Just recently my screen has become barely visible. I dont know if this is related, but a few months ago I started seeing a verticle thin red line at about two thirds to the right. Trie to run screen sweep, but no improvement. Im not sure of the model number and cant find the manual. The unit is about 5 years old. Please help. Tom
SOURCE: vertical red line on my Vizio plasma
Spent 3 hours removing all what seemed like 100 freaken screws.
Took out the OEM 038A, caution the factory placed some type of heat transfer silicon clear grease on the back of the board so it will feel like it is glued on. Just be very carefull and gentle when prying it apart.
Be warned, you will need a magnifying glas to check those little resistors. They all checked out, no broken solders.
What I did observe is the grease melted down the back of the board and puddled at the bottom of the board and where the resistors sit.
I used rubbing alcohol to clean it all up but left the reside on the square pads. Cleaned the resistors and used a dry paint brush to dust of any lint.
Placed the component back and after 10 minutes the Vertical Red Line Disappeared.
Turned on the set next morning it was still gone. 10 minutes later it re-appeared for a couple of minutes then went away.
I spoke to a kind gentlemen at Electronica-USA.com, he stated that the 060Q is an upgrade to the defective proned 038A ( 038C is also an upgrade ). A tech in Cali stated the 060Q worked perfectly. He has had zero complaints about the 060Q in the Vizio plus he offers a 90 day return policy. Funny thing is the 060Q was designed for LG and Goldstar Plasmas but for some reason they do not work for them but do work for Vizio's. He even states that on his site.
As I type the red line is still gone and stayed off several hours last night.
I think I am going to pull the trigger and replace the 038A to the 060Q and be done with it.
Oh yeah, I asked him if the 060Q needs to be "flashed" with the Vizio program. He never heard of it requiring it.
He has 038C on order they are couple of bucks cheaper. the 060Q is $224 plus S&H.
I found on ebay for $184 free shipping but waiting for the guy to verify no "flash" requirement.
Hope this helps someone.
Merry Christmas and a Happy New Year!
P.S. use a power screwdriver, your wrist will thank you. I put mine on low torque as not to strip the heads.
If the line is horizontal then it could be a y-drive panel ( depending on from ctr where it is ) whether it is the upper or lower board. Time to let a service company look at it, don't wait, more damage is possible the longer you play it.If it goes vertical ( up & down ) then it could be one of two buffer boards.
SOURCE: The left half of my Vizio tv screen turned black
This is common and very likely the LCD panel has lost its connection at those points around the panel. Most repair shops don't even try to fix it as it is a huge pain to try. You should be able to get a warranty replacement if it is new.
Yes it's. Just bring it 2the nearst electronic shop for repair. T power my be spoile or some insect get inside n make it burn. It's ever happen 2 my tv also.
