I have a VIZIO Model SV420XVT1A that will not power up. I have a yellow light in front and can see a faint 5.1 through the chassis. Can i get help with the possible issues? Thanks
  • msheared May 01, 2010
    Thanks an I agree. I am a electronics tech and will look. Thanks
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. From what you have described it seems the issue is with the power board or the main board and we’ll need to check few things. When you open the unit up; take a look at the power board-the board where the power cords/plugs goes into. You might see some filter capacitors a little bulged up in the top-If this is the case-this is your defective part(you can try to replace them-but some soldering equipment is needed). If not, then probably the main board has gone bad. This is the other board-where all the inputs are going into. All this is only recommended if you have electrical expertise and know how to solder/re-solder components. Please note that the TV components consists high voltages even when in off position. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on May 01, 2010
Vizio LCD SV420XVT1A-has a red screen when starting then red bleeding through dark
Got to go to settings to change the color of your tv screen and see if that helps
Jan 23, 2015 | Vizio Televison & Video
Red pixels on vizio tv model sv420xvt1a
A picture or video would be great
Jan 13, 2013 | Vizio 42 in. LCD TV
I have a: Vizio SV420XVT1A.... The TV dont turn on!!... The logo light is off and have a sound like a beep beep and a red light blink a number 5.1 in the bottom of the TV
The main digital board to your TV should be troubleshooted. If it found faulty, there is no other way than replace it as card basis. There is no repair to these boards. Very like computer motherboards.
Oct 27, 2012 | Vizio New Original SV420XVT1A Remote...
Model Vizio SV420XVT1A will not power up. The Vizio logo is amber, nothing happens when you press the power button.
You will need to have the set diagnosed as there a number of things could cause this. But I would say you're looking at a power supply or main board problem. It is also possible that your key controller (side buttons) is defective. I take it the TV doesn't turn on with a remote either?
Sep 09, 2012 | Televison & Video
47"Vizio model #XVTSV Led LCD
this is the only way to get rid of the orange light: l3_3_in_hdtv_lcd_television_412611.jpg
  • Connect
  • reset
  • Blurr
  • installation
  • trouble
  • settings
  • service menu
  • set
  • channel
  • parts
  • instructions
  • troubleshooting
  • remote
  • connection
  • drivers
  • blue
  • repair
  • manual
  • bug
  • CODES
Problem with Vizio L32 32 in. HDTV LCD Television
how do i turn off the orange light on the vizio tv, it won't go off after the tv is turned off?
Posted by avatar1.jpgmeg_car on Jul 08, 2009
Vizio TV Repair Power supply troubleshooting Picture problem Sound problem
  • Service by: avatar6.jpgmjsazon
  • 5 Stars
  • Email
Solutions (2) Best Solution That little fella is only turned off by unplugging it. If all those little lights in America could be turned off we could do with one less nuclear power plant. If unplugging it is not an option, my wife's solution is to cover it with a piece of black tape.
+ Add a comment
remove all screws on the back of the tv, carefully pull off back cover. you will see two circuit boards one on the left (Power) and one on the right (Video) on the Video board there is a small plug on the right side with a yellow, white and red wire going into a small white connector. the red wire is what controls the orange light on the front. now that the plug is pulled turn it over and you should see a small white plastic piece that holds each metal connector on the end of the wires in. pry this piece of plastic up for the red wire and pull at the same time, the wire will come out of the connector. now tape the metal connector with electrical tape and tuck it behind something or tape it to the chassis. plug your connector back in. put the rear cover back on. now your tv will only show the vizio logo in white when you have the power on. If you wish to disable the logo for both orange and white just disconnect the white plug completely.
May 16, 2011 | Vizio XVT473SV 47 in. LCD HDTV
I have no power to my television. The vizio power logo is not even yellow.....unplugged and plugged back in and nothing....please help
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or
not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
I repair these power supplies. Write to jah2mil@hotmail.com if you require further assistance.
Dec 15, 2008 | Vizio L37 Television
Televison & Video Logo
52 people viewed this question
Top Televison & Video Experts
Electro Med Services...
