Question about Philips IPF-174 Plain Paper Inkjet Fax
How to instal ink cartridge to fax philips hfc 171
Have this machine approx 7 years. never had to instal ink cartridge. have pulled the machine apart but cannot find where the cartridge has to go. please help
  • 630 Answers
PHILIPS HFC 21 REPLACE BATTERY
Check this link to download the user manual to your fax machine. It has all details.
Feb 11, 2013 | Philips Televison & Video
How to install ink cartridge for hp640 fax
open the front panel door and take out the ink cartridge by sliding it downwards and then pulling it towards yourself. in order to put the cartridge inside the printer you need to insert the same by sliding it from top to bottom and once you hear a click sound it means the cartridge has been installed
May 21, 2010 | HP 640 Inkjet Fax Machine
How can i install the ink film?
Hello :
If you mean change then :
1: Turn the power off on your fax machine.
2: Open the front or top control panel Make sure not to force the door open.
3:Locate the ink cartridge. Gently pull the cartridge out. Set the cartridge aside.
4:Take the new cartridge out of the package and reserve the packaging. Remove the protective covers over the copper connectors.
5:Insert the new cartridge into the fax machine with the brand label toward you. Now place the old cartridge into the plastic wrapping and box that you reserved from the new cartridge. Recycle the old cartridge or dispose of it in the garbage.
6:Close the fax machine's access panel. Turn the fax machine's power back on.
Warning:
1:Touching the copper connectors on the ink cartridge could damage the cartridge. 2:Make sure that you purchase the correct cartridge for your fax machine. Purchasing the wrong one could damage the cartridge or your fax machine. good luck . please don't forget to rate !
Apr 04, 2010 | Panasonic KX-FHD331 Plain Paper Thermal...
How do I change the toner?
The Fax-2480c does not use toner cartridges.
This is an inkjet and so uses ink cartridges.
There are 4 cartridges, black, yellow, cyan (blue) and magenta (red). If any of these cartridges are empty, you need replace them.
This machine takes LC-51 cartridges.
You're probably out of warranty so jsut get refills... it's cheaper
Mar 25, 2010 | Brother IntelliFax-2480C Fax
I'd like to refill the ink cartridge on my Philips
Yes, some have a chip on the cartrige unit, they cannot be reset.
Buy a new unit.
Sometimes using competitve ink in this machine can cause other problems.
The copies are light with background and with streaks, also sometimes the toner might be spilling below the developer housing or copy cartrige unit.
Good luck
Oct 14, 2009 | Philips Office Equipment & Supplies
I want to install ink cartidges and do not know where to begin. I have misplaced my instructions
To install your Brother machine#s ink cartridges, follow the steps
listed below:
1. Make sure that the Brother machine#s power is turned on.
2. Open the ink cartridge cover. This cover is located on right-hand
side of the Brother machine#s front panel.
3. Pull down the four lock release levers. There is one lock release
lever for each ink cartridge.
4. Take the ink cartridge out of its protective bag.
5. Carefully remove the yellow protective cap from the ink cartridge.
- DO NOT touch the side of the ink cartridge covered by the yellow
protective cap.
- Take care when removing this cover to prevent spilling ink and
staining your hands and clothing.
- If the cartridge cover comes off when you open the bag, the cartridge
will NOT be damaged.
6. Install each ink cartridge in the direction of the arrow on the
label.
- Please note that each color has its own specific position. These
positions are indicated by the colors of the four lock release levers.
Do not install an ink cartridge in the incorrect position, as this can
cause print quality problems.
7. Lift each lock release lever and push it until it clicks into the
closed position.
8. Close the ink cartridge cover.
- If the LCD shows #Install Black,# #Install Cyan,# #Install Magenta,#
or #Install Yellow# after you install the ink cartridges, please verify
that you have installed the cartridges correctly.
NOTE:
* DO NOT remove the ink cartridges from the Brother machine unless you intend to replace them. If you do, it may reduce the quantity of ink left in the cartridge, which may cause the Brother machine to miscalculate the amount of remaining ink.
* DO NOT shake the ink cartridges. If ink stains your skin or clothing, wash the affected area with soap or detergent immediately.
* DO NOT repeatedly insert and remove the ink cartridges. Doing so may cause ink to seep out of your cartridges.
* If you mix the colors by installing an ink cartridge in the wrong
position, clean the print head several times after correcting the
cartridge installation.
* Once you open an ink cartridge, install it in the Brother machine and use it up within six months of installation.
* Use unopened ink cartridges by the expiration date listed on the
cartridge package.
* DO NOT dismantle or tamper with the ink cartridge. Doing so can cause ink to leak out of the cartridge
Apr 20, 2009 | Brother MFC 240C All-In-One InkJet Printer
Philips magic 5 primo machine doesn't send or receive
the green flashing light means your ink cartridge is empty
you need to replace this before you can send/receive
once you have installed new ink green light will go out
Jan 12, 2009 | Philips Magic5 Voice DECT Duo - Fax /...
Philips fax phone hfc 171
It goes face up into the bottom of the machine. Here's a manual. http://www.fax-anleitung.de/Philips/Fax%20HFC/BDA%20HFC141-171%20uk.pdf
Carl
Nov 10, 2008 | Philips Lands Phones
Philips IPF-174 Plain Paper Inkjet Fax Logo
308 people viewed this question
Top Philips Office Equipment & Supplies Experts
matt martin
matt martin
Are you a Philips Office Equipment and Supply Expert? Answer questions, earn points and help others
