Question about Whirlpool 24 in. GU2500 XTP Built-in Dishwasher
Whirlpool dishwasher Model#GU3200XTPS0 No power to unit, Control panel does not have power check the circuit and outlet, are OK. is there any fuse inside the unit? is circuit board has any fuse?
aborcass
  • 2651 Answers
SOURCE: whirlpool dishwasher repetes cycles continiously
yes does sound like a "stuck"button within the membrane switch cause constant restarting and/or re-cycling. wire diagram and tech sheet are generally located under the lower acesss panel(unless previous repair ***** returned it). tried looking up the part couldnt find exact model match mine all ended in Q1,Q2, ** Q3, but parts from my models ranged from 110-165
Posted on Mar 10, 2008
  • 1314 Answers
SOURCE: dishwasher is dead, no start
there is a fuse just before power enters the control panelwhere the line goes in check that first bet its open
Posted on Jan 29, 2009
  • 3 Answers
SOURCE: We have a Whirlpool Gold
I replaced the heater element on mine and that fixed the problem.
Posted on Mar 06, 2009
  • 37 Answers
SOURCE: kitchenaid dishwasher, control panel is not
I don't know your technical ability, but there is a fuse located next to the control board inside the console, this is a good place to start. Kitchen Aid is good about putting tech sheets on the back of the kickplate and it should have wiring and diagnostic info there. Just be sure to put the sheets back so the next service tech to work on it will have them :)
Posted on Sep 01, 2009
  • 949 Answers
SOURCE: I have a Whirlpool DU1055XT. The unit will not work
The flashing light indicates the water is not heating, there could be several reasons for this, I have created instructions on how to reset the dishwasher so you can use it and why it may have occurred. If you follow these and still have trouble let me know and we can dig into it deeper.
http://www.fixya.com/support/r4628906-flashing_or_blinking_green_clean_light_7
Posted on May 03, 2010
Whirlpoool model du920pfgb3--touch pad is not responding and no lights or nothing are on??
Control panel. Try to push cancel button to see if it resets.if not google it and they will walk you through it.
Mar 28, 2013 | Whirlpool Gold 24 in. Built-In Dishwasher...
No indicator lights Whirlpool wdt710paym dishwasher
If it doesn't run and you have no indicator lights, check the circuit breaker for that outlet. If it is ok, test the output voltage at the plug-in for the machine (115Vac). If it is "live" then check inside the control panel (turn off the breaker first) for a fuse that appears blown. If no fuse problem, CAREFULLY (with breaker back on) see if the main switch is getting power. If it is getting power, the control board is shot...replace it!
Dec 28, 2012 | Whirlpool Gold 24 in. Built-In Dishwasher...
Kitchen circut was accidently turned off. Now whirlpool gold disher will not work(unit was not running and the door was not closed all the way when circuit was turned off, All circuit breakers are on)...
You can put the unit into diagnostics (press the following keys in order within 6 seconds HEATED DRY, NORMAL, HEATED DRY, NORMAL all the lights will come on and it will start a diag cycle) and see if it recovers. If not, you are looking at a electronic control, and yes you CAN change the part yourself.
Mar 08, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
Whirlpool dishwasher won't turn on. There is power to the unit.
Make sure there's power getting to the dishwasher. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the dishwasher (inside the junction box, behind the bottom kick panel), if this is the case, the wiring must be repaired or replaced.
If everything stated above is ok, this will lead to a failed control sector. The control sector can be a timer module, or control board assembly.replaced the control sector if all above is ok.
Nov 06, 2009 | Dishwashers
Maytag Dishwasher MDBH965AW will not power.
If the junction box checks out ok, the wall outlet socket is live, replace the main control or timer module.
Jun 19, 2009 | Maytag 24 in. MDBH965AW Built-in...
Whirlpool GU2500XTP dishwasher went dead in mid-cycle.
"Wondering if this model has had reliability issues with the circuit card." ...If by circuit card you mean the electronic control board, that part number is used in many other models as well. In my experience with these control boards, I believe they have a low failure rate.
Make these checks if you haven't done so yet...
Check for 120V (breaker). Look for loose/shorted wiring connection at the dishwasher's junction box. Check all wiring connections to the control panel, electronic control and thermal fuse. Test the continuity of the thermal fuse (part # 8193762). If that's ok, you have already replaced the control panel so the problem is likely with the electronic control board (part # 8564546).
Good luck.
Mar 12, 2009 | Dishwashers
My Whirlpool GU2300 just stopped working. None of the panel lights come on. I've checked the outlet and it is working fine.
hi there,
here a few things to check:
plug the unit into another outlet, if you still don't have power then
unplug the unit and check the connections to the circuit control board on the frontand the keypad, if okay then
check the door latch assembly and make sure that the switch is making contact, if okay then
you have a blown TCO fuse on the control board
i would recommend replacing the control board, since the fuse is saudered on the control board.
let me know if any of this helps.
Oct 11, 2008 | Dishwashers
WHIRLPOOL QUITE PARTNER ii
there is a thermal fuse attached to the main control, check for continuity if none replace fuse.
Jul 19, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool dishwasher stopped working...
It sounds like the thermal fuse in the control console has blown.
Turn power off to unit.
Remove the outer door panel and then the console.
Remove the black plastic cover from over the circuit board if it has one.
You should see the thermal fuse clipped to the circuit board housing.
If you have an ohm meter, check for continuity across it, it should read closed.
If you don't have a meter, unplug the wires from it and and hook them together.
Turn power back on to unit, hold door switches down and cancel cycle. The washer should drain the water.
If this doesn't work, check your door switches to make sure they are closing properly.
Nov 17, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool 24 in. GU2500 XTP Built-in Dishwasher Logo
99 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
