Question about Brother MFC-7820N Laser Printer
Replace Drum Soon Message
I am getting the "Replace Drum Soon" message. I replaced the drum about 3000 copies ago and it is still printing fine. Any suggestions?
  • Anonymous Apr 04, 2008
    I've been getting that message for months, never replaced the drum and it's still working. I do have a drum I bought, just in case...
  • Brother Master
  • 1,113 Answers
Read your manual. There is a counter that goes off, that can be reset when you change the drum.
With power on and front cover open press set, then select reset drum
Posted on May 11, 2008
Continue to get a message to change drum soon. Changed drum already. Print quality is still not good.
hi
This message would continue to appear if the drum counter was not reset when you replaced the drum. To reset the drum counter, follow the instructions listed below.
  1. Open the front cover.
  2. Press the Options key on the control panel.
    The display will show "REPLACE DRUM - 1.YES 2.NO".
  3. Press 1 to reset the drum count.
  4. Close the front cover.
Oct 07, 2008 | Brother Office Equipment & Supplies
How to reset " replace drum" for brother MFC-7860DW
Time to really order a new drum and really replace with a new one.
Resetting the drum unit will not improve print quality. It only resets your drum and allows you to continue to print. You decide when to replace the drum unit not the manufacturer!
1.Remove the drum unit and toner cartridge. Wait 1 or 2 minutes.
2.Replace the drum unit and toner cartridge into printer.
3.The error message "Change Drum Soon/Drum end soon" will continue to appear if the drum counter was not reset when you replace the drum unit.
4.To clear this error message, you need to reset the drum counter as instructed below.
5.Make sure that the machine is turned on.
6.Press Options.
To confirm you are installing a new drum, press 1.
7.When the LCD shows Accepted, close the front cover.
8.Your drum is now reset.
Jul 30, 2014 | Brother MFC-7860DW Laser All-In-One
Drum end soon again
My MFC-7420 began to display the message "Drum end soon" so I quickly went out and purchased a new drum. But I decided not to install it until I needed to. Because what does "drum end soon" mean? I thought it would mean that the print quality would deteriorate enough that I would notice the problem. So I continued to replace toner as needed, and pushed the blue cleaning thing down the wire regularly. This went on for over 3 years until *finally* I started having regular print job production problems. I replaced the drum, and the problems were solved. So,my advice is be prepared, but don't replace the drum until you have to -- the message means very little.
Mar 18, 2014 | Brother MFC-7340 All-In-One Laser Printer
How do i reset ricoh sp 1200s drum unit
why toner life end message keep on showing on sp 1200s prints.
Aug 04, 2012 | Ricoh Office Equipment & Supplies
Alarm says replace drum soon. Can the message be
The "replace drum soon" indicater is a warning for you to have a new replacement drum "on-hand". Soon the display will change to "REPLACE DRUM" AT WHICH TIME THE UNIT WILL STOP PRINTING.
When the new drum cartridge is then installed...the REPLACE DRUM indicator will be reset. DO NOT replace the drum before the machine says to.
Jun 04, 2010 | Muratec F320 Plain Paper LED Fax
Brother 8360p says change drum soon
You have to open the front door and then press options, should see Replace Drum? just answer yes.
Sep 09, 2009 | Brother MFC-8440 All-In-One Laser Printer
Drum life low replace soon Error Message
I already answered this at some other place here - but just to make sure the word gets out there:
There is a little special (white) gear on the outer left side of the drumkit - a little bit below where the toner sits. That gear joins with toner assembly - and you can rotate it counterclockwise all the way back. This should reset the drum counter - worked for me!
I hope it also does the trick for you ;-)
Apr 03, 2009 | Panasonic KX-MB781 All-In-One Laser...
CHANGE DRUM SOON
You need to change the drum on your printer. Part # DR-350.
Thanks and please take a moment to rate as fixya.
Nov 06, 2008 | Brother MFC-7220 All-In-One Laser Printer
Drum on Brother MFC-7420
Why does the message "CHANGE DRUM SOON" continue to appear on the LCD display of my Brother machine, after I replaced the drum? Description: This message would continue to appear if the drum counter was not reset when you replaced the drum. To reset the drum counter, follow the instructions listed below. Open the front cover. Press the Options key on the control panel. The display will show "REPLACE DRUM - 1.YES 2.NO". Press 1 to reset the drum count. Close the front cover.
Jul 27, 2007 | Brother MFC 7420 All-In-One Laser Printer
Brother MFC-7820N Laser Printer Logo
722 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
