEEM LIKE A MAJOR PROBLEM. ALL IT IS IS A LITTLE SPRING. Hope that is only your problem.
Dec 31, 2007 | Koutech Systems PC720 (IO-PC720) (IOPC720)...
Canon ImageClass D861 Printer Logo
169 people viewed this question
old marine
old marine
