Question about Saeco VIA Venezia
ESTRO VAPORE / Thermostats verification ?
Can you please tell me how to check whether my thermostats on my ESTRO VAPORE / BARISTA espresso machine work properly. Yes, I get the steam all right but sometimes I have a suspicion that possibly the water is overheated when I make an espresso, or sometimes when STEAM is not turned on when I want to get some hot water out of the steam wand / pipe at first I get a good amount of steam. So I'd like to verify if my thermostats work properly, how? thanks.
  • robertkoreck May 04, 2010
    There is only one cable going to a thermostat (two thermostats each having one cable going into it). What do you mean disconnect one of the leads, as I said there is only one.
    What value for the resistance should I get ?
    President:
  • 1,618 Answers
Using an ohms meter, disconnect one of the leads and check the reading across the terminals. Make sure power is off when checking resistance.
Posted on May 04, 2010
  • Ernest R
    Ernest R May 06, 2010
    Here is a wiring diagram.
Problem with espresso machine
make sure your coffee grind is not too fine. try a coarser grind. imagine two bucket, one with fine sand and one with gravel. the water will travel faster through the gravel. if this works then slowly make the grind finer until creme returns on your espresso. also try descaling the machine.
Jul 14, 2013 | Estro Barista Athena
I have a starbucks barista athena that has a vapor lock. How do I fix this?
It's easy to break the vaporlock on an Athena.
  1. Power the machine off and let it cool (20-30 minutes is plenty)
  2. Place a mug under the steam wand and open the steam valve all the way. If there's residual pressure, let it release the pressure before proceeding
  3. Power on the machine and wait for a steady stream of water from the steam wand.
  4. Close the steam valve and you should be good to go!
Jan 14, 2011 | Estro Barista Athena
My estro vapore has lost pressure. it will not force water through the filter. how or where can I fix?
Hi Some of the old Estros had Cosmic pumps and that was one of their problems. You can switch out the old Cosmic for a Ulka pump. There would be some modifications but not much.
Feb 06, 2010 | Estro Barista
I need a manual for the Starbucks Athena Barista - how can I get one?
I believe this is the URL you want:
http://www.starbucks.com/ourcoffees/Barista_Final_011305.pdf
Jan 11, 2009 | Estro Barista Athena
ESTRO VAPORE
I just took mine apart, and put it back together. Of the three holes for the screws, there are two smaller and one bigger hole. Align the larger hole on the filter and the base, and the tiny plastic bit and the spring go in to the larger, along with the hollow and larger screw.
Aug 11, 2008 | Estro Barista Athena
Estro Barista Athena Tripping the GFI Circuit
is there a diagram for the coffee holder. i took mine apart to clean it and i am not sure how the spring goes in.
Mar 04, 2008 | Estro Barista Athena
Starbucks Estro Barista Athena
Mine is a red O-ring about 2 1/4" diameter, the same as some automotive brake calipers. A well equipped mechanic or parts store like NAPA should have a supply of O-rings with the proper size, best to take your strainer in to test fit.
Feb 16, 2008 | Estro Barista Athena
Saeco VIA Venezia Logo
530 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
