Question about Hoover F5866-900 SteamVac Deluxe Wet/Dry Vacuum
5 BRUSHES DO NOT ROTATE WHEN IN CONTACT WITH CARPET
  • 438 Answers
HI There,
When the brushes on a Hoover SteamVac stop spinning, it can be caused by several things. The most frequent problem is that there is debris in the brushes such as pet hair, or lint, that prevents the brushes from spinning. Usually if you remove the brushes and clean them thoroughly, this will fix the problem. This sounds to me like what is the problem on your machine, as you make it seem as if the brushes spin, but only stop spinnning when you put them down on the carpeting.
The brushes on your Hoover are driven by a turbine brush gear assembly, not a belt. Sometimes this part can go bad, but usually when it does, the brushes won't spin at all, even when they are not on carpeting.
Anyways, here a helpful guide that I've done that shows you step by step how you can diagnosis the problem with your brushes:
First, what you'll need to do is take the brush block out of the machine. To do this there are 4 clips on the brush block. You will need to turn the machine upside down, and pull down on the brush block to where it won't pull out any farther. There are 4 clips, 2 on top, and 2 on the rear of the brushes. (See picture I have circled one of the clips in red). Simply press these clips at the same time, and pull the brush block out of the machine.
I'd say that 60% of the time that I see this problem, the main issue is that the brushes just need to be cleaned. If you have pets in the home, a lot of the time the pet hair will just be lodged inside the brushes, will prevent them from spinning. Use a pressurized water hose with spray nozzle is ideal) and spray each brush with water to dislodge any pet hair. You should be able to get these brushes spinning when you spray them. Spray each brush until the brushes are spinning pretty fast. Re-insert the brushes into the machine, and test to see if the cleaning has fixed your problem. If the cleaning still fails to fix the problem, take the brushes back out of the machine.
Now look at the brush stem that goes into the turbine inside the machine. This is the green pole pictured in middle of the brush block. Examine this pole to determine if the top of it has broken off. It should exactly how the picture shows it. Make sure that the plastic has not broken.
If the pole has broken, you will simply need to replace the brush block. If the pole is not damaged, the next thing to try is to turn the machine on while you have the brushes out. Look inside the machine, where the pole goes into the turbine (also important, make sure the switch for the brushes is turned to "Rotating Brush Speed Hi), this female receptacle should spin when the machine is turned on. It is important the try this when the foot pedal is released, and the handle down, and not in the upright position, as there is an internal switch that shuts the brushes off when the machine is in th5 BRUSHES DO NOT ROTATE WHEN IN CONTACT WITH - 232c8b0.jpgosition.
If you notice that the female receptacle where the brush pole is inserted is spinning, then your turbine is fine. If this part is not spinning, then most likely you will need to replace your turbine.
If you find that your turbine needs to be replaced, I have written a step by step guide that shows you each step on how to replace your brush turbine gear. Here's a link to that repair if you need to do it:
http://www.fixya.com/support/r4530769-diagnosis_fix_hoover_steamvacs_when
Hope this helped you, please be sure to rate my repair or leave me feedback if you found this helpful, thanks so much!
Chris Jones
GoVacuum.com
Posted on May 01, 2010
SOURCE: hoover carpet cleaner f7425-900
The brushes will not rotate until the handle is released and the pulled backward, the switch should change from handtools to floor
Posted on Apr 11, 2008
  • 29 Answers
SOURCE: bissell carpet cleaner brushes won't turn
Make sure you have released the handle, as if you wanted to push the machine forward. If the handle is locked upright, the brushes do not spin.
If they still don't spin, you may have a broken belt. Look carefully at the base, on each side. As I face the front of mine, on the right side of the machine, a small belt goes around one brush and a small cog wheel. On the left side, a larger belt goes around both brushes. If either belt is broken, the brushes will not spin. This can happen if you let gunk build up inside the clear plastic side pieces or around or above the brushes. It's very important to constantly be cleaning your Bissell. The belts can be ordered online and replaced. See your owner's manual.
Posted on May 29, 2009
  • 190 Answers
SOURCE: the brushes do not rotate when cleaning carpet. Is
(1) Assure the Brush Control on the hood is NOT set to the OFF position.
(2) Remove the brush assembly by pulling/unlatching it from base on each side.
(3)Does one of the brushes have the drive pin present? It should be about ¼ inch square, and two inches long. It attaches the brushes to the drive mechanism
Posted on Oct 23, 2009
heatman101
  • 43501 Answers
SOURCE: Bissell proheat 2x carpet cleaner
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will give you all the information you need to fix your Bissell Proheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
Posted on Sep 04, 2010
heatman101
  • 43501 Answers
SOURCE: we have a 2x brushes bissell carpet scrubber. Do
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
heatman101
x
Posted on Sep 30, 2010
Brushes don't rotate on proheat2X,
How to Replace the Belt & Brushroll on Bissell ProHeat 2X ...
? 2:11
https://www.youtube.com/watch?v=Jj_43IHz9U4
Dec 28, 2012 - Uploaded by eVacuumBags
How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... How to Replace Bissell Deep Cleaner Pump Belt orBrush Belt - Duration: 1:44. ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
Brushes Will Not Rotate Deep Clean Essential - YouTube
? 0:53
https://www.youtube.com/watch?v=gbEXY5jkWSc
Apr 9, 2015 - Uploaded by BISSELL
If your machine is turned on and in the upright position yourbrushes will not turn. ... How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
bissell pro heat 2x brushes wont spin Questions & Answers ...
www.fixya.com > Forum > Tags
... bissell pro heat pet 2x and my brushes won't turn or operate... check the belt belts ok brushes won't turn/rotate turn dial on bottom front on the water tank to ...
Feb 03, 2016 | Vacuums
Brushes will not move
Try to turn the brushes by hand. If they won't turn remove the brush assembly to see if it is seized, if it is, take it apart and clean the brushes and the gears. If it is nor seized the turbine might be seized.
Dec 26, 2013 | Hoover SteamVac Carpet/Upholstery Deep...
The brushes do not rotate when cleaning carpet. Is in carpet clean mode and will not rotate. I did clear the filter underneath.
Oct 22, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
We have a 2x brushes bissell carpet scrubber. Do
heatman101
x
Aug 29, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
I have a Bissell Pro Heat 2X carpet cleaner and the brushes spin, then stop. I turn it off and when I re-start, the brushes do not spin until I push foreward. The it spins and stops again. Both belts are...
The reason for the brushes to stop when it is above any surface is there is a switch in the handle that stops the brushes so it dont burn your motor up it may have a faulty switch.
Jul 14, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
Hoover Steam VAc carpet Model F7425-900
Take out the brush block, make sure that the shaft is ok, it goes up into the turbine, which is what drives the brushes. If the shaft is ok, then the turbine either needs to be cleaned and lubed, or replaced.
Jun 01, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
My power brushes on my bissel carpet cleaner stopped working. They do not rotate. This is the 2nd power cleaner I have bought and it has the same problem as the first one. What is the problem with the...
The brushes will only work if the handle is released and the ProHeat vacuum is running . There is a micro switch inside the lower handle that switches on the DC carpet brush motor. The DC power for the motor comes from a Bridge Rectifier on the PC Board. petedcurtis@gmail.com
Apr 18, 2008 | Bissell Vacuums
Hoover carpet cleaner f7425-900
the brushes are run on a vacuum the switch may no be opening
Nov 21, 2007 | Hoover F7425-900 SteamVac V2 Widepath...
Hoover F5866-900 SteamVac Deluxe Wet/Dry Vacuum Logo
709 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
