Question about Electric Superwinch 12 Volt DC Winch - 8500-Lb. Capacity, Model# 1585200D
Need diagram on how to hook up solenoids and remote switch for a winch
My warn vantage 3000 will not spool in. solenoid clicks but motor does not turn. winch operates on out. use for snowplow, only a month old
If motor runs in one direction motor is not burned out.
Solenoid clicks, solenoid is ok.
Most likely points on solenoid on one side. If you can get to it, then look at the points.
To check , reverse battery terminals then click. the reverse should work and the other not. This will prove the points are bad on one side. .
In that case, you have to take it apart put in new points or get new switch.
Feb 15, 2015 | Vantage 3000 Winch-ATV
2007 Polaris sportsman 700 EFI and am trying to install a superwinch t2000 on it. I have the winch on already but my problem is it had one on that was wrecked and the switch was gone. My question is on the...
This winch should simple straight foward hook up. Your big red & black wires should hook straight to your battery. Red (+) black (-) if there is no fuse on the wires put at least a 20 amp.fuse close to your battery. These are the main power suply. They will go in a.small black box. Also coming out of the black box will be the wires that run to the cable in & out switch.and there should be one heavy ga. Wire going to the winch motor. Make sure the wire is good and clean when you hook it to the winch motor. Do not over tighten the nut . Just give a good snuging down. As for your solenoid box. That should be the little black box that your main power wires go into and controle wires come out of..
Nov 23, 2014 | ATVs
Warn winch troubleshooting
It sounds like your solenoid is not reversing the polarity , which will require a new winch solenoid. Before replacing the solenoid, check your switch. It might have one contact no good. Switch the wires around and try to retract winch by paying out.
Aug 03, 2014 | Warn Industries Warn 64851 Atv Winch Mini...
What is the wiring diagram for winch remote
Ramsey website shows Badger wiring diagram for solenoid hookup etc but not plug. Shouldn't take a good DIY mech or auto electrician too long to work out which wire goes where especially if they loosen the socket it plugs into which should reveal which wires go to where on the solenoid block. Basically that's all they do, there's a supply side, a ground wire and all the hand control does is switch the supply to the solenoid for forward and reverse. From memory there's only 4 wires? Supply to hand control,1 wire to one sol, 1 wire to other sol, 1 ground wire. Supply could be red, ground is usually black, fwd / rev will be 2 other colours. Look at the socket to see match up?
Jul 20, 2014 | 115101: Ramsey Badger Series Winches
Was installing a winch on my 2009 prowler 700 xtx hooked positive cable to selanoid winch did not work,hooked direct to battery,works,rig wont start
Where did you ground the winch motor? You need a separate, heavy duty, switch with a relay to transfer the positive side voltage properly... DO NOT ground to the battery..use a clean, free of paint, place to ground. You may have fried the solenoid..do not connect the positive side to the solenoid. Direct connection to the + battery from the relay is good with a good waterproof fuse in line. Sometimes I have seen the "maint. free" batteries die when used "wrong" and still show 13 volts+.
Apr 08, 2014 | Arctic Cat 2009 Prowler 700 H1 EFI XTX 4x4
Electrical diagram for 8000lb champion winch
Winches are out in the worst weather so before I looked at a wiring diagram I would be checking the condition of all the terminals for clean and tight. Next check the charge rate and condition of the battery driving the winch even having a load test done on that battery to see if all the cells are ok as when the solenoid clicks but no more the results are the same as a bad battery in the car.
Jul 22, 2013 | Champion International Champion 8000lb...
Tmax winch no power
The winch has electric solenoids to control the motor. Most of the time when these things quit working, it is either because the solenoid has failed or the wire connections to the solenoids has come loose.
Mar 23, 2012 | Cars & Trucks
Electric Superwinch 12 Volt DC  Winch - 8500-Lb. Capacity, Model# 1585200D Logo
548 people viewed this question
Top Electric Hammering Experts
John Trevino
Pieter Vleeshouwers
Pieter Vleeshouwers
Dan Webster
Dan Webster
Are you an Electric Hammering Expert? Answer questions, earn points and help others
