Question about Amana ALG331RAW Gas Dryer
There is a squealing noise when the dryer runs. The belt seems to work fine, but there is a whistling/squealing noise when the dryer is on
  • Amana Master
  • 8,220 Answers
The drum rides on a pair of plastic glides in the front. They get thin and their bracket begins to rub the drum.
The rollers tend to get a little noisy in time. I use HVAC oil (zoom-oil from ace hardware) to lube them because it is temp resistant, won't disapate, and is non flammable.
Posted on May 01, 2010
2009 elantra SE, whistling sound this morning after a rainy night when i turned the key to start, it had delay for few sec and long whistling noise then started!
What you heard was probaly the drive belt, if it stopped after a few seconds, take a glss of water and pour on belt while running and see if it does it while pouring the water, this also works to tell if you have a bad belt or idler pulleys, if the squealing goes away its a belt if it keeps squealing its the idler. If its an actual whistle, before it starts, who knows......
Dec 19, 2017 | Cars & Trucks
I have a 95 Buick Regal.It makes a noise when running ,but if take the belt off it stops.
it depends what kind of noise, if its a licking noise the pulleys that the belt is being turned by could be bad (belt tensioner pulley ,Idler pulley etc.) if its a squealing sound like a high pitched whistle or like a rubber heal screeching on a tile floor constantly the belt is no good there is fabric on the inside of the belt and when it wears away you will get the chirp or squealing /screeching sound from this. inspection of that belt will tell you look at the grooves if looks like shiny rubber you found it if it doesn't and the fabric is there then a pulley is the problem bad bearing can make the belt slip resulting in the squealing good luck LATER MAN!
Aug 24, 2014 | 1995 Buick Regal
What would cause whistling noise near pully and belt area noise gets louder with acceleration
The engine serpentine belt may be worn or wet. The belt slips, causing a high pitched squealing or whistle noise. The other possiblility is a bearing beginning to go out on one of your belt driven components
Mar 27, 2012 | 1999 Pontiac Montana
Dryer works but makes high pitch noise
This probally the idler pulley, drum rollers, or a bearing hard to say until you take it apart and take a look. There is a good video on checking and replacing these parts at www.appliancehelponline.com/servicemanual.html
Hope this helps
Mar 21, 2010 | Dryers
Squealing noise on start up drying still works
This dryer needs to be taken apart to lubricate any and all moving parts. Idler pulley and rollers, if they are worn out in any way, replace them.
Also, consider a new belt.
Nov 16, 2009 | AEG T58840 Dryer Electric
Hoover Maxi 6 TC50 Tumble Dryer making squealing noise
Have you fixed this problem? I also have a Hoover condenser dryer, only a few months old, and has started to make a squeal/whistle. I'm thinking it might be the front fan needing some WD40, OR too much water vapour around the belt that moves the drum causing the sounds.
If it's the fan, lubricating the shaft and its components should fix the problem, if a wet fan then I'd think maybe fully cleaning the condenser filter, reservoir ect will fix the problem.
The problem seems to go away though "mostly" 15 or so minutes after you start the dryer, so that makes me think ones it gets warm something is expanding to allow more "give" so maybe the belt.
Aug 26, 2009 | Hoover Dryers
Maytag gas dryer squealing
Hi, this is a belt issue. make sure the tension on the belt/motor is sufficient. adjust to specs. if the belt is fine, this will be bad bearings in the roller assembly.
Replace the rollers in this case.
May 21, 2009 | Maytag Dryers
Loud squealing noise from Drum belt looks fine other solutions
If the noise is like a shaking of rattling , like coins being shaked , then it is an object trapped inside the drum.
If instead the noise is a loud grinding , that may get louder on high speed, then it is usually a bad drum bearing.
If dryer is not cooling, check that the noise is not coming from the ventilation fan.
Rollers and belt tensioner can also make noise.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
May 06, 2009 | GE Dryers
Kenmore 400 dryer squealing noise
A little lubricant on the pulleys near the belts will go along way. Its vereasy to access these parts front the back of the machine with a 1/4 hex head screwdriver.
Jan 19, 2009 | Kenmore 63942 Dryer
BWM 318 DRIVE BELT NOISE
bearing in the a-c ,sounds like it needs a new 1 .not a easy fix
Jan 06, 2009 | 1997 BMW 318
Amana ALG331RAW Gas Dryer Logo
524 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you an Amana Dryer Expert? Answer questions, earn points and help others
