Question about Philips GOGEAR SA6045 MP3 Player
PROBLEM DURING THE UPDATING IS GOING ON
WHILE I OPEN'D MY GOGEAR, I WENT INTO A PROBLEM WHILE THE UPDATING IS GOING ON.MY GOGEAR STUCK AT D'AT TIME.
I D'NT KNOW W'AT TO DO.SO PLZ HELP ME.
    Master:
  • 383 Answers
Please flash the same . you will get the flashing utility or reset utility from their website. the software most probably has gone corrupt
Posted on May 01, 2010
It will not turn on or charge
Hi, the Philips GoGear is a portable MP3 player with additional functionality such as the ability to record your voice or the radio. Some minor problems may develop in the device that keep if from working normally. The most common issues are the GoGear freezing, not powering on and memory-error messages. Troubleshoot your device to return your GoGear to normal operation.
Unresponsive
1. Your GoGear may not respond to button presses from time to time. This is often caused by an error in the operating system and can be fixed by resetting the device. Resetting the GoGear is similar to rebooting your computer. You will not lose any of the data uploaded to the device. To reset the GoGear, press the "Reset" button located on the left of the device. The screen will go blank for a few seconds and then turn back on.
If the GoGear freezes after uploading a file to the device or if one song or sound file freezes the device each time you play it, the file is likely corrupt and needs to be removed from the GoGear. Connect the GoGear to a computer and delete the file from the device.
GoGear Does Not Power On
2. Problems with powering up the GoGear are often the result of an exhausted battery. If you cannot power on the GoGear, charge the battery with the supplied charger.
In some instances there is an error with the device that is keeping it from powering on. Unlike the errors that freeze the device, errors that keep it from powering on cannot be cleared by pressing the "Reset" button. The errors need to be fixed by using the "Firmware Manager." The Firmware Manager is a computer program that restores your device to their factory conditions. You will be able to use your device again after restoring it to factory conditions, but you will lose all of the data on your GoGear.
To use the Firmware Manager, open the installation CD supplied with your GoGear and follow the onscreen instructions to install the Firmware Manager on your computer. Plug the GoGear into the computer and check that your computer is connected to the Internet. Open "Firmware Manager" on your computer. You will be prompted to "Restore" the firmware or "Update" the firmware. Since you need to restore your device to working order, select the "Restore Firmware" option. Updating the firmware will not delete the files or errors that are causing the GoGear to malfunction.
Once the process is complete and your GoGear can power on again, consider updating the firmware. Updates give your device extra functionality and repair errors in the device.
Hope it helps...
Have a nice day.
Feb 22, 2011 | Philips GOGEAR SA6045 MP3 Player
Go gear vibe has been frozen for about 25 min. wont shut off or anything
Hi, i stuck a pin in the reset hole, (to the right of the lock switch) and it shut it off, than all you have to do is turn it back on..
The Philips GoGear is a portable MP3 player with additional functionality such as the ability to record your voice or the radio. Some minor problems may develop in the device that keep if from working normally. The most common issues are the GoGear freezing, not powering on and memory-error messages. Troubleshoot your device to return your GoGear to normal operation.
Unresponsive
Memory Full
The GoGear allows you to make voice or FM radio recordings and saves the recordings to the internal memory. The internal memory is limited and the GoGear may show the message "Memory Full" when trying to save recordings. When you receive this message, plug the device into the computer and delete any extraneous files or files you no longer want to keep on your device. This will free up memory so you can save more recordings or place additional music files on the GoGear.
Hope it helped..
Have a nice day.
Feb 22, 2011 | Philips GoGear ViBE Digital Media Player
Updating player keeps going and going
you could try to make firmware upgrade.
I think, this link will help you:
http://www.userdrivers.com/MP3-Player/Philips-GoGear-SA6015-SA6025-SA6045-MP4-Player-Firmware-Upgrade-1-15-2/
I hope your player will work fine again.
Bye, gylacz
Jan 30, 2011 | Philips GOGEAR SA6045 MP3 Player
My Phillips GoGear MP4 player stopped updating at 99% and will not continue.
1. Launch Philips Songbird program from Windows start menu. The program can be found on GoGear Accessories disk, or you can download it from:
http://www.userdrivers.com/MP3-Player/Philips-Songbird-1-7-2-Build-1667-for-Windows-XP-Vista-7/
2. Reset your GoGear player while holding Volume+ key and immediately connect it to computer. (You should do it before "Udating at ..." message appears.)
3. From Songbird menu choose Tools -> Repair my GoGear Vibe.
4. Follow the instructions.
Oct 09, 2010 | Philips GoGear ViBE SA1VBE08K MP3 Player
The Philips GoGear SA6045 i have won't start or reset. What should i do?
The problem your are encountering is often caused as a result of an exhausted battery. If you cannot power on the GoGear, charge the battery with the supplied charger.
If this isn't the case then there is an error preventing the player from powering on and this cannot be cleared by resetting
Aug 30, 2010 | Philips GOGEAR SA6045 MP3 Player
White screen after turning on laptop, have to reboot
It's sounds like the lcd is going out.
But it could also be GPU related.
Try updating the motherboard firrmware / bios
Updating the Video Drivers. If that produces the same results then more than likely the lcd will have to be replaced.
Let me know if you have any more questions.
Nov 23, 2009 | Video Game Consoles & Games
Goes white when turned on
try turning it on and leaving that way until the battery is fully discharged.
After that, try connecting it again.
Good luck
Jun 21, 2009 | Philips GoGear SA3125/37 MP3 Player
"Updating player" at start-up
There is not a way around this - Philips is not going to issue another firmware upgrade for this model. It is one of those minor annoyances that you have to live with.
Sep 21, 2008 | Philips GOGEAR SA6045 MP3 Player
Philips 6045 - updating player
Disconnect the GoGear from the computer and turn it off:
1) Open up Philips Device Manager (Start --> All Programs --> Philips) - if you don't see it, then re-run the installation CD or grab the "Device/Firmware Manager" from the Philips website
2) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button (if the repair tab does not appear immediately, then connect the disconnected GoGear to the PC temporarily - that should make the Repair tab appear)
3) Disconnect the GoGear from the computer and turn the GoGear off (if you haven't done so already) - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new
-Tha Mp3 Doctor
Jan 20, 2008 | Philips GOGEAR SA6045 MP3 Player
Philips GOGEAR SA6045 MP3 Player Logo
297 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
