Question about Konica Minolta DiMAGE Z3 Digital Camera
Open z3 body
I have a z3 I fried with 12vdc; I want to fix that someday but for now just want to swap its good battery door onto a working z3. Need a little help getting started opening this puppy without breaking it forever.
maybe you have a link to a manual, etc? even just pointers would be good.
thanks much for whatever insight you can offer.
Tracy Pierce
  • ktpierce Apr 10, 2008
    good info about the shock-loosened connector, but no info re opening the camera.
    but I figured that out and posted how to open on a couple of Battery Door threads.
  • ktpierce Apr 11, 2008
    wonderful, thanks! I had a bit of trouble spotting the photos, maybe there are more in there. btw I found you only need to peel the grip back starting at the tip of right thumb past the single screw near the top. the tricky screw is the one deep in the battery compartment; I posted instr's on a couple of 'battery door' threads.
    anyway, thanks for your reply and your efforts. If you happen to be in the market for Z3 parts, I have everything except for some fried goodies where the power connects. The camera was working ok with 12vdc connected for several minutes, after which the camera died closely followed by the power supply.
    Scholar:
  • 125 Answers
I opened a Z3 to fix a loose connector. I posted some pictures here:
http://forums.steves-digicams.com/forums/view_topic.php?id=573231&forum_id=20
Posted on Apr 10, 2008
  • Michael Ifurung Apr 11, 2008
    I mentioned in the forum that you have to remove all the rubbers in the grip of the camera. Once the rubber is removed, you will see all the screws. The rubber can be put back in place using double adhesive tapes. There is also a photo there showing the circuit board of the camera
Something is draining the battery on our 2002 bmw z3.the battery and alternator checks out good,what is draining the battery??
HELP 2000 Z3 Battery Drain - Bimmerfest - BMW Forums
www.bimmerfest.com > ... > Z Series > E36/7 Z3 (1996-2002)
Feb 18, 2007 - 7 posts - ‎6 authors
HELP 2000 Z3 Battery Drain E36/7 Z3 (1996-2002) ... Something is draining the battery. ... Posts: 55. Mein Auto: 2000 BMW Z3 2.8 Roadster. z3 1.9 battery drain (fuse 31)
Apr 9, 2013
Intermittent car battery drain problem NEED HELP
Jan 29, 2013
Mysterious Battery Drain
Feb 23, 2008
Battery drain....after 2 days sitting dead...
Mar 28, 2006
More results from www.bimmerfest.com
Jan 18, 2016 | 2002 BMW Z3
I have a 2005 Nissan Titan Crew Cab. When I went to open door with key fob it would not open. Used both fobs, no luck. Used key, could not enter truck. Both fob batteries dead? But why won't key work
if key not opening than you have an internal problem which you need to open door and remove door panel go around and enter vehicle from passenger side and open door behind door panel are rods with clips that operate release their are also spring on latch itself but usually the clip breaks or becomes disconnected most auto stores carry a replacement clip
Aug 04, 2015 | 2005 Nissan Titan Crew
Why don't the rear door locks work anymore?
first is fuses are they good.?
the locks on cars are solenoids.
im guessing all ways to open it fail,
keys, key fobs, and internal controls panels?
no childern locks set (some are hidden on cars)
no drivers, panel , master lock, he pushes it and all locks freeze?
this is a general statement.
so you use a thing like a volt meter. $10 at walfart.
we check for 12vdc across the 2 solenoids.
12vdc when active is good.
0v is bad,
if you get 12v then the solenoid is bad or jammed.
if you get 0v, the controls are bad.
its that simple. and electro magnetic solenoid, is easy to test.
with any voltmeter made.
if the controls are bad we use the same method to check them.
12vdc to the switch it must be.
then you push the rear switch and 12vdc leaves this switch.
if not the switch is bad.(input good)
Jul 16, 2015 | 1995 Isuzu Rodeo
I cannot find the ecm / ecu on my 2002 toyota corolla. where is it?
You can do more damage trying to fix it youself if you don't know what is really wrong. I suggest you bring it to a mechanic to check out the damage. It also could be a simple thing like replacing the fuseble Links.
First check that the battery is connected properly - to body ground and + to engine. Make sure battery is fully charged before installing. Good luck
Mar 09, 2012 | 2002 Toyota Corolla
No buttons on the driver door panel work. the interior light doesn't come on when the drivers door is open. All fuses are good. :::::
Two possibilities, broken wire in harness that goes between body and door or a bad driver's door module. You can temporarily swap in the passenger side module to troubleshoot.
Aug 31, 2011 | 2007 Chevrolet TrailBlazer SS
Just replaced my fried multi-switch board for the power windows
original could have fried because the power motor fried or you could have wiring that is melted and electrically open. You need a voltmeter and a schematic of that system and start checking for missing 12vdc.
Apr 24, 2010 | 1994 Pontiac Grand Prix
I locked my wifes Z3 with the key when I washed it and now the passenger door will not open with the remote or the door handle,have I put the system out of sinc
i think so. disconnect battery first, put keys in ignition and turn to the point before firing up would be, refit the battery earth. Should now be able to res ync fob and get door open
Oct 07, 2009 | 1998 BMW Z3 Roadster
Yes i have a 99 bmw z3 coupe will not start been 2 the bmw dealer they replaced the computer but stil couldnt fix the problem, it started with i let car sit up for a month covered , went too go start it...
hi,i have bmw z3 coupe 1999,2,8.i was having same problemes,and it` cost me money by mecanic by geusing(starter,altermateur) like 1200$,belive me the probleme was the battery, get a new battery,and make sure the+ i mean the red line in the battery is good and try to move it to make sure good luck..
Jan 11, 2009 | 2002 BMW Z3
Open the body
I own 2 Z3's, I have opened a virtually brand new but defective Z3 that I bought for $50. I have posted some pictures in a steves digital camera forum :
maybe this will help
Dec 09, 2007 | Konica Minolta DiMAGE Z3 Digital Camera
Konica Minolta DiMAGE Z3 Digital Camera Logo
223 people viewed this question
Top Konica Minolta Cameras Experts
Greg Cann
Greg Cann
Willem.
Willem.
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
