Question about Kenmore 63942 Dryer
110.86427100 - 64271 Kenmore electric dryer .. runs normal with no blockage of air flow and there is heat but maybe not enough ?? Definately not doing the job as it normally did..
  • cyburfer2 May 04, 2010
    Further checks: I've pulled the element to check the coils and observed them to be intact with no "sagging" or weak areas .. I bench tested the thermal switches to function when heated by a heat lamp and although I did not know what temp's they were activating at did note that the inlet was a slightly higher temp than the outlet which seemed reasonable to expect.. As far as drum seals I do appreciate the answer but am at a loss to understand how this could greatly affect the actual drying of the clothes when pumping hot air into the drum with the subsequent evacuation irregardless of how it exits.. This may serve to keep the room the dryer is in from warm air but would still seem to count as air flow for the clothes.. Anyway , thanks again ...
  • Kenmore Master
  • 528 Answers
If you have the unit more then 4-5 years you better get it maintain , b/c there are several seal around the drum that ware off and the heat just leak out from the drum and the unit feal like it less heating well.
Posted on May 02, 2010
My kenmore gas dryer works for 5 minutes then control panel flashs and won't heat th cloths
GOD IS GOOD !!!!
Gas Dryer no heat: or shuts down soon after heating CHECK:
Thermal Fuse
If the air flow in the dryer is restricted, the temperature in the heating chamber can get hot enough to blow the thermal fuse. If the fuse blows, it cuts power to the coils that control the gas valve. The fuse is usually mounted to the exhaust duct just inside the back panel. You can check its continuity with an ohmmeter. If, after disconnecting the fuse, you get any reading other than 0 when you touch the leads of the meter to its terminals, it has blown. There's no way to restore it -- you'll have to install a replacement.
Igniter and Gas Valve Coils
TEST with a multi meter: The igniter is an electric conductor that works like the element in an electric heater, glowing hot enough to ignite gas when you turn on the dryer. This conductor can burn out, and when it does, it may glow, but it won't get hot enough to ignite the gas. At times it may give a reading of continuity yet fail mechanically and not get hot enough to ignite flame though it gets hot and glows and even may show Ohms or continuity ( close circuit) ?
Occasionally, the Gas safety valve and the electric coils that control the gas valve are defective -- they can wear out when the dryer gets old. When this happens, the igniter glows, but gas never enters the heating chamber or does not stay consistant.
Performing a continuity test on either part will help you determine whether or not you need to replace it. But the coils should also be tested for amount of resistance as well as Ohms. As they may be showing ohms yet not putting out enough resistance to keep proper gas pressure flowing. Most coils should show at least 1300 ohms ( GIVE OR TAKE 150 OHMS). Anything significantly less Thus u get an ignition but then it soon goes back out. The flame does not stay lit.
Air Flow and Heat
The motor that drives the tumbler also drives a fan that circulates air through the heating chamber and the tumbler and expels it through the vent. If the air can't circulate, perhaps because of lint blockage, the heating chamber overheats, which prompts the cycling thermostat to turn off the gas. The thermostat resets when the chamber cools, but the chamber heats up quickly and the thermostat again shuts off the gas. The result is that the temperature in the tumbler doesn't stay hot, and your clothes take longer to dry, if they get dry at all.
Warning
There's a big difference between a dryer that doesn't heat up at all and one that just doesn't get hot enough to dry your clothes. In the first instance, the problem is usually a defective part, and things should be back to normal after you replace it. In the second instance, the problem is caused by restricted air flow, and you need to clear the lint filter and vents and take steps to prevent lint build-up. If you don't, you'll use more energy for drying than you need and the dryer may continue to malfunction. Worse, you may have a dryer fire.
Sep 21, 2014 | Kenmore Sears Kenmore Clothes Dryer Flame...
Kenmore advantage gas dryer
Thermal Fuse
Air Flow and Heat
Warning
Aug 10, 2014 | Kenmore Dryers
Why dose my Kenmore elite dryer come on and then goes right back off and say f2
Dryer runs then shuts down wont start up for an hour:
Bad motor windings
IS IT GAS? IF SO Gas Dryer no heat: or shuts down soon after heating CHECK:
Thermal Fuse
Air Flow and Heat
Warning
Jul 21, 2014 | Kenmore Dryers
Kenmore gas dryer series 500 won't heat
Thermal Fuse
Air Flow and Heat
Warning
Jul 04, 2014 | Kenmore Elite HE4 Electric Dryer
How do i fix my kenmore gas dryer model 87673100, will not heat up
Thermal Fuse
Air Flow and Heat
Warning
Jun 14, 2014 | Kenmore 63942 Dryer
I have replaced the thermal cutoff fuse and the high limit thermostate, along with the heating coil, and cleaned all the lint. But the thermal cutoff has failed again, what should I check now?
Sounds like you have some sort of blockage either in the dryer itself or in the exhaust vent.The thermal fuse will blow if the air is not flowing enough.Hope this helps.
Apr 13, 2011 | Kenmore 62602 Electric Dryer
My Kenmore electric dryer runs but no heat.
On the back sides of them dryer is a heating element with a series of safety. The safety would trip if that dryer gets too hot and could cause yo house to burn down. It very well might be a bad heating element but look for air blockages in there that might cause air to overheat from lack of flow. If any sign of air restricting then correct that and hunt down them pesky limitsthemobilian_1718.jpgthemobilian_1719.jpgthemobilian_1720.jpg
Use the zoomspout oil to lube you dryer. Safe for all major appliancesthemobilian_1721.jpg
Get in there and inspect for lint
How to videos and a service manual are HERE
Mar 05, 2011 | Dryers
DRYER TAKES ALONG TIME TO DRY A LOAD OF CLOTHES IT HEATS TO WARM CLOTHES ARE STILL DAMP FOR AT LEAST 2 HOURS NOTHING IS CLOGGED IN THE VENTILATION LINT CATCHER IS CLEAN HELP!!
You may have a blower which is not circulating enough air flow. You can have heat and no blockage but a blower whcih is not moving enough air to distribute the heat and displace the moisture filled heat to the exterior.
Mar 17, 2010 | General Electric DBXR463EG Dryer
Strong odor coming from dryer
Usually when there is a strong heat (burn) smell from the heat element, it is telling you that there is poor air flow. This has nothing to do with the model. It is a blocked or restricted vent line, or an internal blower wheel malfunction or a lint blockage further in the machine that is restricting the air flow. WHEN AIR MOVES CORRECTLY, THE ELEMENT HEATS NORMALLY AND DOES NOT GIVE ANY OVERHEAT ODER.
Oct 11, 2009 | Kenmore 63942 Dryer
I have Kenmore 70 Series electric dryer, that takes forever to dry anything - what could it be?
you need to check to see if you have a strong air flow out from house where it vents out.you have a blockage that wont let heat escape so moisture stays inside dryer.you can run it with the vent off one time to see if clothes dry in proper amount of time.if it doesnt then your blockage is in dryer.you will have to locate blower housing and take it loose to see if blockage is in their.
Mar 11, 2009 | Dryers
Kenmore 63942 Dryer Logo
100 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
