My unit will not power up. I think it might have been subject to a power surge although it was plugged into a protector.
Easy fix and/or worth fixing?
Thanks
Kev
rambl2@aol.com
Often, power surge when the unit is off will not cause major hardware breakdown. Components often hit are fuses, VDRs (voltage dependent resistors) and/or fusible links/resistors. Simple enough to replace/repair.
Should you venture a DIY, pls be reminded of safety precautions when working with electrical devices. Of course this would also require a bit of familiarity with electronic components and circuitry, use of a DVM and a soldering iron. Access to a service manual or at least a schematic diagram with voltage measurements would make the diagnosis a lot easier. Should you be uncomfortable going this route, perhaps your best bet would then be to seek the services of a qualified professional.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
VCR / DVD combo. VHS side works fine...DVD side recently will not play anything except occasionally...
(More)
VCR / DVD combo. VHS side works fine...DVD side recently will not play anything except occasionally after I use lens cleaning disc (which it picks up and plays fine) THis is also happening with my straight DVD player...
