Question about Pioneer DEH-P5900IB CD Player
ERROR MESSAGE SOME TIMES DISPLAY SHOWS ERROR 11
  • bulldawgs123 Mar 14, 2009
    when i plud my ipod nano into my radio it says error 11, it still plays the music but i cant use any of the controls on my radio
If this problem occurs with an iPhone unplug the charger and plug it in until display says "Ready" the DEH-P5900 is intended for use with ipods only, not iPhones, its a pain but it only takes a few tries to get it right.
Posted on Oct 27, 2008
  • 149 Answers
Clean your cd read lens with a common cleaner.
Posted on Mar 25, 2008
If I change my display image on yahoo messenger as a pic, then I am able to see it. But, when I change it to an avatar, It is blank. I have latest yahoo msgr 11.
Because , When when u change it in avatar , U Click on Avatar Option, Let me Clear You. On One Time ,Only 1 Option will be show. it is your Pic , or It is your Avatar... So when u select Avatar Option ,then Only Avatar will be Show, But When u Select Display Image , Then Only Your Display Image will Show.... Both Option can't Display on Same Time....
Jul 21, 2011 | Yahoo Messenger
Problem with the Samsung Washing Machines The machine keeps coming up with the message HEI 10x
Here is a list of errors for your machine.
I hope they help you.
SAMSUNG WASHING MACHINES, ERROR FUNCTIONS
When an error occurs, the alarm noise will sound and the error code displayed in the program window. Listed below is a series of error codes you may or may not see for your model of Samsng Washing Machine. The errors are shown as blinking in O.5 second intervals until the error status has cleared. In this case, all the driving devices are turned off until the error is cleared.
1. WATER SUPPLY ERROR - Display shows 4E.
Water Supply Error occurs when water level frequency does not show changes more than 100Hz or water is not supplied up to the preset water level after 10 Minutes or more at the time of initial water supply. The error status can be cleared by turning the POWER switch OFF and back ON.
2. WATER DRAIN ERROR - Display shows 5E.
5E is displayed if the water level frequency detected is 25 KHz or less in the initial phase of the UNB -detecting cycle. The Water Drain error can be cleared by turning POWER SW OFF and back ON.
3. OVER-FLOW ERROR - Display shows oE.
Over-Flow error occurs when the water level is too high. It can be cleared by turning POWER switch OFF. Water is drained prior to POWER switch OFF. The tub is drained for 2 minutes if a frequency of more than 25 KHz is detected.
4. UNBALANCE ERROR - Display shows UE.
Laundry load is unbalanced, manually loosen any tangled laundry.
If only one item of clothing needs washing, such as a bathrobe or jeans, the final spin result might be unsatisfactory and an UE error message will be shown in the display. Unbalance error is cleared by POWER switch OFF and back ON.
5. WATER HEATER ERROR - Display shows HE, HE1.
HE, HE1 is displayed if the water temperature rises by 7 C or more in 1 Min or by 2 C or less 20 Min after heating process has started. The error can be cleared by turning POWER switch OFF.
6. WATER PRESSURE SWITCH ERROR - Display shows 1 E.
* Generated Frequency Signal of WATER LEVEL (WIL) SIW (KHz)
Normal Level = Abnormal W/L Frequency
Low Level = 30.00 Khz
High Level = 15.00 Khz
If the same signal is detected for more than 5 seconds, it is a PRESSURE SWITCH Error. When this error occurs the drain pump will operate for 3 min. and the display will show 1 E indicating a pressure switch error.
7. ABNORMAL WATER TEMPERATURE ERROR- Display shows cE.
e.g. If the water temperature is 50 C or more, during a Delicate or Wool cycle.
At the time of initial water supply, if the water temperature is not appropriate, the display will show cE. This error can be cleared by POWER SWITCH OFF.
8. WATER LEAKAGE ERROR - Display shows 11 E.
Water Leakage error occurs when the water drains naturally, (by leakage) after the washing program starts.
9. THERMISTOR ERROR - Display shows tE
Nov 21, 2010 | Washing Machines
When I put on the D80 Nikon camer with 18-55 lens showing err 10 or 11 in small display in place of frame counter. Otherwise auto focas work, even camera klik but picture not expose then what is the...
Hi nrkelkar, In the D80 manual page 36 it speaks about the buffer. What you see as an error message is r with a number. The number is how many shots the buffer at that moment can handle. It is not an error message.
Jul 07, 2010 | Nikon D80 Digital Camera with 18-135mm...
HP Designjet T1100 error code 08:11
The error code indicates a communications problem between the display and the electronics. Reseat the connectors on the display and the connection to the electronics. If that does not solve the problem, replace parts in this order until the problem is solved: display and display cable, electroncis module, logic board.
Apr 19, 2010 | HP Designjet T1100ps Printer
Whirlpool duet washer shows error message "F 06"
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Remove, reseat and reconnect every connector at least 3 times. Remove the motor control board, spray it down with electronic cleaner along with all connections by disconnecting them, spraying them down. Disconnect and connect a few times to ensure good contact.. It appears that spraying the board and connectors work.
Pl give me a ‘very helpful’ rating for the free help, thanks.
Jan 29, 2010 | Whirlpool Duet 3.8 cu. ft. Front Load...
Roland SPD 20 shows analog test error at power on.
I am having the same issue with a SPD-11 that ahd brought from Japan. Please let me know if you get a resolution for your issue.
Dec 25, 2009 | Yamaha RX-V659 Receiver
My Pioneer Auto CD Player has an Error 11 & 12 message, plays for a few minutes then the error message shows
the laser eye needs cleaning.....i actually just did mine today, just with a normal cleaning cd...if it doesnt work first time, smear a little nail polish remover on the cleaning disc, it works a treat........error 11 and 12 mean the laser cannot read disc properly......starts and stops depending on how much cleaning is required....
Sep 13, 2009 | Pioneer DEH-1600 CD Player
Error 0x80040702 while installing corel draw 11
when i install corel draw 11 it shows a message that
'error number: 0x40080702
description: failed to load dll: MC Setup
setup will now terminate'
please help me in installing this software immediately since i have to do an urgent work on it.
Thanks
Feb 18, 2009 | Adobe Photoshop 7.0 for PC
Error message HO2 shows on vhs display
the player begins to read dvd. display will read 00---READ and it repeats this process a few times and the error then is displayed next.
Jul 10, 2008 | Panasonic Televison & Video
ERROR-11
yeah i knw...it hap wid ma playerz also ....i showed many electricianz...then ma self ...i removed da player ........n throwed in da dustbin...n bought a new one... u can also do da same thing ;) enjoy
Jan 12, 2007 | Pioneer DEH-P7500MP CD Player
Pioneer DEH-P5900IB CD Player Logo
263 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
