Question about Baumatic 23 in. BDW13 Built-in Dishwasher
Leaking from bottom of door
When on my dishwater leaks from bottom right , about a jug full. have checked seals all look fine. any advice gratefully recieved !
    Problem Solver:
  • 6 Answers
Thereis a float switch in the pan it is usualy a plastic inverted cup like thing there is an electrical switch connected to this usualy by a plunger it is either out of adjustment the float may be gunked up or the switch is just faulty now
Posted on May 01, 2010
My dishwasher is leaking from the bottom of the front door. I can't seem to get to the drain filter. Can that be removed? I think there may be a clog in it.
If the leak is from the bottom of the front door than it is most likely the door seal. If the leak is from beneath the unit and appearing to leak out from the front there are many sources for the water.
Check the seal around the door. It may have some residue that has collected prohibiting the seal. The water in the machine actually sits in a tub. The seal on the door prohibits the water leaking as the spray arm rotates.
To test the door seal start the cycle and stop the unit as soon as the machine begins the spray cycle. Open the door and observe that the tub is full but still below the edge. Dry the seal around the door. Place colored paper towels or cloth beneath the door as close to the door seal as possible, Continue with the cycle and observe for water leaks. Stop allow the unit to sit a few seconds open door and observe the seal. You are looking for the location that it is leaking.
If you can confirm that the seal is leaking you can purchase replacement seals, On some models they can be easily replaced.
In my experience I have not seen a filter in the return line. If there is a blocked return hose the unit would not leak. The tub would remain filled after the cycle. There is an overflow switch that prohibits the tub from overfilling if the tub has not emptied between cycles.
Nov 21, 2015 | Dishwashers
I have LDF6920 dishwater. There is a leak at the bottom of the door possibly from the vent. What to do?
The drain tube from the vent to the bottom right of door may be clogged with food debris. On mine this tube was not placed at the right place so the water was soaking a foam part and the water was dripping outside the bottom pan. The seal of the vent may need to be replaced but the drain tube is supposed to take the excess water.
Dec 15, 2013 | LG LDF6810ST Stainless Steel Built-in...
Oil leak on bottom seal of front jug on my 2000 night train
once a vehicle has been serviced with synthetic oil your not suppose to ever use any other oil. My opinion would be to drain the oil again and change the seal on the jug where it leaks as soon as possible and add synthetic oil. also make sure the mechanic you have your Harley serviced at is aware of this or your bike will get messed up fast. Is this the knight train limited edition that came out with air suspension? If so badass!!!
Dec 02, 2013 | 2000 Harley Davidson FXSTB Night Train
How to stop dishwasher from leaking out of the bottom left corner?
follow the next steps and fix it. God bless you
Dishwasher Not Leveled
This is a very common reason for a leaking dishwasher especially if this was a new installation. The framing in a dishwasher is made up of mostly thin sheet metal, so if it is not sitting flat and level things can get distorted very easily. Watch the video on leveling your dishwasher.
Door Seal
This is not very common in most dishwashers. To check this look for rips and distortion of the seal. If it is ripped or distorted you will need to replace.
Dispenser Seal
This is a more common place for a leak to develop. This is easy to check, remove the front panel and carefully inspect around the seal for water dripping or stainage. If any is found replace the dispenses ed19f28b-0f72-4aa8-a09e-69699854be01.gifgasket.
Water Inlet Valve
Usually it is the connection to the water inlet valve that ends up leaking. Check this connection ( there is usually some sort of adaptor between the valve and supply hose) for leaks. Check the connection on the back of the water inlet valve also. Ocassionaly a water inlet valve will leak around the solenoid in this case replace the water inlet valve.
Drain / Circulating Pump
Some dishwashers have separate drain and circulating pumps Some use one pump to serve both purposes. In either case you will need to check the housings for leaks along with all the connections. Some dishwashers have a seal that leaks down into the pump . This is easy and inexpensive to replace. Follow the tutorial on replacing the pump
Door Latch
The door latch can become loose or misalinged. Check both the striker and the latch. To adjust the latch you will need to remove the front panel and adjust the switch until properly aligned.
