Paper is jammed behind the paper tray on my HP 7280 all-in-one printer. I cannot get to it it to pull it out. How do I get the sliding paper tray out so I can have access to the paper?
    Guru:
  • 163 Answers
Open the front and back cover of the printer. The cover is openable and u can pull the jammed paper out
Posted on May 01, 2010
Testimonial: "Thank you. I never thought about the back being removable."
I pulled the main input tray out- how do I put it back
Try looking at HP's page on your model here:
http://h10025.www1.hp.com/ewfrf/wc/documentSubCategory?tmp_rule=65515&tmp_task=solveCategory&cc=us&dlc=en&lc=en&product=3315742
Is it a 'carriage jam' or an 'out of paper' error?
The paper input tray on your machine should go back in similarly to a kitchen cabinet drawer. Lift up slightly and push in, and it should slide back into place.
Mar 15, 2013 | HP Photosmart D7260 Printer
My HP Laserjet 4L has started jamming paper when I try to print more than one page.
Here is some tips to avoid paper jam..
  • If your printer has a paper tray do not fill the tray to capacity. If you're encountering frequent paper jams, reduce the amount of paper you place in the tray each time it is filled.
  • Make sure you or the tray feeding the paper into the printer is aligned properly and the slider used to hold the paper in place in the tray is snug with the paper. Many printers have sliders that allow different types and sizes of paper to be fed into the printer. If the slider is not properly positioned it can cause paper jams.
  • Use standard office paper; folded paper, paper with labels, and specialty paper such as hard bound paper can often cause paper jams. If you're uncertain with what paper you should use with your printer your printer documentation will list the paper compatible with your printer.
  • Do not mix the paper you're feeding into the printer at one time. If you need to change the paper or size of paper being used removed any other paper currently in the printer before inserting the new paper.
  • If your printer uses a slot or tray for the paper make sure to not push the paper too far into the slot or tray.
  • Examine the printer for any previous stuck paper in the printer. Previous paper jams, torn paper, printing labels or other foreign objects in the printer can cause reoccurring printer jams.
**If you need any kind of technical assistance you can contact support cell at here
Feb 26, 2013 | HP LaserJet 4L Printer
Turn printer on ERROR comes on screen. Carriage jam Open Door clear carriage jam and then press OK to continue. I do this nothing found in carriage close Error comes up the same?? What to do?
Joe,
Pull all of the paper out of the machine. Look for a wadded up small piece of paper. After you look for it. Examine the door slide tray where paper is stored. Look at take-up rollers... make sure slide drawers close easily...examine door where print cartridge is....Look at (on side) feed tray...Paper feed tray... If you fail get a flashlight and take another look it does not have to be a very large piece of paper...good luck
Nov 26, 2010 | HP OfficeJet 7310 All-In-One InkJet...
I have a hp deskjet 3940 colour printer,there is paper jam error,so what i could do to solve the problem
Follow these steps :
1.1
Take out any paper that is not jammed. Remove the loose paper from the in and out paper trays to prevent any more paper from being pulled into the jam.
2.2
Open the cover of your HP laser printer. This will give you access to the inner machinery of the printer and should unveil the jammed paper. If you do not see jammed paper, you may have another type of malfunction.
3.3
Gently pull on the jammed paper. In many cases, it will come out easily.
4.4
Move the rotors on the inside of the printer by pressing the flashing button on the housing of the printer. This may help to loosen any jammed paper.
5.5
If the jam persists, unplug your HP printer. You'll be able to pull more firmly on the paper with the power turned off. Be careful not to rip the paper.
6.6
Attempt printing again. Refill the trays with paper and plug your printer back in to test its functionality.
Oct 30, 2010 | Office Equipment & Supplies
HP Photosmart C 7280 paper feed problem
check the feed tray is good, if so.
Clean the feed rollers,
Lint free cloth, distilled water.
Should be good.
Regards
Richard.
Apr 18, 2009 | Office Equipment & Supplies
Paper Jam
Tweezers work well too.
This video shows how to clear a jam.
Jan 29, 2009 | HP Photosmart C7280 Printer
I have a paper jam and need to pull out main paper tray. How do I pull out mail paper tray
On that printer, you can't pull out the main tray. This video shows how to clear a paper jam on the C7280.
Dec 03, 2008 | HP Photosmart C7280 Printer
Printer will not print 4X6" pictures.
Loading index cards, post cards, and 4 x 6-inch photo paper Remove the paper output tray and all paper from the paper supply tray. Slide a stack of cards into the paper supply tray until they stop. Make sure the print side is face down. Adjust the paper-width guide against the cards, and then slide the paper-length guide in until it stops. Make sure the cards fit within the tray (do not overload it), and then reinstall the paper output tray. Figure 3: Loading a stack of cards 80455c3.jpg
Nov 10, 2007 | HP PSC 1410 All-In-One InkJet Printer
Paper not picking up and alarm light comes on/stays on
Hi, You have the right idea of cleaning the rubber rollers behind the tray, (if the paper will feed through once then we can eliminate the idea of a paper jam)unfortunantly, when the rollers get too worn out then cleaning is not effective. I work on alot of Brother 5140 printers which look very similar to this model, and we pull out the tray,take the pick roller off of the printer, pull off the rubber part of the roller and rotate it 180 degrees from it former position which gives it a new area of wear. Usually that's a pretty good fix, and it isn't too hard to do, just make sure to note how it was put together before taking it apart. Good luck.
Aug 29, 2007 | Brother HL 1440 Laser Printer
90 people viewed this question
jasbo
jasbo
