Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
Blown Fuse I have an L120 riding lawn mower, it has Briggs & Stratton Intech 20 HP. The 20 fuse at the battery keeps blowing, when tractor gets hot. There are no loose or burnt wires that I can see. What components does this fuse protect?
  • 7 Answers
SOURCE: is there an oil filter on a Briggs/Stratton riding lawn mower. Model#42A700
Yes there is a spin on oil filter. Depending on the date code when the motor was built there are two possibilities. The easiest way is to measure the length of the filter, If the filter is 2 1/4" long the Part Number is 492932.
If the filter is 3 1/4" long, the Part Number is 491056.
Posted on May 25, 2009
  • 130 Answers
SOURCE: briggs & stratton 190707 wiring diagram
make sure your coil has not move ajust to 010. gap check magent on flywheel.see if strong.if all is ok yes coil is bad
Posted on Jul 22, 2009
SOURCE: I have a john deere L120 riding mower with about
have a john deere zero turn that will not turn all the way over
Posted on Aug 16, 2009
nova2nv
  • 197 Answers
SOURCE: Fuse blows when engage blade
The electro-magnetic coil side of your PTO is shorted out.On the 318 it is very easy to replace,just under front screen.
Posted on Nov 14, 2009
nova2nv
  • 197 Answers
SOURCE: JD L120 riding mower keeps dying on me
Loosen fuel cap 1 turn to see if it will stay running.Theres a tank breather hole/vent in the cap and when it becomes plugged no air can get into fuel tank when fuel is used,can also be a plugged fuel filter.
Posted on May 05, 2010
Electric start on a 700 series briggs & stratton engine power-propelled, electric start doesn't work
All electric start newer mowers have an in line fuse 20 or 30 amp installed in the wiring harness just before the battery. Some have 2 fuses, check for blown fuse.
May 27, 2014 | Garden
Intech briggs and stration started smokeing
check oil level, be careful not to over fill, drain gas, put fresh gas with cap full of fuel injector cleaner to offset eythenoyl gas .
Sep 22, 2013 | Simplicity "Coronet 30"" Briggs And...
Husqvarna Riding Lawn Mower High engine rpm after warm up
pour liter fluid all over the machine then throw a lit match into it
Aug 29, 2012 | Husqvarna Garden
Have and older style Poulan rider mower with a 14.5 hp and 42 inch cut. Replaced Battery, starter selenoid, and ignition switch. Now the 30 amp fuse keeps blowing, how come?
disconnect the starter and turn the ignition to see if the fuse blows, if it does not then the starter is grounded, but more then likely there is a stripped/bare wire grounding out somewhere. Hope this helped Tim
Jun 05, 2011 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Have a Craftsman , with 25 HP Kohler engine & 50in. deck. Just stoped running whlie mowiing. Now won't start, Sounds like battery dead. Checked seat safty switch by jumping eires, did'nt solve problem
My Briggs and Stratton did the same. Look under the hood along the wiring harness for a 20 amp automotive type plug in fuse. Mine was blown, but fuses blow for a reason. One of my headlight connections came loose and shorted to ground. If yours has that fuse look for a short.
Apr 16, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Have a 2005 18.5 hp poulan riding lawn mower, wouldnt start so i replaced battery and solenoid and 20 amp fuses, startyer was checked and fine. Finally got it started and now it won't mow, blows 20 amp...
most likey you have a short . how do you ingage your blades by button or lever. if the button type look for a shorted wire . look for a bad wire some times mice get in to it and chew wires .
Apr 09, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Craftsman 19.5 - keeps flooding getting too much gas
I think that you have a sticking float in the carb. You probably will have to rebuild it. hope this helps
Sep 19, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Mtd riding lawnmower won't run
my mtd lawn mower wont start . when I turn the key there is a buzzing soung where the battery conectors are near the shifter but the starter is hot and getting juice
Sep 28, 2008 | Garden
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
130 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