Door Hinges
They can cause problems, but this usually only happens from opening a heavy load of dishes on the door. Occassionaly a broken spring or cable occurs. You will need to remove the toe kick and maybe the front panel to inspect.
Jul 06, 2013 | Dishwashers
Water leaking from inside of freezer bottom
Check the defrost of the freezer which you are using right now.For More information please visit Clothes Dryer Element.
Oct 06, 2012 | Hotpoint HSS25GFP Side by Side...
The pan underneath keeps filling up with water and over flowing. I can't find a leak anywhere
Your looking for a water leak and what you have is a air leak. One of the doors are not sealing right. Check the door gaskets for a good seal, clean the edge of any dust. Also pull the fridge out from the wall good remove the rear cover and vacuum out the coil on the bottom. Having a good clean coil helps to evaporate the watter in the pan. If not enough air flow over the coil the pan may stay full longer. Humid air gets pulled into the fridge thru the door seals and during defrost drips into the pan, where the heat from the bottom coil helps to evaporate that water. Other causes are too many door openings, keep that freezer door closed as much as possable in the heat of the day.
Aug 29, 2010 | Kenmore Refrigerators
2002 beetle. Water on floor/passenger side - Vapor barrier faile
open doors and look for drain holes try sliding a wire into holes does it go in easily? if yes they check door seals for torn of loose seal, is there a sunroof/moonroof does this leak? get in car and have someone hose for awhile and look for leaks with a flash light? if door drian holes are blocked remove panel and clean inside. have you been using a/c? if yes is the a/c drain line blocked and condensation is leaking into cabin, also the front windshield has a grate at bottom remove grate and check channel for blocked drains or leaking seal. good luck on this one of these should be your problem.
Oct 30, 2009 | 2000 Volkswagen Beetle
My jugs are leaking too at the bottom. If anybody finds the replacement jugs somewhere please let me know. I have a double smoothie maker model 5787. Thanks! email me at javstarz@hotmail.com
My blender would do that if I didn't screw the jar on firmly enough. Sometimes the action of the blades will even loosen the bottom from the jar during blending, so I always hold the jar handle while the blending is going on. That way if it starts to undo, I can twist it back tight. Before I learned that trick I had smoothies leaking out the bottom - what a mess! Also make sure you put the gasket/seal on in the right order. If it's in the wrong place it won't seal correctly.
Sep 06, 2009 | Blenders
Water is leaking from the bottom in the front left side of side by side maytag. water line is ok not leaking. can't see where it is coming from.
the water for the dispenser (ice/water dispenser in the freezer door) comes from under the frige then up thru the bottom hinge of the freezer door .. it then goes inside the door up to the dispenser .. its a plastic hose and it has to twist near the hinge each time the door is opened .. thats where it usually breaks or develops a pin hole leak .. you can replace the whole hose or just the damaged section if that easier ... since the bottom freezer.hinge where that hose comes up thru, is at the position of your leak then i suspect thats your trouble ... ..also check the condensate pan to make sure its not full .. thats a flat pan under the fridge ..you can usually get acess to it by removing the front kick panel at the bottom of the frige .. if thats full then look for a door seal leak (damaged rubber seal) ... a broken seal or open door will allow moisture to condense inside the machine ..that runs down into the condensate pan where it normally evaporates .. but a problem (like open door) will fill it up to overflow in time ....
Aug 05, 2009 | Maytag Refrigerators
Leaking Microwave door seal (between grated and back of door)
I think that you can get the plastic wet, ie sponge, or lick.
Jun 26, 2009 | Microwave Ovens
Baumatic 23 in. BDW13 Built-in Dishwasher Logo
146 people viewed this question
Top Baumatic Dishwashers Experts
Greg Cann
Greg Cann
Kolbrun...
Are you a Baumatic Dishwasher Expert? Answer questions, earn points and help others
