Question about Sirius Sportster 4 SP4-TK1 Satellite Radio Receiver with Car Kit
Sirius Sportster car kit - blown fuses
Hello: I have 2 Sportsters with car kits. No problems up until yesterday
when the unit in my wife's car blew the fuse in the 12V adapter. I replaced it with the fuse from my adapter and it worked for about 3 minutes before blowing that fuse. I tested the 12v source in her car and there's no problem with other products (cell phone chargers, etc.)
Is her adapter bad, or should I just try a bigger fuse than the 2A250V one that came with the adapters? Thanks!
  • 20 Answers
Try the other adapter and see if it works without blowing the fuse. If that fuse blows also, something is wrong with the radio.
Posted on Apr 27, 2008
SOURCE:
Power window
why not do the tests and not make assumptions. its an old car.
let reality win. it always does..... on all machines.
what will be , will be......
its just and electric window.
1: guides jammmed.>? feel them.
2; motor dead, got 12vdc to it. y./n
3: no 12v to moto?r,. must be bad switch, its got 0v out.?
i the check input.
4; oops the switch has no 12v input, dang the fuse blew.
dang the wire fell off. it. dang the connector is corroded.
a $10 walfart meter and im guessing free......
the FSM covers this, why not read it.
all cars,
Jun 05, 2013 | 1998 Honda Accord
Radio windows and sun roof fuse keeps blowing
Chafed wiring is my suspicion. The door wiring is a prime culprit, where the harness leaves the car body and enters the door.
Get a blown fuse, wire a 12v 21watt lamp across it and plug it in. The light will go out or flicker as you find the faulty wiring.
Jan 24, 2018 | 2004 Ford Explorer
My Garmin nuvi 265 was working fine until 2 weeks ago. We got a screen message saying that the XM traffic was not supported, and then noticed that the unit no longer could be charged using the car...
The traffic receiver is in the car charger cable. The charger should have a red light on if it is getting power. If the light is on and the unit is not charging and you have no traffic, the charger cable is bad. If the light is off, then either the fuse did not fix the problem, blew again, or is somehow not sitting properly in the charger. Another thing you can check is by using the unit in another vehicle. If it works fine there, then the charger is not making good contact with your vehicle outlet for some reason. You will probably have to buy a new traffic receiver charging cable.
May 04, 2017 | Garmin nuvi 265 Car GPS Receiver
Subs and amp dont work
His amp probably blew your fuse. Check that you have 12V at the power connections. If you don't, then find the fuse in your positive wiring to the amp. If you do have 12V to the amp, check your remote power up also has 12V between that and the negative line when your head unit is on. If it doesn't, then it's probably an internal fuse in your remote switch on line inside your head unit caused by a fault in your friends amp. This is normally accessible at the back of the head unit.
Oct 06, 2009 | Legacy Audio LA370 Car Audio Amplifier
Fan blew 12v car fuse
You probably burnrd out the wiring into the lighter or, you burned the contacts in the lighter socket. You can not use an AC fan in a car. A car is DC.
Jul 09, 2009 | Radio Shack 120VAC 4" Fan
Which audio wire could have tripped the power windows?
The radio should have 2 fuses, 1 is batt 10 or 15 amp and 1 is acc 7.5 amp. The windows should have 1 or 2 fuses and relays.
Jun 03, 2009 | 1998 Buick LeSabre
Blowing fuses
[double post]
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
But I would wait until the authorized servicer gets there (or take it to them) to maintain your warranty.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 02, 2008 | Maytag MMV5207A Microwave Oven
Acquiring signal
My wife replaced the car kit.
The sportster itself was fine, what fixed the problem was replacing the cradle.
Now the second one has taken a dump.
May 21, 2008 | Sirius Satellite Radio Sirius Sportster...
TX-R3079WHX/XAA Blown fuse
greetings from belize make good checks in your power supply replace your voltage regulator it has an short which is activated after accumulating heat.change the horizontal transistor.and the bias diode the feeds to the B+ to the flyback.if that does not solve the problem replace the flyback.your problem is intermittent so you cannot check voltage just replace components matter of fact replace all the components in the power supply you can buy a kit from www.dalbani.com in miami florida.good luck.
Dec 27, 2006 | Samsung TX-R3080 30" TV
Sirius Sportster 4 SP4-TK1 Satellite Radio Receiver with Car Kit Logo
787 people viewed this question
Top Sirius Audio Players & Recorders Experts
Anthony Ward
Anthony Ward
Larry Alex
Level 1 Expert
Are you a Sirius Audio Player and Recorder Expert? Answer questions, earn points and help others
