Question about Lexmark X7350 All-In-One Printer
I need to have driver re-installed on my computer for the lexmarkX7350 all in one printer
  • Lexmark Master
  • 6,487 Answers
  • 10,322 Answers
1st You download Printer Driver. Lexmark Printer Driver After this install the Printer driver in the system.
Installation of Printer Driver
  • Go to the control panel
  • Click on the System Icon
  • Click on the Hardware Tab
  • Click on the Device Manager then
  • Select the Unknown Device or printer device where yellow Question Marks sign on it.
  • Right click on it and uninstall it.
  • After this go to the top of the device manager and click on scan for hardware changes.
  • Driver installation Wizard start.
  • Brows Your Driver from the Hard Disk and click on next.
  • Driver will be install.
Posted on May 01, 2010
Cannot get my lexmarkx7350 to work on my computer
In this case you need to follow 2 steps:
1: In this case what i would request u to do is:
1. Let the Printer be Connected to the Computer......
2. Click on start then Click on Run or If Windows Vista Type Services.msc Under the Run Window if XP,Under Start Search if Vista.......
3. On that Services Local Window u need to find Print Spooler just Double Click on that and Click on Stop..........
4. Now let that Window still be Open now click on that start Menu Click on Run If XP........
Type in "Spool" and Click Ok...........
5. Double Click on Printers and Delete Each and Every File Inside the Printers Folder...........
6. Now Close this Window and now u will be back to the Print Spooler Window now u can click on Start under the Print Spooler....
Once this is done if you refresh the Devices and Printers Page you would find the exclamation mark gone from the Printer icon now follow the below steps to install the Printer again:
Now go ahead and download the software from the following Link:
http://support.lexmark.com/index?page=productSelection&channel=supportAndDownloads&locale=EN&userlocale=EN_US
Just go to this Link and select ur Product & the operating System.
Download the drivers from here and install the Printer.....
Good Luck!!!!
Apr 04, 2013 | Lexmark X7350 All-In-One Printer
Canon mp258 printer can not fine driver on my computer it only picked up the scander part
Possible causes of failure:
1. Error install driver process
How to install the correct driver canon
- Do not connect the printer to the computer. So, turn on the printer but do not connect the printer to the computer.
- Insert the driver CD and do the install process.
- At the time of the install process, it would appear the request connect the printer to the computer.
- Connect the printer to the computer. The computer will detect the printer, and install process will continue until completed.
- Then, press the START - Printers and Faxes - Right click the Canon MP258 series Printer - select Printing preferences - click Maintenance - Print head alignment - Align print head - OK - etc. Perform print head alignment until completion (approximately 3 times the heat print alignment). Print head alignment, to configure the printer and computer.
- After the print head alignment is completed, the printer is ready to use.
Install the wrong driver canon
- Connect the printer to the computer, then perform install process.
- Solution: disconnect the USB cable from the printer to the computer, then uninstall the drivers and applications that are already installed, then restart the computer.
- Repeat the process to install in the correct way.
2. Drivers don't support the operating system
If you need a Canon MP258 driver download here:
Canon Support and Download
- Follow the link
- Product category = Inkjet Multifunctional Printers
- Product series = PIXMA
- Model = PIXMA MP258
- Document type = Drivers & Software
- Click Find
- Select OS = example : Windows 7
- Download driver printer; MP250 series MP Driver Ver.1.04
- Download driver scanner; MP Navigator EX Ver. 3.04
I hope this information helps. Thank you for using FixYa!
Oct 07, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
Bought a used HP1022n printer. Need to hook up to my computer as a local printer. When trying to instal the driver, the set-up says waiting to connect to the computer. I have the USB cable connected,...
Make sure you don't have the printer connected until after you install the driver. If you had the printer hooked up to the computer before you installed the driver, uninstall and start over. There should be a prompt during the installation process that tells you when to hook up the printer. If that doesn't work, you may have a driver for a different operating system than what you have on your computer. If you need further assistance, please email me the operating system you are using on your computer.
Feb 07, 2011 | HP LaserJet 1022n Printer
Can't install 1210 printer
Insert the software disc for the HP 1210 printer before you plug the printer into the computer with the USB cable. Allow the disc to install the software. You will be prompted to choose a destination for the software.
Plug in the printer USB cable to the computer when the installation program tells you to. This will be after it has installed any drivers that you need to run the printer on the computer.
Complete the installation by running a print test to make sure the printer software is installed correctly. You may remove the disc after the print test is complete. Installation without a Disc Visit the website http://welcome.hp.com/country/us/en/support.html to find the available drivers needed to run the printer on your computer. On this page, select "Download drivers and software." Enter "HP 1210 printer" in the product box and click the arrow to find the drivers. Select your printer from the list provided. This will take you to the next page, on which you will indicate your operating system. Select the "HP Officejet and PSC Full Feature Software and Driver" under "Driver" to begin the download. After the download is complete, you can open the file from the download location and install the software and drivers. Follow the installation software's prompts, after you finish download the drivers you need to double click it,it will give you the option to RUN or DON'T RUN the driver click on RUN and it would continue the installation. Run a test print.
Aug 27, 2010 | HP PSC 1210 All-In-One InkJet Printer
Hoe to install cannon ip 1900 to computer
Go to the Wbsite where your Printers Manufacturer and download and install the drivers for it. Follow the instructions on how to install the drivers. Some Driver rrquire that the Printer NOT be connected and some need to be when installing th edrivers. Hope this helps
Jun 06, 2010 | Dell 924 All-in-One InkJet Printer
Installing my printer
You need to install the printer driver in your computer. You can use the installation cd that came with your printer. The software will also show you how to setup the printer itself. If you don't have the installation cd, there are drivers available for download in the Lexmark website. Just click on this link: http://bit.ly/bLIMIo . Choose the operating system of your computer by clicking on the Microsoft, Macintosh, or Linux/Unix dropdowns found at the bottom of the page. Download the correct driver compatible with your computer's operating system. Install the software. Hope this helps. If you need more assistance, place a comment so I can get back to it. Thanks.
Apr 15, 2010 | Lexmark X2600 InkJet Printer
How do i download my printer on 2 my computer without the disc
Go to the manufactures website and download the drivers (software needed for your hardware to run) for your printer..drivers usually are free.
hope this helps.
Oct 22, 2009 | HP Deskjet F4180 All-in-One InkJet Printer
Won"t print- will copy:
You need to reinstall your printer driver. If you have the installation cd,
1. unplug your printer from the computer,
2. install the driver from the cd,
3. plug your printer back into the computer
4. turn the printer on
5. print your document.
If you do not have the installation cd, try the printer manufacturer's web site for the print driver. Before installing the driver, disconnect the printer from the pc to make sure installation goes smoothly.
Once the driver is installed, when you plug the printer into the computer and power it on, the computer will find it and finish the installation process automatically.
This will not help the problem posted by guest. His problem is totally unrelated.
Dec 06, 2007 | HP DeskJet F380 All-In-One Printer
Printer
go to the manufacturers website and DONLOAD IT. ALL printer manufaturers have the drivers on their websites- just put in the model # and DOWNLOAD it...
Oct 23, 2007 | HP Photosmart 4180 All-in-One Printer
Lexmark X7350 All-In-One Printer Logo
96 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
