I have an RCA Projection TV. The model number is R52WH73. What is the lamp model number? The TV was working fine last night and then my son turned it on this morning and it all of a sudden went out. We tried to turn it on again and the on button lights up for a second then goes out, no picture, no sound.
If the picture is dark you will need to replace the projection lamp. Make sure before replacing that the TV has been turned off for at least an hour as the lamp does get very hot. Just do a google search with the lamp part number of 260962 to find a decent price for it. Be careful as some will be just the bulb and not the complete assembly. I suggest replacing the complete assembly as replacing just the bulb requires gloves and being very careful handling the bulb assembly. There is an access door on the lower right side of the back of the TV where you can get to the lamp. Make sure the TV is unplugged and once you put the new lamp in make sure the door is placed back in correctly otherwise the set will fail to light the lamp. Good luck and I hope this helps : )
Tv projection Lamp might be some how the causes again.Tries unplug,replug tv back like about an hour later.Try it again,should work now.If not,yes the projection lamp,might have been kill by the cold weather.
the ITC222 and ITC222a Convergence option missing repair kit from www.tvrepairworld.com should solve that issue. The kit also contains the CD with instructions.
Sounds like the bulb went out. Go to http://www.purelandsupply.com/RCA-Projection-TV-Lamp.html and order a new bulb for under $200. They are easy to intall; a screwdriver and 10 minutes.
Unfortunately the functions you require are only available via the remote. Also a replacement remote isn't cheap averaging about $85-150 each and most of the time RCA only supplies universal replacements that only cover the basic function of the origional.
