Question about Whirlpool 5' Jacuzzi Tub Bathtub Cetra 532 H525-969
My jacuzzi works fine but the air button seems faulty as turning it makes no difference. The clear tube is connected to the box on top of the motor. Any thoughts?
Lots ot time a small spider nests in the tube or switch body. If you can detach the tube at the switch and run a pipe cleaner down to clear the web, that might help. also look for cracks or holes in the tubing.
Posted on May 01, 2010
We turned on our soaker tub, ran it for a bit, then it wouldn't turn off. I then flipped the circuit breaker off and now the tub will not start when you push the start button. Model B950.
If the switch is an air type switch check the tubing connected from the switch the control for kinks or pinched spots. This could be the cause of the problem. Hope this helps.
Bob
Jul 04, 2014 | Jacuzzi Tara, Whirlpool Bath -...
How to install whirlpool jacuzzi switch
Air Switch Repair
It sounds like you have a bad air switch located in your motor.
The air switch is what the air hose connects to on the back of the motor or on the box on top of the motor. The other end of the air hose is connected to the air button on the lip of the tub.
This is a latching air switch and when you push the air button it latches to send power to the motor. When the air button is pushed again it opens the latch in the air switch and stops power going to the motor shutting it off.
US Parts Center
Apr 27, 2014 | Jacuzzi Home
Jacuzzi tub will not turn on button will not click on as usual
Your problem is most likely NOT the air button but the switch in the motor.
Air Switch Repair
Rod
US Parts Center
Apr 10, 2014 | Jacuzzi Home
Jacuzzi majic touch won't turn on
Air Switch Repair
US Parts Center
Nov 28, 2013 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
My on off button quit working on my bath jacuzzi. I can go out to the garage and trip the breaker to turn it off and on. I used to be able to barely push it and it would come on or go off, now you can...
US Parts Center
Oct 25, 2013 | Jacuzzi Whirlpool Bath Tub Real EG85-969...
Kohler led lighting and jacuzzi motor + jets stopped working but automatic line clearing air still blows when tub is emptied.
Air Switch Repair
US Parts Center
Bath Spa Replacement Parts Hot Tub Bath Parts Accessories US Parts...
Oct 06, 2013 | Kohler Home
On off switch isnt working,i have to unplug tub to turn it off
When you push the air button and nothing happens it could be the air button is bad or could indicate the air switch in the motor is bad.
pull out the motor and plug it into a wall outlet. take a straw and push it onto the air switch, where the air tubing was connected, and blow into it.
if the pump comes on then you will need a new air button on the top of the tub. If however it does not come on then will need the air switch that is on the motor to rectify the problem.
Feb 08, 2011 | Jacuzzi Home
My american standard jacuzzi tub doesnt work. It's plugged in, but the push button doesn't engage anything. It worked before I removed it to install ceramic tile around and under it.
check the air tubing coming off the back of the motor. that tubing should connect from the air switch on the motor to the bottom of the air button on the top of your tub.
if it is not connected then it will never turn on.
Feb 03, 2011 | American Standard Home
1980's jacuzzi bathtub, won't turn on (seems to be the kind when you push a button in to turn on), no outside electrical panel, no clear point of access (tiled on side of tub) - where do we start?
you will need to open up the back of the tub where the pump is and see if there is a clear tube about 1/4" OD attached to the backside of it close to the pump cord.
If it is there then you will need to check out the air switch on the motor that the air tubing attaches to to see if it is good. If it will activate the pump when you blow into it with a straw then the air button on the top of the bathtub is probably bad and needs to be changed. if it does not turn the pump on/off when you blow into it then you will need a new air switch.
Jan 23, 2011 | Jacuzzi Home
My jacuzzie motor just clicks and won't turn on.
Look behind the tub cover, it should have one. You should be looking for a GFCI it sounds like. These are the outlet that you generally have in your kitchen. They have a reset button and it just sounds like it needs to be reset.
Aug 02, 2009 | Jacuzzi Bellavista 6 Whirlpool w/2-Speed...
Whirlpool 5' Jacuzzi  Tub Bathtub Cetra 532 H525-969 Logo
436 people viewed this question
Top Whirlpool Home Experts
Donni Steen
john h
Mike
Are you a Whirlpool Home Expert? Answer questions, earn points and help others
