Question about Ryobi Garden
How do I remove the clutch rotor assembly on a ryobi 720r?
How do I remove the clutch rotor assembly on a ryobi 720r engine? I got the clutch drum off by removing the torx screw, but the rotor assembly is on tight. Looks like aluminum, so I don't want to pry too hard.
I have the same model, I inserted a large screwdriver on the inside to stop the rotor assembly from spinning, then I used a pipe wrench (but channel lock pliers would probably work better) and then w/o much effort, I easily turned the wrench counter clockwise to loosen.
Posted on May 06, 2010
How to remove bell houseing from.ryobi 725r
You must remove the boom, clutch housing, and the clutch assembly. Clutch drum will have most likely a trox head retaining screw accessed through drive cable hole.
Oct 21, 2014 | Garden
Change pull cord
hello sir, ryobi trimmers and other models removal of the bell housing,removal of the metal bell housing,or clutch drum, on models 780R & 790R, here is what you do. after removing the trimmer & shaft assembly.remove the spark plug insert a screwdriver in the cylinder to keep piston from moveing. to remove the bell housing twist off the spring and using a T20 TORX screwdriver unscrew the retaining screw in the center of the bell housing (normal r/h thread) . push down firmely try not to strip screw head . you should be able to remove clutch housing.remove clutch using a pair of channel locks,works for me, (normal r/h thread) you should be able to remove front engine cover to repair what you need to.coil,pull stsrt, hope this works,. this solution applies to all trimmers with clutch removal~~~hope this helps,,any comments welcome,thank you. 11
Jan 27, 2012 | Homelite Mighty Lite Lawn Trimmer
How do you remove the clutch so that the pull cord can be replaced
Dec 31, 2011 | Garden
Need to remove flywheel ryobi RLH1100 mark2
Nov 04, 2011 | Ryobi 15" Electric Factory Reconditioned...
How do I rmove the clutch rotor from the shaft so I can access the pulley rotor assembly -does it screw of and if so is it a RH threaad? It is a Ryobi Weed Hornet 77 31cc
I always describe this solution in detail, and am going to include pictures this time. Here are online instructions with pictures, followed by my directions.
http://www.ereplacementparts.com/article/1771/How_to_Remove_a_Trimmer_Clutch.html
Here are my instructions to aid you.
(Yes, the Torx screw inside the clutch drum is a right-handed thread)
Remove the tube that holds the flex-drive shaft from the front of the motor cover.Remove the rear engine cover. Remove the throttle cable from the carburetor. Mark and unplug any wires for the on/off switch that go to the ignition coil (underneath front cover) if possible. Now if you have pulled the driveshaft tube out of the way, the clutch drum is up next. Inside it, screwed into the very end of the engine's crankshaft is a Torx #25 screw. Before you loosen it, you will have to lock up the engine. To do so, remove the spark plug. Pull on the starter until the piston is down, then insert a length of clean, soft rope into the engine. The engine will come up and compress the rope, thus locking it in place to allow clutch drum and clutch removal. Loosen the T-25 screw inside the drum.. You may be able to remove it with a long thin-blade screwdriver also.It probably won't come completely out...it is made this way. Next, remove the clutch. It is screwed onto a small threaded section of the crankshaft Removal is counterclockwise.. It will be pretty tight. To help, apply peneterating oil. Whack the ears of the clutch near the center with a dull flat-blade chisel and hammer unless there are bolts. then use wrench. It will turn counterclockwise for removal and there will probably be a removal direction arrow on it's face. After getting that off, remove the Torx screws holding the cover to the engine. The starter unit should be mounted inside as it mates with the top of the flywheel to start the motor. Remember to preload tension (5-7 turns) on the starter unit. Make sure the handle is installed. Jam the unit with a screwdriver or vise grips so you can insert and tie off the new rope. Then remove jam device and let recoil pull your new rope into place while holding the handle. Reassemble and you are done. Disassembly requires Torx head drivers
Nov 26, 2010 | Ryobi Garden
Ryobi 40cc chainsaw chain oiler function not working
1) check oil supply holes in the bar
2) With the bar removed, run the engine for 30 seconds, does oil come out of the side of the saw.
3) If no oil on the side of the saw, inspect the clutch drive spring and worm gear on oil pump shaft
Outboard drums (drums on the outside of the clutch) are held on by a nut or e-clip.
Inboard drums are held on by the clutch which is threaded onto the crankshaft. And there is the challange.
***NOTE all chain saw clutches have LEFT hand threads, so, rightey loosey, lefty tightey. (just backwards from everything else)
*** NOTE #2: DO NOT USE AN IMPACT GUN
this will most certainly shear the flywheel key or damage the flywheel !!!!! (after 35 years, you can ask me how I know that, LOL)
1) Use a piston stop to hold piston from moving: THIS IS A MUST !!!
Ok, so you do not have one, let's make one.
a) remove the spark plug
b) insert a piece of recoil rope into the cylinder hole, leaving a tail to remove it by. (rope, large shoe string, anything that is soft, that is aprox 1/4 to 5/16 in diameter to place into the spark plug hole to help the piston to stop it's travel by filling up the empty space. Just make sure you can remove it later)
c) secure the saw (extra set of hands may be needed) and with a suitable wrench on the clutch center, rotate the clutch to the right until piston comes to a stop. With a hammer, tap the wrench to aid in rotation. This can be very difficult, and may take several taps.
d) after removed, inspect and grease the drum bearing before re-assemlby.
e) upon re-assembly of clutch, tighten by hand only, NO hammer required. The force of the chain will tighten the clutch.
f) remove the rope, and re-install the spark plug.
Nov 16, 2009 | Ryobi Garden
How to remove the 'governor?' so that I can remove the plastic cover and replace the cord pull on Ryobi strimmer RPT2543C
What you are calling the "governor" is accutally the clutch drum. The is a screw in the center that needs to come out, then you will need to remove the clutch with a small punch and small hammer, by unscrewing it. Then you should be able to get to the recoil assembly.
Hope that helps.
Good day, mate.
Oct 23, 2009 | Garden
Ryobi 720r weedeater. Starts, stalls, won't start.
When you rebuilt the carb did you remove and replace the welch plugs. If you did not, then that is probably where your problem is. Debris, varnish and corrosion can build up under the welch plugs and the unit will not pass fuel.
Sep 06, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
How is the clutch rotor assembly removed from a ryobi 720r trimmer
on my 767r there are 4 cap head screws on a funnel shaped piece that connects the shaft to the engine. Once removed you'll have access to the clutch
Aug 21, 2009 | Ryobi Garden
Need to know specifications of spark plug for Ryobi Leaf Blower
You can download the manual at www.managemyhome.com. I have the Ryobi 720r and the sparkplug is a champion RDJ7Y.
Jul 11, 2009 | Ryobi Garden
Garden Logo
697 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Nick Olsen
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
