Question about Kitchen Ranges
Igniter will not start - Kitchen Ranges
  • Kitchen Ranges Master
  • 43,501 Answers
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
Posted on May 04, 2010
It wont start with ignition but can clutch start and run fine what wrong with ignition
nothing wrong with the ignition but there is with the battery
when trying to start from the key , the battery falls below that required to start and run the ignition system but with a push start there is enough voltage to run the ignition system and then the alternator cuts in to supply power to all the rest
have a load test done on the battery
Mar 01, 2016 | 2000 Nissan Frontier
Do i need a fuse or immobilizer?
Search Results
    Replaced Ignition cylinder switch. Now I can't start car ...
    www.grandamgt.com > ... > Technical Q&A
    Aug 9, 2007 - 11 posts - ‎4 authors
    So the car should start right up right? Nope, still won't fire up, as if there is no fuel coming to engine. Did I do the passlock reboot procedure ...
    Auto Repair Problem with Car Won't Start and Ignition ...
    ? 1:20
    https://www.youtube.com/watch?v=Uz5dnWQBynw
    Aug 24, 2012 - Uploaded by YourMechanic
    When you start your car, it is the ignition switch that turns the engine on, when it is working properly ...
    Car won't start after changing ignition switch? ' Yahoo Answers
    https://answers.yahoo.com/question/index?qid...
    Jan 7, 2013 - Also, I think that you replaced the lock cylinder and not the ignitionswitch, .... Change ignition switch,but car won't start,acura integra 98 aut.
    HELP! Replaced ignition housing and barrel - car won't start ...
Feb 08, 2016 | Cars & Trucks
2001 dodge stratus no crank no start from ignition
When you use the ignition key you activate both the starter and ignition circuits. When you jump the starter motor all you do is crank the engine - you have not energized the ignition so car will not start.
Aug 26, 2015 | 2001 Dodge Stratus
Engine wont start
Engine does not crank (Does not start)
1. Starter and starter relay
2. Neutral start switch circuit
No initial combustion (Does not start)
1. ECM power source circuit
2. Ignition coil (w/ Igniter) circuit
3. Fuel pump control circuit
4. Fuel Injectors.
No complete combustion (Does not start)
1. Fuel pump control circuit
3. Fuel Injectors.
Jul 30, 2013 | Toyota Corolla Cars & Trucks
Is there a way to reset the ignition
use the ignition switch master key. turn the ignition switch for ten minutes until LED ignition warning light go off.then turn off ignition switch wait 5 seconds then try to start engine. if this procedure starts your engine have dealership or garage to check out theft security system.
Jul 28, 2013 | Cars & Trucks
Avital 4103 when i push start button the ignition lights come on but doesn't start the engine
Try leaving the key in the ignition (but don't turn it) and then try. If it starts then you need to properly bypass the transponder system. If not then most likely you don't have your ignition and/or start wires hooked up properly. On many cars there is a second starter wire that needs to be connected
Feb 17, 2013 | 4103LX 4Button Remote Start System with...
My riding mower will start by pull cord but not from ignition
Jump the solinoid with a screw driver, it the engine starts, replace the solenoid.
Apr 23, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Flashing alarm light after battery change. Car wont start,
System operation
System arms 5 seconds after switching ignition OFF. Switch ignition ON. Ensure clock LED illuminates for 3-5 seconds. If LED flashes rapidly at regular intervals for approximately 1 minute, then flashes at irregular intervals: Key code not recognised. Remove key and try again.
Programming
When
System malfunction: LED illuminates for 1 minute, then flashes at irregular intervals. Key(s) added or replaced.
NOTE: Replacement keys MUST have blue mark. Keys with red mark are NOT compatible with this system.
How
NOTE: Programming method using vehicle keys can be deactivated using diagnostic equipment.
Obtain 2 programmed keys (A and B). Insert key A into ignition switch. Turn ignition switch to position II. Wait 1 second. Switch ignition OFF. Remove key A. Insert key B into ignition switch within 5 seconds. Turn ignition switch to position II. Wait 1 second. Switch ignition OFF. Remove key B. Within 10 seconds: Insert key to be programmed into ignition switch. Turn ignition switch to position II. Wait 4 seconds. Switch ignition OFF. Wait 5 seconds. Start engine. If engine does not start and clock LED flashes: Switch ignition ON. Wait at least 20 seconds. Switch ignition OFF. Repeat programming procedure. Repeat above procedure to program remaining keys. Keys can also be programmed using diagnostic equipment
Mar 08, 2010 | 2000 Ford Focus
Kitchen Ranges Logo
50 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
