Question about Acer AL1716 17" LCD Monitor
Light on power on switch keeps blinking, screen blank.
Intermittent problem, monitor 'on switch', when turned on, the green light on the power button starts blinking, screen blank. after unplugging and re-plugging in several times it works.
  • Acer Master
  • 2,404 Answers
Definitely a problem with the monitor. If you can get the back open then look at the main board and the power board. You will want to look for puffy capacitors. Instead of a flat top it will look puffy like its pregnant.
If you find any like that then you need to replace them with new capacitors that have the same Uf rating and at least the same voltage or higher.
This will take some unsoldering and soldering skills. Make sure the stiped edge gets aligned with the striped edge on the board.
If you replaced them then the monitor should turn back on. If it doesn't then its a screen problem and you'll need to get a new monitor.
Posted on May 01, 2010
My monitor does not turn on and the power button light keeps blinking ... <my Gateway monitor light blinks blue slowly but the screen is blank
This is usually a sign that there is no signal going to your monitor, check all your cables and then reboot.
Jun 28, 2010 | Gateway FPD2275W LCD Monitor
I have a monitor HANNS-G It worked 3 years. And exactly after 3 years warrant policy ended my monitor got a problem. It looks like there is a problem in power connection on front buttons. After I connect a...
This is a problem with the power supply unit inside the monitor, there is no easy way out here. If you keep on using your monitor like this eventually it won't switch on no matter how long you wait. Keep on using it like this for the time being without switching off anything but ultimately you will have to take it in for repairs or otherwise purchase a new screen..
Aug 02, 2009 | Microsoft HannsG HU171D 17" LCD Monitor
There is no display on the monitor screen. The amber light on the power switch keeps blinking uselessly!
The monitor requires service The monitor is not receiving a signal from the computer
Apr 15, 2009 | Computers & Internet
HP L1706- screen is blank when I switch on
First if you have a extra monitor try to plug it in and see if it works. If not then check your video card. or get into the computer and try and remove and reseat the memory. Sometimes by just doing that can solve the problems
Feb 06, 2009 | HP L1706 17" LCD Monitor
Blank screen, led lights on, intermittent beeps
take out the RAM of your laptop, put it again,
also check the display on external monitor through vga port
Oct 20, 2008 | HP Compaq nc6000 Notebook
Viewsonic vp930b-3
MY VP930b has the same problem.
It takes a very long time (5-10 minutes) before it becomes normal.
Aug 04, 2008 | ViewSonic VP920b 19" LCD Monitor
Green light blinking screen blank
Hi Suzee,
Is the green flashing on the tower or the monitor?
If it is flashing on the monitor, then it might be tht the monitor is not gettign signal from the tower.
To check, disconnect the monitor from the tower and check the monitor. If you get a msg on the screen like no input signal or check video cable, then 99% monitor is fine.
Check for the power supply light at the back of the tower.
Disconnect everything from the computer and then press and hold the power button on the comp for about 30 seconds.
Then connect the cables and check if it is working.
Jan 14, 2008 | Sony SDM-S73/B Monitor
Blank screen
its cheap buy a good one!!!!!!
Dec 22, 2007 | Computers & Internet
Acer AL1716 17" LCD Monitor Logo
886 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
