Question about Nuova Simonelli Premier Maxi Espresso Machine
Lower gauge that monitoring pump always shows 4 no matter what. The upper gauge that monitors steamer works normal. As recommended in the user manual, I adjusted screws located near the pump but no response. Please help.
  • Nuova Simonelli Master
  • 1,711 Answers
The gauge is connected with pump water output with a very thin pipe called cappilary pipe. So if any dirt that is comming from the water supply can blocked this cappilary pipe and if this happens during the pressuring phase then blocked a pressure of 4 bar inside the gauge. So if you desconect the cappilary pipe behind the gause the you should see if any water comes out from cappilary pipe. If not you can remove it also from the side of the water pump and try to clean it by blowing air from the side connected to gauge this can clean it perfectly. The you can conect it back together. The you will read normaly the pressure of the water mains and during making easpresso pressure of about 9 bars. If you dont have any change in the gauge after performing above the gauge might be the problem.
Posted on May 02, 2010
Samsung monitor 204b screen image is split in to two parts; the upper part OK but lower part is gibberish, ghosty?
Interference. Separate the wiring so it doesn't touch. Touching wires create cross-talk of signals and keeps from running normal.
Feb 11, 2014 | Samsung Computers & Internet
My laptop screen resolution is already set to 1200 *600 and windows 8 does not support in that screen resolution they want to 1200 *768 what can i do
  1. Open Screen Resolution by swiping in from the right edge of the screen, tapping Search (or if you're using a mouse, pointing to the upper-right corner of the screen, moving the mouse pointer down, and then clicking Search), entering Display in the search box, tapping or clicking Settings, and then tapping or clicking Display.
  2. Tap or click Adjust resolution.
  3. Tap or click the Resolution list and find the resolution marked (Recommended). This is your monitor's native resolution-usually the highest resolution your monitor can support.
Screen Resolution in Control Panel shows the recommended resolution for your monitor.
Monitors can support resolutions that are lower than their native resolutions, but text won't look as sharp and the display might be small, centered on the screen, edged with black, or stretched.
Oct 12, 2013 | Samsung N150 (36725723009) Netbook
1998 Saturn Wagon 2 For the last few months my car cooling system seems to be running hotter than normal per the dash gauge. For years and even the the summer the temp gauge would never get over 1/4. I...
I would do a sniff at the tail pipe to make sure you are not pumping coolant out the exhaust pipe.
sound more like a bad gasket than a bad water pump to me.
Jan 27, 2011 | Saturn SW2 Cars & Trucks
The screen doesn't show the whole image, it is to wide, to tall, so there is no upper and lower toolbar, same on sides. I tried with the screen control on lower front of the monitor, but it is not enough.
your screen resolution must be changed to a lower MHz...
go to Control Panel/Dislay/Display properties/Settings/Screen Resolution/
here try a lower/higher resolution
then else try Advanced option there and set a lower setting there under the General Tab and Monitor Tabs.....
some hit and trial may solve th issue...be sure NOT to chose the wrong setting as that may cause hard to your monitor
Sep 05, 2010 | HP mx705 17" CRT Monitor
Samsung syncmaster713bm not optimum mode
try to adjust resolution you monitor may not support higher resolution change it in the display properties
Mar 13, 2010 | Computers & Internet
AoC 913 W Monitor driver. The monitor was the last in a show room and the seller didn't have no more the accessories, including the install CD! Now, the windows 7 only says I have a standard monitor, and I...
I don't think it matters whether or not you install the monitor. In fact I don't even think the monitor has a specific driver. The monitor should still display fine with a standard monitor driver. You should still be able to use all of its features. The more important driver is your graphics driver on your PC. That will determine your ability to change things like refresh rate or screen resolution.
In any case, if you would like drivers, the best place to go is to the manufacturer's website. This is the link for the manufacturer's Brazilian support page:
http://www.aoc.com.br/v2/php/index.php?req=pagina&pgn_id=4
This is the North American one:
http://us.aoc.com/support/downloads
Usually you have to go to downloads and select your monitor and the driver you want. Although honestly, they don't even have drivers on the American site, they just have the manuals and the technical specifications of the monitors. In general, monitors don't need drivers, and they usually aren't packaged with them. The install CD that you are referring to that would normally come with the monitor usually only has the user manual for the monitor in different languages.
Feb 15, 2010 | Computers & Internet
Monitor turns black and with a not optimum mode pop-up
Press F8 when you boot your PC, Then boot on SAFE Mode...
Right Click on Desktop>>Properties>>>Settings>>>Advance>>>Check the Apply the New Setting without restarting.
Click Apply then OK
Rebbot the computer to a Normal Boot
Oct 09, 2008 | Samsung SyncMaster 740N 17" LCD Monitor
Distortion in Monitor
Your problem is simply a leaky capacitor on the vertical oscillator circuit on your monitor. Try replacing the ones with 10uF values.
Aug 10, 2008 | Samsung SyncMaster 753S 17" CRT Monitor
A very thin vertical brun line in the middle
If it's a straight vertical or horizontal line always in the same place it's a panel issue which the average user even with repairing skills will not be able to reliably repair ,Sorry.
Samir
Feb 25, 2008 | Dell UltraSharp 1905FP LCD Monitor
Open Questions:
See all Nuova Simonelli Premier Maxi Espresso Machine Questions
Nuova Simonelli Premier Maxi Espresso Machine Logo
141 people viewed this question
Top Nuova Simonelli Coffee Makers & Espresso Machines Experts
J.D. Browning
J.D. Browning
Andrew Taylor
Andrew Taylor
Gil Shultz
Are you a Nuova Simonelli Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
