Question about Bernina 2500DCET
What is the correct setting for a hand rolled hem?
    Genius:
  • 1,116 Answers
I do not have this brand, but thought these instructions for a 2-thread rolled edge might help -
Presser foot - Rolled Edge
Needles - Right or Left (depending on the width you want).
Stitch Width - Normal to Wider (your choice)
Stitch Length - 1 mm/left needle; 0.5 mm if using the right needle.
Differential Feed - Normal
Blade Position - Up
Right Needle Tension - Tighten
Lower Looper Tension - Normal or Loosen
2-Thread converter - engaged.
The converter may also be referred to as a subsidiary or auxiliary looper. This fits into an opening near the tip of the upper looper to "trick" the upper looper into thinking it is threaded.
The above information is from "Serge With Confidence" by Nancy Zieman. I have found this book to be more helpful than the instruction manual that came with my Babylock Imagine.
Posted on May 01, 2010
  • 4 Answers
SOURCE: rolled hem or rolled edge
You need to disengage the cutting blade by openingfirstly opening the front and left hand side covers. pull on the larger of the two silver knobs and slide the red lever towards you. I'm not sure what the tension settings are, but I'm certain you need to reduce them a fair bit to aid in the rolling effect. I only use 3 threads when doing a rolled hem.
My description isn't too detailed but I hope it helps!
Posted on Jun 11, 2008
JeremySew
  • 65 Answers
SOURCE: rolled hem settings
Here is a link to purchase your instruction manual:
Pfaff Sewing Machine Instruction Manuals
Posted on Jan 06, 2009
  • 20 Answers
SOURCE: what is a Narrow double hem with hand slip
You can find some instructions on a narrow double hem at http://www.sewjanetmoville.co.uk/content/learning/viewArticle.asp?lcArticleCategoryID=0&lcArticleID=3&pgid=learningCentre. Instead of machine sewing it, use a hand slip stitch as seen here: http://www.hutchal.clara.net/curtains/sewguide.htm.
You can find more info on these techniques at http://www.repair-home.com/how_to_sew_repairs.html
Hope this helps! Let me know if you need more info.
Posted on Mar 18, 2009
  • 136 Answers
SOURCE: Juki baby lock EA 605 'rolled hem'
No way to rolled hem, machine as much as 40 years old
Posted on Aug 29, 2009
  • 1116 Answers
SOURCE: Rolled hem
Here is a tutorial - http://www.wonderhowto.com/how-to-rolled-hem-foot-sewing-machine-240603/view/
I have to practice with scraps first.
Posted on May 08, 2010
792d setting for rolled hem?
If you scroll down to "Serger," and download Workbook 1, there are instructions in there for setting up a rolled hem.
Bernina Mastery Workbooks
Your machine differs but the way it functions is very similar--at least the settings should be helpful.
Jul 18, 2017 | Sewing Machines
How to set Bernette serger 203 for rolled hem
Be sure you have the proper foot for your machine to make a rolled hem.
Bernette 203 How to use rolled hem foot have the one page manual but it...
Sew Inspired Serger Rolled Hem Tips
In case you don't have a manual, you may be able to glean some information here:
Sergers Overlockers
need manual for the Bernina Bernette 203 overlocker
Aug 31, 2016 | Bernina Sewing Machines
Make a rolled hem
If you want it done entirely by machine you will need a special attachment. You'd have to check the make and model of your machine to find out if there is an attachment available from the maker. If not, there are some companies that make general attachments, and they'll list what machines these will fit. Check online sewing supply houses for this kind of thing.
You can also make one by hand. Any decent sewing book would tell you how. Usually you sew a straight stitch along the hem, using quite small stitches. Trim hem to a quarter inch from the stitch line. Crease the fabric or press it along the stitch line to the inside. Anchor your hand thread, then take a short stitch right along the stitch line. Next catch one thread of the fabric a quarter inch above the stitch line. It's just a basic running stitch, back and forth. Every few stitches, gently snug up the thread, which will roll the hem over. The finer the fabric, the smaller the stitches you take where they'll show should be.
There are some images that will help, if you enter the following search terms in google, you will see several pictures. Type the words," Illustrations for how to make a rolled hem by hand ? " and you will get a load of ideas.
Oct 09, 2014 | Sewing Machines
Which threads do I use to make a rolled hem?
Only 3 threads are used for rolled hemming ........you will need to change to rolled hem mode with a slider switch or a special needleplate, depending on your machine, ...the manual will tell you how to go about it if you have one.
Use both loopers, and the Right hand needle....(remove the Left needle)
If you cannot figure it out, call the dealer where you bought the machine, or one that sells that make, they will probably help, they may even offer to show you or do lessons for a modest fee.
Best Wishes
Bargainbox.com.au
Aug 11, 2009 | Sewing Machines
How many foot for Baby lock E5280 like flat, blind, rolled hem?
i dont have a baby lock but on my machine i change from rolled hem to flat needle plate
or change setting to n from r also loosen lower looper tension as rolled hem requires a tight lower looper tension.
hope this helps you
mary h
Jan 05, 2009 | Baby Lock BL1556
Bernette 134D
Stitch length should be set between 1 to 2.
May 26, 2017 | Sewing Machines
Ezy_Lock 304D
This may be too small to read, if so, email via
www.bargainbox.com.au and I shall send it on........remember to only ever use the R needle, so you only have 3 threads.
To move the Rolled hem arm, you will need to release the upper knife (knob on left inside cover....push to the right and blade moves approx 6mm) so you can slide the small metal tongue to correct position for:
N = Normal
R = Rolled
Jul 10, 2007 | Janome MyLock 634D Mechanical Sewing...
Sewing Machines Logo
183 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Derek Massey
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
