Standart television sony model kv 32fs300 tv no power the front panel the led flash 5 time
  • Anonymous Feb 16, 2009
    how do you change the video source setting in order to use a dvd player?
How to change TV setting to video mode so I can connect a VCR/DVD combo player.
Posted on Mar 25, 2008
Sony tv model KV-HA21M80 is having problem front stand by L.E.D is blinking 4 times and stopping
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Electro help
Jan 14, 2015 | Sony Televison & Video
Sony KV-24fs100 -Blinking front panel LEDS when attempting power up
count the number of RED blinks..You should have a pause inbetween counts.then count starts from 1..let me know
Dec 26, 2007 | Sony KV-32FS10 32" TV
I have a sony tv model kv-27v42 i have sound but no pictture and stand by light blinks what is the problem
How many times do this standby light blinks at a time of switch on? These blinks are fault indications. From the number of these blinks, you can get an idea about the faulty circuit section inside it. Count it. If you wish to get more details about the blinking codes to Sony TVs, check this link.
Feb 24, 2013 | Televison & Video
SONY TV. STANBY TIMER FLASHING
Hi Frank,
Please let me know if it has a pattern of blinks (separated by a pause) or it will flash an exact number of times. Your unit (KV-34HS420) has a built in self diagnostic software that will indicate the probable caused of the fault by flashing of the LED at the front panel.
Jdvillanueva
Nov 30, 2011 | Sony FD Trinitron WEGA KV-34HS420 34" TV
I have a kv-32ls60u Sony TV. It blinks 5 times
The most common failures are the flyback transformer assembly and sometimes some of its support components, and or there is the possibility of a short in the CRT electron gun. In either case, the power supply is going in to protect mode, and the uPC is sending this flashing error code to the front LED.
I have no idea if the flyback transformer assembly is still available, but I am very sure the CRT is no longer available. In any case you will find the cost of servicing your set to be expensive for its age. The last time I checked, the cost of the CRT exceeded the replacement cost of the set.
Jerry G.
Nov 14, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
3 flashes at my sony tv kv-29fx66k
you probably need new power supply diodes or solder connections, you need a qualified tv repairman to fix this.
Sep 15, 2009 | Sony KV-29FX66 29" TV
Sony Wega KV-XF21M83 21" Color TV red LED flashing two times
mt sony trinitron power light is blinking from green to red twise and then pause for 3 seconds and then blinks again from green to red
Jul 05, 2009 | Sony FD Trinitron WEGA KV-32FQ70 32" TV
Powered on and geting off. No display front led is blinking 4 times.
I HV A PROBLEM WITH SONY-KV-HA21M80 TV. WHEN THE SWITCH ON POWER ON AND GETTING OFF. FRONT LED IS BLINKING 4 TIMES. WHAT COULD BE THE PROBLEM. PLS HELP ME ON THIS.
Apr 29, 2009 | Televison & Video
Standby indicator light on TV flashes - Sony TV
    Please check fisrst that indicator liight (LED) blinks how many times.it could be from 1 to 8 times and the interval would be of three seconds.So, count the led flashes how many times and then tell me i will try my best to find and fix the solution.
Thanks
Nov 17, 2008 | Sony KP-53HS30 53" Rear Projection...
Sony - no power
Well 5 times blinking indicates EEPROM ic getting malfunction. Change this ic tv is working well and good. Note that this ic comes only in blank you have to program it as your tv model.
Aug 04, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Televison & Video Logo
314 people viewed this question
Top Televison & Video Experts
Electro Med Services...
