Question about Canon SmartBase MP360 All-In-One InkJet Printer
Spillbläck full? What to do - Canon SmartBase MP360 All-In-One InkJet Printer
  • Canon Master
  • 11,800 Answers
It means that the pad that absorbs the ink when the heads are cleaned is full and if you use it more it will spill the ink over your desk. The official way to deal with that is to take the printer to a dealer and they will clean the absorbing pad and reset the warning.
You can do both yourself:
1 - to clean the ink pad: remove the cartridges and unplug the combo - the carousel should remain in the middle, leaving the pad in the right side visible; take the printer to your sink and pour water over it thru a pipe (try not to splash it everywhere) until the pad becomes white and the water that flows out colourless; allow it to dry thoroughly (at least 2 days in a hot environment).
2 - Reset the Waste Ink Volume Counter
1) Press Menu + Copy + # to enter SERVICE MODE.
2) Select TEST MODE.
3) Select 8 - PRINTER TEST in TEST MODE.
4) Select 3 - EEPROM CLEAR.
5) Select 0 - INK COUNT.
6) Press the OK key.
7) Press the Stop/Reset key (returning to the state of 3) and then press the ON/OFF key.
Posted on May 01, 2010
    President:
  • 4,070 Answers
You may need to replace the wastepad sponge to avoid spill. If not, you can just dry the wastepad sponge so it can absorb ink. HOpe this helps and have a good one!
  • 5,603 Answers
The waste ink reservoir is full based on an internal counter of cleaning cycles.
Disassemble and remove the waste ink blotter. Either rinse it (takes a lot of washing till light grey) or replace it. Reassemble unit.
Then download and run service software for the printer that will reset the waste ink counter. Search web for maintenance spftware for the Canon printers.
Hej jag har prolim med lexmark cover open
Det kan vara patronerna i bärselen. öppna skrivarens lucka och ta bort bläckpatronerna. Kontrollera cylinderampullen område för några hinder i bärselen vägen. Om inga, stäng locket. Koppla ur och tag bort skrivaren till strömkällan att återställa sig själv. När skrivaren slås , sätt tillbaka bläckpatronerna och kontrollera att de sitter i rätt och säkrade. Stäng locket. Försök skriva ut igen.
May 04, 2011 | Lexmark X3480 All-In-One Printer
Für die Übertragung eines Filmes von dem Camcorder Panasonic NV-GS17G brauche ich einen Firewireanschluss am Notebook Aspire 7736. Welches Gerät eignet sich für einen Einbau? Mit...
Hallo Horst,
Ich habe die Spezifikationen f?r beide Ger?te nachgeschaut und sehe, dass beide einen USB 2.0 Anschluss haben.
Damit sollte eine ?bertragung doch m?glich sein, oder ?bersehe ich da etwas?
Selbst wenn Du einen USB->Firewire Adapter installieren w?rdest, w?re die ?bertragungsgeschwindigkeit durch das langsamste Glied in der Kette bestimmt.
USB 2.0: 480 Mbps
Firewire 400: 400 Mbps
Firewire 800: 800 Mbps
Einen Firewireanschluss in ein Laptop zu installieren is nahezu unm?glich, weil kein Platz f?r Erweiterungen vorgesehen ist.
Es gibt aber externe Alternativen (siehe z.B. hier).
Pass auf, dass Du eine Firewire800 card kaufst - 400 w?re langsamer als der eingebaute USB port!
Wenn Du noch weitere Fragen hast, schreibe einfach einen Kommentar - vielleicht kann ich helfen.
Viel Gl?ck!
Sep 19, 2010 | Acer Aspire M3201 Phenom X3 8650 PC...
Open Questions:
See all Canon SmartBase MP360 All-In-One InkJet Printer Questions
Canon SmartBase MP360 All-In-One InkJet Printer Logo
421 people viewed this question
old marine
old marine
