Question about Emerson MW8102SS 1100 Watts Microwave Oven
Was cleaning inside of microwave and noticed the paint was bubbled and when I cleaned this area, all paint came off and metal was exposed 9about a 2 inch area). Should I use the microwave or will arching occur? What should I do about the metal exposed area? Many thanks, Bonnie
    President:
  • 949 Answers
Hi Bonnie,
Do not use the microwave with the exposed metal surface.
What you can do is pick up some appliance touch up paint, it comes in a small plastic bottle with a brush. It looks similar to fingernail polish. It should be available at an appliance store such as Sears, Lowes, Home Depot etc.
Clean the area good and use sandpaper or steel wool if needed to make sure the area is smooth and clean. Then use the touch up paint to recoat the surface. Let dry before using the microwave oven, usually a couple hours or so.
Posted on May 01, 2010
Testimonial: "Many thanks for such a quick reply and solution. Bonnie"
When I use my microwave, it seems it was spark happening when I use it. I'm afraid to test it again. Please tell me how I should know it's safe to use
2 things cause sparks.... a damaged Waveguide RF window or bare metal inside the cooking area. If you note bare metal you can sand and paint it with an appliance enamel paint. (no lead paint!) Just make sure to only sand the area your painting as any sanding scuffs not painted will hasten a repeat performance of the sparking routine. The RF will bounce off bare metal and cause the sparking. Once PROPERLY painted it no longer sparks.
If it is coming from the area of the Waveguide RF window... Make sure the window is replaced before next use.
Thanks for choosing FixYa,
Kelly
Apr 21, 2011 | Frigidaire Model PLMVZ169GC Microwave Oven
Sparking on right side of the inside of the microwave.
If there is spark please do not switch on unless you have confirmed the fault. It is possible that the Magnetron is leaking and sparking to the ground. As you have mentioned it was stored, it is quite possible that insect can get into the oven and create soft spots. When you switch on these will create a short and make the voltage jump and in the long run damage the magnetron.
So Remove cover after disconnecting , check for dirt/moisture in the cabin, if so wipe clean and dry, check the magnetron and area clean and use an jet air to clean off.
Now switch the microwave power on and use a cup of water to test.
If you notice any sparks shut off as the magnetron or the main HT capacitor can be faulty. Replace with same type. If not check the waveguides within the cabin for food particles that can burn and spark, check for rust that can corrode and spark when the ceramic paint has worn out.
If there is heating without any issues, you can use the microwave safely
Feb 10, 2011 | GE JE1860 Microwave Oven
My oven is starting to arc. Does it need to be cleaned? This happened to my last oven and it was not repairable
if you are seeing the arching inside the unit throught he door you have exposed metal somewhere they use a protective coating on the inside and when paint wears off or has been scratch off and any exposed metal will cause it to arch... they sale touch up paint that can correct problem at most appliance stores and some home depots/ or lowes hardware stores.... good luck to you
Jan 09, 2011 | GE Advantium 120 Convection/Microwave Oven
Put a hamburger in to heat, on a paper plate. The interior began to spark. the plate on the Right hand side appears to have a something black and charred (as if a piece of meat or grease has adhered to it)...
Usually the sparks are from exposed metal. Clean the oven, and the table and anything else you can inside. Then just try nuking a cup of water. That gives it something to work with and it won;t make any sparks itself. Then just see if the sparks are gone. If the paint has come off inside the cavity and exposed some metal you can get sparks but that usually means replacing the microwave. If its caused by an object or buildup then a good cleaning stops it.
Oct 10, 2010 | Whirlpool MT1110SKQ 1100 Watts Microwave...
Paint has bubbled and chipped off in microwave cavity. I have sanded down areas to expose metal. What type of paint do I use to touch-up cavity areas?
Apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
Jun 30, 2010 | GE JE1460 Microwave Oven
Inside white porcelain paint has defects
It should be sanded smooth and clean and dried thoroughly.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
It's normally enamel on sheet metal, not porcelain.
Jan 16, 2009 | Jenn-Air JMV8186AA Microwave Oven
Inside finish is peeling off
No, if the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean and dried thoroughly.
Otherwise, you can have rust and arcing, which can be messy.
Nov 21, 2008 | Microwave Ovens
Paint off inside top of microwave exposing metal. Safe to use?
It would be dangerous to do so. Any exposed metal inside a microwave is source for sparks and is extremely hazardous. I would recommend getting the paint job done up, or even better, buy a newer model.
Nov 15, 2008 | Emerson MW8102SS 1100 Watts Microwave Oven
Mircowave oven the paint is peeling off from the inside top of the microwave
all you can do is clean it out and spray paint it again. there should be no metal exposed inside the oven or arching will occur.
tnx 4 uisng fixya,
drcool
Oct 11, 2008 | Whirlpool Microwave Ovens
Arching inside microwave
un plug it right away.
there are carbon deposit near the wave cover. the arching is coming from the magnetron to any exposed metal inside the unit or any carbon deposit since carbon is already conductive, it is sensing it as a metal.
remove and clean the interior of the microwave. polished and paint all exposed metal that you will find in the interior.
then test again the unit.
tnx 4 using fixya,
drcool
Sep 30, 2008 | Whirlpool GH7145XF Microwave Oven
Emerson MW8102SS 1100 Watts Microwave Oven Logo
262 people viewed this question
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
