I can't get my Sony laptop to switch to Wireless setup. I've moved the front switch!
  • nufjo Mar 25, 2008
    I installed Wired by the Tiscali Broadband setup CD in Jan.. Now I try it on Wireless but end up being told "unable to locate a wireless network" + Error 103.
After tkw2201's reply I thought again and moved my fax machine away from my laptop and switched it off. I then got a wireless connection!
nufjo
Posted on Mar 29, 2008
    Sergeant:
  • 349 Answers
Hi ya
  • make sure that the laptop has wireless capabilities,
  • it may have just been an option ,
  • do you see a light on or near the switch when you move it.
  • if not go into device manager
  • look in the network adapters for a wi-fi adapter.
  • if its there, and disabled ,enable it ,
  • if not you probably don't have it.
  • you can buy a usb wireless adapter quit cheaply $50AU.
good luck
Terry
Posted on Mar 26, 2008
Sony vaio pcg-61a14L wireless switch
The wireless switch is on the front edge of the computer next to the wireless LED.
See the manual https://docs.sony.com/release/VPCEG1_EH1_EJ1_EL1_Series_EN.pdf
Sep 16, 2012 | Sony VAIO PCG-GRT360ZG Notebook
Cannot connect my acer 5600 wirelessly. WIFI is not lighted on. It says to turn on wireless switch.
The wireless switch is on the front edge of the laptop. With the lid closed, its position on the front edge is just under the right latch of the lid. Turn on by sliding the switch to the right momentarily. You should see Wireless LAN Enabled in large green letters appear briefly at the bottom of the screen. A single screen icon should appear in the desktop's Toolbar at the bottom right of the screen. If the icon doesn't appear, then likely the Wireless Network Connection is disabled. To enable do the following steps....
1. click start button at bottom right of screen
2. click Control Panel
3. in the Control Panel window, click Network Connections
4. right click Wireless Network Connection
5. on the drop-down menu click enable
If there is no Wireless Network Connection in the Control Panel's Network Connection, then the setting up of the Wireless Network Connection was skipped when the laptop was first unpacked and setup. In Control Panel, click on the Wireless Network Setup Wizard to setup the Wireless Network Connection.
Feb 14, 2011 | Acer Aspire 5600 Series 5630-6951 Laptop
Cannot the wireless internet setup
Hi kschmerer,
I understand that you are not able to setup the Wireless Network Connection in your Computer.
To fix this issue, please make sure that the Physical Wireless Switch on the Computer is turned ON and then try connecting the Computer to the Wirelss Network.
You can locate the Physical Wireless Switch on the front side of the Computer. Please move the switch toward right side to turn it ON.
Once the Physical Wireless Switch is turned ON, please try setting up the Wireless Network Connection.
If you are not able to to connect to Wireless Network Connection after switching on the Physical Wireless LAN Switch, try using the Wireless Switch Setting Utility.
To enable the Wireless Network Connection using the Wireless Device Switch Utility, please double-click the Wireless Device Switch icon on the right corner of the Taskbar. Then in the open Wireless Device Switch window, please click to check the box next to Enable 2.4Ghz Wireless LAN.
This should fix the issue.
Please post back if you have any questions or require further assistance.
Thanks for using FixYa.
Dec 07, 2010 | Sony VAIO VGN-AR150G Notebook
Vaio VGN-NS328 funtion key to turn on the wireless internet
Your laptop uses a wireless "Switch" located on the front edge of the laptop on the far left side. There will be an led indicator light to the right of the switch itself. Move the switch to the right to activate the wireless radio. Move the switch to the left to de-activate. Below is the link to the user manual for your laptop. It is in PDF format, so you will need Adobe reader to open it. I am also giving you a picture below of the front edge of your system.<br /> <br /> <br /> <a href="http://www.docs.sony.com/release/VGNNS300_series.pdf">http://www.docs.sony.com/release/VGNNS300_series.pdf</a><br /> <br /> <br /> <br /><img src="http://www.fixya.com/uploads/images/96F2F95.JPG" />
Aug 25, 2010 | Sony VAIO VGN-NS328J/S PC Notebook
I do not know how to turn on the wifi
Please read the below article for detailed steps on fixing your wireless problems:
On the right-hand side near the cd rom drive, there is a switch that moves back and forth. move it towards the back of the computer. that should turn on your wireless capabilities. A wi-fi manager screen should pop and and you should be good to go.
Aug 02, 2010 | Dell Inspiron 1525 Notebook
Switch on the wireless device first?
PLease locate the slider switch at the edge of your laptop. there should be a small slider switch for your wireless. Try to look at the sides or at the front of your keyboard.
Feb 13, 2010 | Lenovo IdeaPad Y430-3231U Notebook
Wireless woun´t work
  • on the system tray near the system time on the lower right portion of the screen you can see there the single-screen pc
    • double cick it and and from there you can turn it off/on
May 01, 2009 | Computers & Internet
Were do you find the switch for the wireless on these laptops
It all depends on the Make / Model. Some are physical (hardware) switches and some are software.
VAIO (General) - Switch on front left
VAIO (General, not further identified) - Button (or slide switch) on the Front Left or Right side
VAIO - VGW-AW125T - Button on Front Left, below keyboard
VAIO - VGN-AX570G - Button on Front Left
VAIO - VGN-B2560 - On top left of Keyboard (light say's wireless when on)
Feb 27, 2009 | Computers & Internet
Locating the Wireless switch on my older Sony Viao Laptop
Hi there, my name is Alex and I am here to help solve your problem
On older models, the wireless switch is the Fun key (the key between the bottom windows logo key and control) with number 2. Press those 2 keys together and it should turn on.
I hope this info helps, please let me know if you experience any problems
Jan 08, 2009 | Sony VAIO PCG-GRT360ZG Notebook
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
