My 1TB ext HDD fails to power up. I have a lot of movies and files on it ... and no back up.... Is it possible to transfer the files or is there anything I can do????
    President:
  • 1,851 Answers
The simple thing to do - if it isn't totally dead - and they do go dead is to make it a slave drive. To do this - find the pin settings and set the pin [s] to SLAVE or CABLE SELECT - then putting a new hard drive on your pc or using a pc with a good hard drive - put your hard drive in that unit. You can buy a good used hard drive and put it in your pc - making your current hard drive the slave and then boot the new hard drive - and look for the drive E - F - G - H - one of these will show up under my pc - double click MT COMPUTER - and look for the drives I showed you above. One of those drives will be the drive you made your SLAVE, Search that drive for your pics and information.
Posted on May 02, 2010
WD 1TB drive only shows up as a 10GB hard drive
WD has a courtesy Drive cloning tool from acronis. It's on their web sit under drivers. Don't worry about the "My Book" thing the file is labeled Acronis True Image WD Edition Software download.
http://support.wd.com/product/download.asp?groupid=132&lang=en
Apr 27, 2014 | Western Digital My Book Essential 1TB...
When i plug my usb external hard drive in, it does not even show that there is a usb drive
If your Ext. HDD has been formatted in NTFS the TV might not detect it. Transfer the files on to a PC then reformat the HDD in FAT32. Then reload the movies , most probably the TV will read the files.
Aug 06, 2011 | Toshiba 32AV600E 32 in. TV
It will read my ext hard drive, reads all the folders/menu's etc, but does not register the files "(null)", yet my other ext hard drive works fine.
try using file option instead of movie or music cos some time when you use movie or music it will only look for movie or music files also what formatt are your movies in cos it has a prob reading certain files and codecs like mp4
Nov 01, 2010 | AGPtek NBOX RM RMVB MP4 VOB MPG 3GP AVI...
My Memorex 320 gb ultra travel drive is not working correctly; when I search a file, it finds it but then some of them don't open and I can hear a clicking sound on the disk like if it was searching for...
Sounds like the HDD is failing or failed. Try removing side cover to your PC (Switched off and unplugged from power supply) remove the CD cable / plug it into the ext HDD (Dismantled) boot into Windows.
If the PC cannot read the drive then it is damaged with loss of all files. If you can read it, I suggest you transfer backed up files to your PC before it fails completely.
Dec 30, 2009 | Memorex Ultra Traveldrive - 160GB USB Hard...
Format from NTFS to FAT 32
You'll want to leave this drive in NTFS format as FAT32 has lots of limitations in cluster size and total drive size.
The issue with your DVD- Media Player has nothing to do with how you formatted an external 1TB HDD.
It's possible that the two occured at the same time for different reasons.
Oct 15, 2009 | Western Digital My Book Essential 1TB...
1tb simpledrive will beep, click, but not work. No joy.
power source jack/plug might be the problem if it has been bumped about or if it was powered up and running before plugging in to the comp.....
i had the problem of my 1tb ext/hdd no longer being recognized because when i plugged it into my comp, the jack was live and not switched of at the wall. the only way i got it to work was to pull it out of the casing and switched it with the 320 ext/hdd i have as they are they same brand..just diff sizes. going to put the 320 into comp to become master drive as the internal is a measly 40g. i think i had burned out the connector pins on the power jack when it was plugged in live. i hope this is an idea for you to try.
Aug 24, 2009 | SimpleTech 1TB External USB 2.0 Hard Drive...
I have issues while transferring files back from Western Digital 1TB external drive. I copied all my important files there. In explorer all files are showing, but have issue, when you want to open or copy...
Hard drive may be going south and there may be bad sectors on it. Run WD diagnostic program on it and cross your fingers. Do not format the drive - that will erase all. If you do find bad sectors the check disk program will find and block bad sectors and move data in bad sectors to good ones whenever possible. After that you can recover as much as you can but not all because there will be areas where nothing can be read at all depending on the severity of the damage to the sector.
Sep 12, 2017 | Western Digital MY BOOK HOME 1TB EXT...
Cannot copy files Parameter Incorrect
most likely the issue is that your trying to copy files over 4gb to fat32 disks, and this causes the parameter incorrect -issue. Try formatting the drive your copying to ntfs, this can handle +4gb files.
Nov 11, 2008 | JVC Everio GZ-MG360 HDD Camcorder
Computers & Internet Logo
54 people viewed this question
David Payne
David Payne
