Question about KitchenAid 24 in. KUDS02FRSS Stainless Steel Built-in Dishwasher
Cable to door will not hold. How do you repair?
    President:
  • 949 Answers
There is a kit that will do the trick for you. It is part number 8194001. I have put together some instructions on how to replace them. Let me know if this works for you.
Door falling down or creaking
Posted on May 02, 2010
How can I disassemble the driver's door to repair the power window without breaking it?
You have a major problem. Either the window regulator or the clips that hold the window on broke. My guess is the regulator because of the cable. To disassemble the door look for the screws holding the inner panel on remove them don't forget the one in the door pull and behind door handle. Carefully pry panel off remember there is some clips holding the panel on. Disconnect any wiring connection and carefully lift panel up towards top of door do not force. You will see a cover of some sort remove it. You are in door and should be able to see the problem
Aug 17, 2015 | 2004 Volkswagen Polo 1.4
Tip
Door handle repair for Ford fusion
The door handle will not allow unlocking from the inside. This is a common problem with the Ford Fusion 2007 to 2012 and other cars. A cheap piece of plastic breaks that connects the lock lever with the door handle. You can roll down the window and unlock from the outside or hold both levers together and pull open from the inside. This is a very simple repair. Go to any of many web sites for auto parts and buy a replacement. I bought a Dorman 81702 Ford/Lincoln/Mercury Interior Front Driver Side Replacement Door Handle. I popped off the lid that covers a hidden screw inside the recess of the door handle. You have to use a torque bit to unscrew the screw. I then unscrewed the torque screw holding the upper part of the door panel that is opposite the door hinge. The upper part of the door panel can be be carefully pulled away with moderate pressure allowing access to the door handle mechanism. One more bolt holds the door handle part in place. Pull out the broken door handle part, remove the locking cable and put in the new part. Reverse the process to finish up. The whole process took about 10 minutes.
on Sep 18, 2015 | 2010 Ford Fusion Hybrid
Driver window will not roll up or down....cables all wound up inside window motor...need schematic for window
What you need is a window regulator/motor assembly. Not a difficult repair. Two clips hold the window to the mechanism. Two bolts each for the tracks, and three bolts hold the motor to the inside panel of the door. Remove all these and the cable hold downs, fold together, and remove from inside the door. It is probably easier if you remove the glass after you remove the clips.
Aug 31, 2011 | 1996 Dodge Grand Caravan
My dishwasher door springs appear not to work and will not hold the door open. How do you replace or reattach the springs? Thanks, JoAnne
they actually arent springs, it is a cable and has probably broken or come apart. You can order this part through KitchenAid and replace yourself. Or call a repair rep.
Feb 10, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
I cant open the front door from the outside i can hear somthing loose inside the door but the door will open from the inside.
Ur link cable from the DOOR HANDLE is dislocated and need for u to connect it again!
Just open the door sidings and u will see a wire cable dangling near the door lock, examine how the handle moves, u will see the hole that the link cable would be inserted.
2 nuts holds the door handle lock, remove them to make ur repair a bit easier!
Hope that helps u out!
Nov 21, 2010 | 2003 Isuzu Rodeo Sport
My gas flap is stuck closed. We had to pry it open yesterday to fill the tank. 2 months ago the same thing happened, but it has worked since then.
If you have fuel door release cable & door is open, verify that cable moves in & out when you activate it. If yes you can adjust tab that it rests on so it will release properly. Just bend tab slightly inward at first, till it releases correctly.
Jun 14, 2010 | 2002 Volkswagen Passat
How do you replace the cable that holds the door open
There is a plastic plug where the cable goes into the door. Take a putty knife or flat screw driver. slide it in between to plug and door. Then pop the plug out. The plug it's self is what holds the cable to the door. Do the same on the unit end. I use a putty knife because it's easier to get behind the plug.
Please rate solution
Sep 08, 2009 | Kenmore Dryers
Cable on power sliding door broken...will not operate with power...expensive fix?
We'll
speaking from one that has change SEVERAL of these. If you havent done it
before its a pain in the ****. I have done so many that I can do them in about
30 minutes. You can do it with or without the door on the vehicle.
Personally I do them with the door off. You can't fix the cable if its broke.
The cable has to slide down 2 sets of sliders and in and out of the motor
theres no tolerance for a splice anywheres. I had no idea those motor assy were
that expensive.
The way this is changed is
you remove the door. (disconnect negative on battery, or turn power slide door
button to off) Remove the panel, drop the glass down about a 1/3 the way, pull
the 2 rubber grommets off from inside the mod. Remove 2 10 mm bolts, remove the
back sash on the door and the inside rear window rail, pull the inside rubber
window run slightly out. Slide the old glass out, drop the mod down, remove the
cable assy bolts (4 10mm bolts) , unplug the wiring harness, remove the 2 10mm
bolts atop the rear slide roller, theres also one 10mm inside the door at the
very top near the rear slider. Remove that bolt too, its grey and about 1
1/4" long. You also have the remove the rear latch lock, 3 T30 torks
bolts. Unsnap the cable from the 2 retaining clips and slide the power door
assembly out the bottom of the door. Reverse assembly for the new one. Id
imagine they are charging you about $300-400 labor. Id do it for $100
lol No idea where to get a new one
reasonably tho. Its sad cause I see 1000's of them daily. Ask me how I know
this? I work in offline repair at Toyota Motor
manufacturing Indiana.
Originally Posted by BLOWN
86
There's a sequence for that motor if you replace it yourself you
could possibly break it again I've seen those motors split easily just by
letting too much cable go into the motor assembly the spool that holds the
cable can only hold just the right amount to open and close the door
Good luck Rob
I agree,
if you don't know what your doing with the new motor your going to shell it out
quicker then you put it on. This is where the dealer comes in handy. I've
replaced a few and from I've seen they usually run around $1100-1200 without
labor
ABOVE IS
FROM ...
http://www.tundrasolutions.com/forums/sienna/73364-2004-sienna-le-power-door-broken/
How to
fix the problem with $5 ...
http://polifrogblog.blogspot.com/2009/09/i-fixed-power-door.html
Jun 24, 2009 | 2004 Toyota Sienna
Back passanger window has come off track/cables. What is the best fix...the window has dropped to the bottom
you will need to replace the window regulator assembly.
this is a one piece design with the window motor, cables and rails serviced as an assembly.
you will need to remove the door panel, pull the window back up and wedge cardboard between the glass and door, remove the two bolts holding the glass to the regulator, remove the couple of bolts holding the regulator assemblt to the door, unplug window motor, and replace with new assembly.
this is not a tough repair, with basic handtools and common sense anybody can make the repair
good luck
wesleyschacht@hotmail.com
Jun 14, 2009 | 2001 Chrysler Sebring
Electric window cable solution
My drivers side quit working. I took the door/window assembly apart and found that a small plastic clip had worn/broken. I modified it to hold the cable securely. The problem I had was knowing how the cables routed in the door and window assembly to put it back together. I found an online picture of a new one and routed my cables per the photo. It has not given me problems since. Time invested, about 3 hours. Cost was $0. If you buy a new one, cost is about $80 (online) and time would be about 2 hours. If you have the $$, buy a new one.
Oct 04, 2008 | 2002 Dodge Dakota Club Cab
KitchenAid 24 in. KUDS02FRSS Stainless Steel Built-in Dishwasher Logo
257 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
