Question about Gateway GT5228 (7156) PC Desktop
Pci e video card not recognized by windows 7 32 or the bios
  • Gateway Master
  • 11,800 Answers
You must connect a monitor to it otherwise it will not be recognized (disconnect the monitor from the onboard connector before that). If you can't see anything - even the BIOS - this way eiter:
1 - the card was installed incorrectly;
2 - the card needs extra power - connect that;
3 - the card is dead.
Posted on May 01, 2010
Graphcis card wont work
You have received some wrong information.
This motherboard has a PCI-e x16 slot(ver1.0), two PCI-X 66MHz, and two PCI 33MHZ slots..
The video card must go in the PCI-e x16 slot.
The x8 lanes are hardwired from the Tumwater chipset to the BCM5721 LAN chip, and are not accessible for use.
There is no x8 lane slot on this motherboard.
Apr 06, 2014 | SuperMicro MB X6DAL-TB2-0 E7525 RT...
Configure graphics card
That graphics card is not compatible with that mobo.
Nov 27, 2017 | SuperMicro X7DVL-E Server Board -...
Palit geforce gt630 not recognized windows 7
Hi, you probably need to enter the bios and select ,turn on, the pci-express option. This graphics card has a good record of working well with Windows 7.
Feb 09, 2014 | Palit Microsystems Palit nVidia GeForce GT...
Can a PCI video card be installed on the Intel SE7501BR2 server board? My onboard video has color problems. I tried a known-working PCI video board after turning off onboard video, but got no video...
Most of the time you'll need to change a setting in the BIOS to force the computer to recognize the PCI slot first. Try going through your BIOS settings until you find it. It should be something like "Display First" or Primary, and it should be set to onboard graphics. Try changing that to PCI and see if that fixes your problem.
Aug 29, 2011 | Intel Server Board SE7501BR2 Motherboard
I am trying to install a pcie-x1 video card on a ibm eserver x206m i salvaged from work. I am running windows 7 64bit . I have tried to turn off on board graphics so that it takes the video card i just...
I know this is really old, but I had the same problem on my 206m 8584 with a pci-e x1 video card. I had to upgrade bios first, but nothing seemed to change, bios only showed onboard video as option and windows perfectly recognized the exta card. I went to windows video settings, it showed both video, onboard as main and active and extra as inactive, changed the second video to main and active and switched the plug to finally see my enhanced video. Only problem is that bios screen won't show up on pci-e card, so I start seeing something only after one minute :) Hopes this saves someone else some time.
Nov 03, 2010 | IBM eServer xSeries x206m
My HP M7260n doesn't recognize my new Video Card...
You might need to uninstall the old video card device, so Windows does not use the old drivers for the new card.
Another option is to try and boot in Safe Mode (press F8 during startup), so Windows uses the VGA mode (which all video cards support), and then install the proper driver.
Installing the latest ATI driver updates might also not be a bad step.
Jun 25, 2010 | HP Media Center m7260n (EG642AA) PC...
PCI Video wont work with Gigabyte GA-K8VM800M motherboard
hey try the removing cards.....
window 7 may took up it best when no such changes are around..
! Gb or 2 RAm is enough to get run your Win 7
and sound card is noot required untill you have 4 or more speakers
Feb 12, 2010 | Gigabyte GA-K8VM800M Motherboard
I can't get my board to recognize my ATI Radeon x300 se in the pcie pnp will not even recognize it.
You must enter the bios menu and set the video controller to boot to the PCIe first. Save and exit the bios. The proper orders when installing a PCI-E card is as follows; before you install you’re new video card onto the motherboard. Install the graphics cards software. Than shut down the system. Install the video card. Boot system and enter the bios menu. Go to and open Advance.
Open North Bridge Configuration
See page 4-23 in manual.
Internal Graphics Adapter should be set to [PEG/PCI]
Internal Graphics Mode Select should be set to [Disabled]
PEG Port Control set to [Auto]
Save you're changes and exit the bios. You should be able to boot to you're PCI-E graphics card now.
Cheers'
Mike
Feb 05, 2010 | ASUS P5E-VM HDMI Motherboard
Firewire PCI card not recognized
Sometimes, when one is inserting a card, one does not push it firmly in place. If some contacts are not well established, the card may not be recognized.
Hope it helps.
Aug 22, 2009 | HP Compaq d530 SFF PC Desktop
8800gt black screen
Hi Juan016, you have done everything right. I'd say the 8800GT is bad & return it for a refund. Run the 8600GT & the NVIDIA 6100 at the same time. If you check the middle of page 9 in your manual. NOTE: It states; if a PCI-E is inserted the bios will automatically run the PCI-E card. (No need to make a bios setting change).
It also says if you change the setting in the bios to, OnChip and PCIe VGA, the motherboard should run both. Depending what amount of memory you set the NVIDIA to run with. Once in windows check the amount of total memory the NVIDIA or 8600GT reports.
Example: You set the NVIDIA to use 64MB & the 8600GT has 512MB than the NVIDIA or the 8600GT should show 576MB. Its not that uncommon one buys a bad video card.
Reading the manual & windows not seeing the 8800GT tells me the bios did not see the 8800GT card. The card is bad. You’re doing just fine.
Mike
Sep 14, 2008 | PNY XLR8 NVIDIA GeForce 8800 GT 512MB...
Gateway GT5228 (7156) PC Desktop Logo
99 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
