Question about Baldwin 5445.003.PASS Classic Lever, Lifetime Polished Brass
My Baldwin Brass lock has stopped working - the lever on the outside is stuck in the down position, and so I can't open the door from the outside at all anymore. I tried to take it apart, but I can not figure out how to remove the lever handle on the inside. I unscrew the hidden allen screw, but then the handle only moves about 1/4 inch out before it won't come off any further. I'm obviously missing some vital piece of information but I can't see to find any information anywhere. Any ideas? Thanks!
  • Kristen Kessler May 06, 2010
    Thanks for your solution, but that's not the problem. There is something mechanical holding the lever down. It wiggles a little, but it seems like there is definitely something gone wrong in there. I'd like to take the lever off the inside so I can get in there, but I can't. Any other ideas? Thanks!
  • Kristen Kessler May 19, 2010
    Sorry it has taken me so long to get back to this. I took the screw all the way out and still no luck getting the handle off. Is there a way I can send photos to you? I took a bunch but don't see how I could get them to you. FYI, there is no knob on the outside of the door, just the thumb lever and a curved, vertically-oriented handle, which is only decorative. The deadbolt is a totally separate assembly, and there is no locking mechanism on the latch, no 2 little plugs that alternate to put the latch in a locked position. Let me know how I can send you a photo so you can see what I'm looking at. Thanks again and sorry for the delay.
  • 2,100 Answers
Did you take the allen screw all the way out? It has a sharp point on it and will get stuck in the slot, Once you get the handle off, the rosette is threaded on, and the threaded part is screwed on to the door, you don't have to mess with that, or the threaded part either. Pull the knob out the other side, It should be split in the middle? One side turns, the other doesn't and vice versa. Pull out the bolt, 2 screws in the edge of the door, it has to be either, broken, wore out or just dirty from wear and tear. The spring in those things is strong, strong enough to lift the lever up and keep it level. I have seen them weaken and break, also stop working from metal shavings in there. A drop of oil might work wonders, you will have to get it out and check it out. Now,, that is not for a mortise lock, It is for a basic passage leverset, by Baldwin. If your lock is fancier than that, let me know. Hope this helps.
Posted on May 06, 2010
  • Ned  White
    Ned White May 07, 2010
    OK, Did you get the screw out? Is there a screw on the other side? Did you get the handle off? Is it a bolt type leverset? Not a mortise lock? Is the bolt split in the middle? Or did both handles move at the same time? If you get the screw out of the bottom on the lever, it should pull off, I don't think it is threaded, some were. Both levers should pull out. If they are worn, they might need a little umph. You might have to take the rosette off so you can peek in there to see whats going on, try pushing the plunger in and pulling at the same time.
  • 10,865 Answers
Hello. Get a can of WD-40 penetrating lubricant with a tiny application tube attached. Squirt some into the latch on the edge of the door and let it work for an hour. Try the door. then apply a little to both sides of the handle. Reappy as needed. Joe
Posted on May 01, 2010
Exterior door stuck closed manually retract ****** remove knobs KWIKSET
You will probably need to replace the latch assembly. There is a small rivet that holds part of the latch together, and it also acts as a pivot point for a small piece that retracts the latch. If it gets bent, the latch won't retract fully, but you might be able to push it back and get the door open.
May 24, 2014 | Kwikset 740ll 3 Smt Lido Keyed Entry Lever...
2012 Toyota highlander (Base Plus model) rear passenger door will not open. I removed the door panel to fix the exterior door handle end cap, put it all back together, shut the door, and now it will not...
rear doors have a child lock in the door that you can set to stop children opening the door from the inside. IT is normally in the rear flat section of the door and is a small lever.. I think that in working on the door this lever was moved to the lock position . You should be able to open the door from the outside if this is the problem
Oct 27, 2013 | Toyota Highlander Cars & Trucks
Re-assemble a kwikset front door lever and knob type latch
Since the exterior side of the lock only has a keypad and no lever, I'm not sure what you mean by the "outside lever". Here is a clear, easy to follow video of the installation. Please carefully review each aspect of your installation against it to see if you can spot an installation mistake:
http://www.kwikset.com/Videos/Vitro/smartcode.aspx
Sep 03, 2012 | Kwikset 909 909-L03 Lifetime Polished...
Right rear child lock is on the door but cant get the door open
Child Locks will stop anyone on the inside of the car from opening the door. If the child lock is on then the door can only be opened from the outside of the car. Of course the main door lock must be off just as any door must be unlocked to be opened from the outside.
