Question about GE GSS25SGMBS Side by Side Refrigerator
Ice melting in ice maker
The past couple weeks I have had ice melting in the ice maker and leaking down on the food in the freezer. I noticed that the temp for the freezer flucuates between the recommend 0 degrees and degrees but eventually corrects itself. There is nothing keeping the freezer door from not shutting and its never left open more the a few seconds. anyone ever heard of this???
Thanks
  • gwmowrer May 08, 2010
    Im having same issue. Any have a solution?
  • GE Master
  • 1,606 Answers
Remove the food from the lower shelves , so the inside rear lower freezer panel can be removed ( only 2 or 4 screws ) .
The # 4 thermistor or # 5 thermistor is bad . # 4 tells the main control board , the temp of the coils , if they need defrosted and when they are thru defrosting . This thermistor is the 1 " long , torpedo looking piece , clipped on the top left of the coils , with 2 white wires going to it . Part number WR55X10025 . It would be advisable to also replace the # 5 thermistor , located at the bottom of the freezer , slightly in front of the drain , also with 2 white wires going to it , slid into a housing . This thermistor , is the freezer thermistor , which tells the control board , the freezer temp and when to cycle off / on , due to temp setting .
Posted on May 09, 2010
Ice Melting towards the front of the ice hopper
Check that the fan motor wiring has not been disturbed. If the freezer fan is not working, the fridge will generally start cooling but due to poor air circulation , it will stay colder at the back but will get warmer at the front hence causing the ice to melt. The usual temp for a food compartment is around 4 degrees. The freezer should be -18 degrees celcius.
Nov 25, 2013 | Electrolux EI28BS56IS (278 cu ft) Bottom...
The food in our freezer has been icing up quickly. Then recently noticed the vegatables in the Refrigerator bins were all frozen and ruined. On inspection of the freezer, we noticed a sheet of ice running...
i would say that the cold coil in back of freezer is covered with ice and the problem will get worse . the defrost system need repair . ck the defrost thermo and the defrost control . . the heater is usualy ok . your unit may use what is a p c control called aditive defrost control . but most common is the defrost termo . located on the evap coil in back of freezer plate. mm hope this helps feed back pls .
Jan 20, 2011 | Refrigerators
GE Profile Side by Side PCF25PGTAWW Ice maker started to leak inside several weeks ago. Ice column formed inside back of freezer and on shelves. Removed ice and turned off ice maker. Refer and freezer...
when you removed the back panel if you look on the right side you'll see a round coil next to the fan you have to clean that out at least once a year,if you get a shop vac you can vac off the coil and then set it to blow and blow the coil out to clean it,if your food is staying clod you don't have a problem,when the machine goes into defrost there's a heater in the freezer that melts the ice off of the coil,when it comes on the temp will get warmer for like a half hour or so until it comes out of defrost and starts to cool again.hope this helps
Oct 05, 2017 | GE Refrigerators
Ice on the food
why did you stop the ice maker? was it not working properly? was it over flowing or leaking? do you have a sheet of ice forming in the ice maker tray? if your ice maker was leaking then your water valve is not shutting off completely and could be leaking down on the food. if this is the case - you need to shut the water line off coming into the refrigerator and replace your water valve.
if it is frost that is forming on your food instead of ice then you should check to see if the refrigerator is defrosting properly. if the refrigerator is not defrosting properly you would also first notice that the refrigerator is not cold enough and then later that the food in the freezer eventually thawing.
May 28, 2010 | GE GSS20IEP Side by Side Refrigerator
FROZEN WATER FILTER - UNRELIABLE TEMPERATURES
About the dual water control valve the side that feeds the ice maker could be defective. Fill the ice maker with tap water and let freeze. If it dumps and does not refill the water control valve will need replaced. Here is a link to the water control valve.
WR57X10032 Water Control Valve
As far as the temperature control here is a link to the Temperature Control Here=>
WR55X10095 Temperature Board Encoder Below are some photos. If I can help answer any questions let me know, Sea Breeze appliancepartsse@yahoo.com 6b49f39.jpg053ba1a.jpg
Jul 28, 2009 | GE Profile Arctica Stainless Steel Top...
Ice on back wall but not freezing food and rattle noise. Moved all food to other freezer
This is a fairly common problem with these types of refrigerators. The design is set to defrost every 12 hours and be down for 1 hour to allow ice to melt on coils. More often than not the ice never fully melts and creates a blockage in the coils and in turn slows air flow. You can remove the screws in the back wall of freezer unit and unsnap the ice maker plug to allow access to the coil. Gently tilt the back plate forward. You can then unplug the ref. and help it thaw with a blow drier. If you are not comfortable removing the back plate then you can just unplug the ref. and let it thaw on its own. this may take a while. try to remove as much ice as you can from the back of the freezer wall by hand and prop the door open for a couple of hours to ensure that all the ice melts. The rattling sound you are hearing is the fan blades hitting the ice that is built up around it. As a precaution I recommend that these type of refrigerators get manual defrost simply by unplugging about once a month for about two (2) hours. I hope that this will help you out with the melted ice cream. Good luck.
May 30, 2009 | Kenmore Refrigerators
Water leaking into freezer
It may be the defrost thermostat. This thermostat turns on a heater in the freezer a couple of times a day and melts the ice in the freezer which should go into a tube that leads to a pan underneath the refrigerator, where it sits and evaporates from the heat of the compressor. It could also be the timer which tells the refrigeator to turn off a couple of times a day and tells the defrost thermostat to turn on.
Mar 21, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
GE side by side not working
Defrost cycle not functioning. Could be defrost timer, timer motor, or defrost heater. I detailed this for someone else. see other solutions.
Nov 05, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Refrigerator Freezer warm
the frost on the back wall of the freezer is the clue to the problem. it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer/control board
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Jul 22, 2008 | Refrigerators
GE GSS25SGMBS Side by Side Refrigerator Logo
616 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
