Question about Frigidaire GLTF2940ES Front Load Washer
Will not spin
I have a Frigidaire washer model # atf6700fs2 and its only 4months old. We use it at the SPCA we do about 13-20 loads a day well now it will not spin i have not taking it apart yet. Just wondering if any one mite know why this thing is not spinning thank you for your time
    New Friend:
I had same problem with mine and its was that the coin trap in the black bellows assembly that connects the pump to the drum was full off coins and hair. because you are at the ASPCA there might be animal hair clogged in it. Recommendayion that rather than put the green clamps back on that you get some regular hose clamps to use.
Posted on Mar 07, 2013
  • 25 Answers
SOURCE: load noise in final spin cycle
turn the tub on the inside if it feels ruff as it turns and makes a noise then most likely you have a bad rear bearing, if it is smooth in turning and no noise then turn to drain or spin possibly something stuck in drain pump. the drain pump will start up first if you hear the noise then the drain pump is accessed from the front lower cover, if its the rear bearing probably not worth fixing about 400.00 in parts and alot of work.
Posted on Feb 16, 2008
aborcass
  • 2651 Answers
SOURCE: frigidaire front load washer no spin
sounds as if theres something stuck in your drain pump, youll need to remove the lower acess panel(2 screws across the bottom front of unit) you'll see teh pump in the rigth hand corner. i would remove as much water as possible before trying to remove the hose to the pump or you will get soaking wetaferer removig the hose youll be able tro see what trapped in oyu pump preventing free draining.. VERY common problem.DISCONNECT POWER THE DRAIN PUMP IS ALWAYS LIVE!!!!!!!!
Posted on Oct 19, 2008
  • 196 Answers
SOURCE: Frigidaire front load washer won't drain or spin
This often is a drain hose that is too low or a drain hose that has been pushed too far down inside the stand pipe....the water is actually siphoning out of the washer. Do not "seal" the drain hose to the house plumbing pipe, this will also allow the water to be siphoned out.
Posted on Nov 12, 2008
  • 5 Answers
SOURCE: My model #gltr1670aso makes loud noises during spin cycle
Usually this is due to either the drum support breaking or the back bearing being bad-neither easy to fix- or worth it. Try lifting the drum up and down, if it moves up and down they are bad. I see this a lot, and the price of repair isn't worth it. Craig
Posted on Aug 02, 2009
SOURCE: Washer does not agitate
im having the same issue, my washer fills ill open the lid when it starts to adjitate i can see it trying to go but it doesnt, when its done with the timer it drain then spins just fine. every 3 to 6 months i noticed i have to replace the thing that makes the washer adjitate, i think is called a adjitater coupling? is there something else wrong with my washer?
Posted on Jan 22, 2010
Our frigidaire 10 year old front-load washer is vibrating way too much. it knocks on fast spin. is something broke?
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems
Washer noise when spinning
heatman101
Feb 12, 2011 | Frigidaire Washing Machines
My Frigidaire Model fails to spin after wash
my washer had same problems, turned out to be door lock switch. around $75.00. Washer 2 years old. Questioning quality also.
Dec 17, 2009 | Frigidaire ATF6000ES Front Load Washer
I have a frigidaire washer, when drum spins it
It is probably the belt.. Replace the belt and that should take care of it..
Have a nice day..
Sep 08, 2009 | Frigidaire CWS3600AS Top Load Washer
Washer not spinning
You're problem is probably the door latch assembly. This is a common problem on Frigidaire front load washers. You can find the part at your local appliance parts suppliers. If the door latch assembly is faulty, the washer will run through all of its normal cycles, but will not spin. Hope this fixes the problem for you.
Jan 01, 2009 | Frigidaire ATF6000ES Front Load Washer
I had the same problem. The service tech came out and replaced the pump, it has been working fine ever since. I couldn't believe the pump went out in only a couple of years.
Jul 06, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire GLTF2940ES Front Load Washer Logo
136 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
