Question about Coleman Powermate Proforce 2500 Generator
Spark plug gap
What should the spark plug gap be for the Powermate 2500? Thanks.
CarlGehrke
  • 169 Answers
SOURCE: powermate 6250 no spark
Hi Mark,
The engines used on the Powermates have a low oil shutdown system that can be troublesome. Try this:
1 - Make sure there is enough oil in the crankcase. The oli level needs to be all the way up to the bottom of the threads in the oil fill hole.
2 - Still no spark? Replace the spark plug with a new one (properly gapped), then spray something like brake cleaner into the carb. Pull the rope and see if you hear any detonations from the engine. If the engine tries to start but won't you need to look at the fuel system, then the ignition.
3 - If you proved there isn't any spark happening, look under the plastic cover where the kill switch is located. You'll find a small metal box with wires coming out of it. Find the wire that goes from the box to the kill switch and disconnect it at the switch. Mark things as needed so that you'll remember where to put them back. Give the rope a gentle pull and see if we have a working ignition, if it does have spark there is something wrong in the low oil shutdown mechanism.
4 - If you've convinced yourself that the low oil shutdown is misbehaving try changing this oil and flushing out the crankcase. Look for any evidence of debris that would have made the oil level float bind. As a final test reconnect the wire we took off the switch and disconnect the one that goes from the module to the oil sensor on the side of the engine, if you don't get a spark with the sonsor disconnected you probably have a bad module.
5 - If we didn't get ignition with the low oil shutdown disconnected from the kill switch, reconnect the wire we took off and then disconnect the (usually black) wire that leads down inside the engine. This is the kill wire for the ignition module. If you get the engine to start with this wore disconnected you may have a shorted kill switch, test it with an ohm meter.
6 - if there still isn't a spark with the kill wire disconnected you may have a bad ignition module. You have to take off the carb, then the blower housing to get to it. Check that the kill wire isn't shorted to the block anywhere, and that the module has the proper gap and orientation before replacing it, The modules say "cyl side" on the side that should face into the engine. A regular business card or a playing card ought to just fit between the magnet on the flywheel and the module, too loose would cause a loss of ignition. You get extra points if you use a feeler guage to set the gap to 0.010 inches.
7 - Ignition modules are available from a bunch of different places, your local Briggs supplier will want to know the model, type, and code numbers located on the side of the valve cover in order to be sure which parts you need,
Rate me if you liked the answer,
Carl
Posted on Dec 01, 2008
  • 211 Answers
SOURCE: Spark Plug location for Powermate Proforce Generator #PM0102500?
Hi
Try to see where is the had of the engine.
best regards savumihai71
Posted on Feb 12, 2009
  • 1114 Answers
SOURCE: fipped over
This is a search and find type of problem. Check all wiring, especially if the generator has a low oil cut off switch. Check the wiring to that. Also, check carburetor linkage and for any springs that may have come off. Check the linkage to the governor on the engine to make sure the linkage is not binding.
Posted on Aug 10, 2009
sal_kh_sab
  • 98 Answers
SOURCE: powermate 6250 wont start
try checking the WKM setting...i dont know what its called in english....but we call it WKM ...on my gen. its a peice of metal (with OHV written on it)...if you don't know how to set it...send me an email at
sal_kh_sab@yahoo.com
Posted on Oct 11, 2009
  • 4 Answers
SOURCE: coleman powermate plus 1750, changed gasoline,
check the carborator see if the butterfly valves or closed, than see if the govener can move back and forth and than go farther and if you move the throttle will the govener butterfly valves move. if that is stuck move it or use some lubricant and there should be 2 linkages, 1 inbetween the throttle and the govener, and 1 inbetween the govener and the carborator.
Posted on Oct 25, 2009
What should i do next to start my Powermate generator 5000.
Fuel evaporated or gone bad. Float in the carburettor stuck? When you try and start it, remove the spark plug and see it its wet. That will tell you if gas is getting through. Not a good idea removing any sensors.
If you are sure there is no spark, then you may need a new ignition coil.
Aug 15, 2015 | Electrical Supplies
What is a sparkplug gap for a powermate 43cc engine
Set spark plug gap to 0.024 - 0.028 in. (0.6 - 0.7mm).
Oct 11, 2014 | Powermate 10 in. 43 cc Gas 2-Cycle...
What size of spark plug for a colman 5500 generator?
any good lawnmower or car plug will work ,just gap @ 35
May 31, 2014 | Coleman Powermate Powermate 5000W...
Ignition mystery! 1994 GMC Suburban 2500 5.7 mtr. No spark to spark plugs. Have spark from coil to distributor. Have changed coil wire, cap, rotor, ignition module, and coil. have 12.5 volts going to...
I guess you could have the ignition analyzed on an oscilloscope. Maybe a tech could see something then.
I always heard the only gap was the spark plug gap-the rotor has no gap-are you sure you got the correct rotor? And does it touch the top distributor cap coil wire tower?
Let us know. It is a mystery worthy of a solution.
Sep 21, 2013 | Chevrolet Suburban 2500 Cars & Trucks
Manual for powermate 54 series model#545020
what is the low pressure ( ) setting for a powermate 54 series
  • model 545020 is . because .i need a new fuel pump and dont have the manual for it thank you
Sep 30, 2012 | Coleman Powermate Powermate 5000W...
What is the Coleman Powermate 5000W Generator spark plug gap
Powermate 435001 w Subaru EX30 spark plug gap is between ..006 - .007 according to manual.
Sep 22, 2012 | Coleman Powermate Subaru 5000W Portable...
What is the spark plug gap for a 2004 GMC Sierra 8.1 liter V8.
.060 (In thousandths of an inch) Caution! Gap is not adjustable on certain plug brands. Torque the plugs with a torque wrench no more that 15 ft lbs.
Sep 22, 2011 | 2004 GMC Sierra 2500
New spark plug, carb cleaned, new gas.....won't start......could it be the coil?
First check the surface between the rotor and the coil and make sure there is no rust. If there is take some fine emery cloth remove the rust from both the rotor and coil. Use a noncondutive cleaner to remove any metal particals. If you remove the coil you can use a standard business card to reset the gap.
After completing this process if it still does not start check the plug and make sure you have a spark in the plug gap. You can test it by removing the plug and reattach the plug wire then lay the plug on the head and try starting the engine. The spark should be a bright blue. If you do not have any spark recheck the plug gap. If the spark is a red color your coil is weak and needs to be replaced.
Nov 24, 2009 | Coleman Powermate Powermate 5000W...
Coleman Powermate Proforce 2500 Generator Logo
50 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Phil Walker
Phil Walker
Tim Garcia
Tim Garcia
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