Now if you do not want the child door lock to be on then you must first open the door from the outside with the main lock open or unlocked. Look at the space that is covered when the door is closed. There you will see the lever that turns the child lock on or off. Simply move it to the off position.
Good Luck.
Jun 22, 2011 | Toyota Highlander Cars & Trucks
Both door locks do not work properly. I can only open the drivers side door from the inside. And the passengers side door will not open at all. This is on a 1999 Ford Explorer Sport.
Do any of the door handles inside or out feel sloppy (when you pull on them does it feel like there is nothing connected to them)?
If so that the levers on the latches are probably rusted up and sticking. Say for example the outside door handle lever that is attached to the door latch is stuck half way in the open position it will not allow the door lock mechanism to lock or unlock. The door will still latch and stay closed because the lever will not be stuck far enough to release the latch mechanism from hold on to the striker.
I have had pretty good luck removing the door latch (the part that actually holds the door closed) and soaking in penetrating lube and working all the levers until they move freely.
As far as the door that doesn't open I suspect it is stuck in the lock position and one of the handle mechanisms is in the partial up position. Again the symptom would be a sloppy door handle. That lever will need to be put back in its normal resting position before the door can be unlocked. This can be done with a slim jim. Once you have the door panel apart on the door that still opens you will be able to see the parts you need to move. You can then use that knowledge to move those parts on the other door that doesn't open.
If you don't have any experience with a lockout kit (i suspect most people do not) that that's the best way I can describe how you can do this yourself.
Sep 29, 2010 | 1999 Ford Explorer
I have a '04 rio and the driver side door is stuck shut, when the manual lock pin is pulled up, it snaps back down like its on a rubber band.
JEB, Homestead Florida
Total credit to rfbqwerty
Have 2003 Kia Rio 1.6, door shut, locking pin springs back down, I followed rfbqwerty istructions to the Penny and it worked in about 20 minutes I was able to open the door. The restst is a POC, thanks a million!!!
Option found in Google 6/16/2012
rfbqwerty
03-28-2006, 06:22 AM
Easy method to open a stuck Kia Rio door. Full credit to 'fastkia' for explaining how to open a stuck lock but after opening my lock by his method I found an easier way to do the job. You need a piece of straight wire (clothes hanger is good) and make a 3/4 inch square bend on one end. Wind down the window & push a tapered (plastic) wedge between the glass and the inside rubber to get a gap to work through. Poke the wire down beside the glass and pull up on the lever that is operated by the outside door handle. This is not the wire from the door handle but is the lever the wire connects to in the lock. While the lever is held up by your hook you can now pull up the locking button. Remove the wire from the door and everything works and it can be opened and closed as often as you like but don't press the button or use the key lock or it will be stuck again. The lever is normally held up by a small spring that has a sharp bend at one end and the spring will ALWAYS break at this bend. I used the same spring with a 'new' loop made from a section of paper clip to replace the old loop. Better than the original. No cost and it took less than 30 minutes
Mar 09, 2010 | 2002 Kia Rio
94 chevy lumina apv door will not open most of the time
since it is the drivers front door it could be the outside door handle , the rod that goes from the handle to the lock asbly or the lock asbly its self take the door trim panel off and then loos inside the door and latch the door with the door open. open the door with the outside door handle and watch the rod and the lever that the rod is pushing down the lever might not be pushing the lever down far enough to release the lock. If the lock does not open try pushing down on the lever and see if the lock releases if it does ck the outside door handle for cracks along the hinges of the handle I have found that most of the time that it is the outside door handle cracked and the rod is not moving the lever far enough to release the lock.
Feb 20, 2010 | 1994 Chevrolet Lumina APV
My door on my n01 grand am gt 2 door will not close. the thing in the door is like stuck locked? what can i do
Manually push the lock button into the UNLOCK position. Now HOLD the OUTSIDE DOOR HANDLE in the OPEN position while at the same time, moving the DOOR LATCH into the open position. Hope this helps
Jun 15, 2009 | 2001 Pontiac Grand Am SE
Baldwin 6321 mortise:when locked can open from either side
It sounds as if the lock is installed backwards or more specifically in inside mechanism. The inside lever/handle when turned should retract the deadbolt (safety feature). If yours does not currently switch around.
Feb 02, 2009 | Hardware & Accessories
Baldwin 5445.003.PASS Classic Lever, Lifetime Polished Brass Logo
1,088 people viewed this question
Top Baldwin Electrical Supplies Experts
Steve
Gene Haynes
Are you a Baldwin Electrical Supply Expert? Answer questions, earn points and help others
