Question about HP OfficeJet J4580 All-In-One Laser Printer
How to scan with an HP J4580
What are the steps to scan a document with and HP J4580 printer?
  • HP Master
  • 5,105 Answers
Do you have the full-feature software installed? What OS is on your computer? Assuming you have the full-feature software installed (installed before connecting the printer to the computer) and a direct USB connection (with a good cable and functioning USB port), you have two choices.
Start the scan from the computer (have the document face down on the glass or face up in the ADF (for models with the document feed) and the all-in-one ready. For this, with Windows, launch the HP Solution Center (Start > All Programs > HP > HP Solution Center), then click either the Scan Photo or Scan Document button in the program. Set the desired scan settings (this should come up if it wasn't turned off) then click Scan.
Alternatively, you can start the scan from the button (it's the one closest to the button with an X (cancel) on the all-in-one and that will launch the HP Solution Center (assuming HP Digital Imaging Monitor is running). The scan menu will also come up on the printer screen with requests for more setting information (destination etc.)
With Win7 and Vista, Paint will acquire scans (Import from Camera or Scanner). Some versions of Vista and most of Win7 also include Windows Fax and Scan which will also handle new scans.
I hope this helps.
Posted on May 01, 2010
Testimonial: "Thanks for your help"
2 Suggested Answers
  • 5 Answers
SOURCE: When trying to scan to my HP J4580 Officejet J4580
this means the printer has not been configured to the computer,,
1st check the connection of the printer and the computer,,
then check if all the software like the basic print and scan drivers, hp solution center and the hp imaging device function had been installed or not,,
if all the above things had been checked then
open hp solution center,,
click settings,,
go to scan settings,,
select scan to set up.....,,
you will get two columns there,,
the left will be for the solution center and the right one will be for the printer,,
you will see two arrows in between the columns,,
populate the entries on the printer that is on the right column using the arrowes,,
once done click update device,,
then close the olution center and restart the printer,,
then check it will work................
Posted on Feb 16, 2010
How do I scan a document from my HP officejet J4580 all-in-one printer to my computer?
Make sure the full feature software package of the printer is installed.
Press the Scan button on then press scan button on the printer to scan, or you can also scan via HP software.
Aug 20, 2010 | HP OfficeJet J4580 All-In-One Laser...
ANyone else having this problem? My j4580 has
Clean adf ,connect directly with wall jack or Change automatic document feeder,
Jul 28, 2010 | HP OfficeJet J4580 All-In-One Laser...
How do i scan a document?
Visit to the given link and download the manual. The detail procedure is given in the manual... http://www.retrevo.com/support/HP-J4580-Multifunction-Printers-manual/id/20067ag014/t/2/
Hope this has helped you.. Please rate the answer.. Thanks...
Jun 25, 2010 | HP OfficeJet J4580 All-In-One Laser...
Scanning pictures and documents
Everything you need, including a PDF (use adobe reader at adobe.com to read PDF's - free download) manual is available online on hp.com at the following URL:
http://h10025.www1.hp.com/ewfrf/wc/product?product=3645100&lc=en&cc=us&dlc=en&lang=en&cc=us&submit=Go%20%BB
Jun 19, 2010 | HP OfficeJet J4580 All-In-One Laser...
J4580 OfficeJet All In One Printer Laser: the printers scanner is not working and when i pre...
Just check that can you scan from HP Solution Center, if yes. Then perform the steps given below to resolve the issue.
Open HP solution center:
CLick on settings:
select scan settings from settings.:
A Menu Appears.
select scan to setup:
a new page will appear:
you will see all options on the left side:
select all the options manually and click on the right arrow
to move all the options from left to right side.
after perfoming these steps.
Restart the printer:
and try scanning from printer now.
now will be able to scan from printer itself.
May 18, 2010 | HP OfficeJet J4580 All-In-One Laser...
Won't scan. says no scan options, refer to documentation
You may need to have the "full-featured" software installed on your computer in order to perform scanning operations. If you do not, you may download this software for your HP model here:
Choose your Operating System > Download > Install
HP OfficeJet J4580
Dec 20, 2009 | HP OfficeJet J4580 All-In-One Laser...
Hp J4580 Officejet don't want to scan.
hi,
try to scan from solution center software from the computer or click on the following link and follow the document which will help in resolving this issue,
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00503569&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
Regards,  raj_p5983
Jan 20, 2009 | HP OfficeJet J4580 All-In-One Laser...
Can't scan on the HP OfficejetJ4580
Uninstall everything that has to do with your old HP printer, drivers, photo processing, etc. Reinstall software with J4580 printer. That should open HP Digital Imaging Monitor where you can set scanning options. Plug printer into the back opf your computer. Plug power supply directly into the wall socket.
Nov 12, 2008 | HP OfficeJet J4580 All-In-One Laser...
HP OfficeJet J4580 All-In-One Laser Printer Logo
411 people viewed this question
Seeker5211
Seeker5211
