Question about Kenmore Dryers
Will start when start button is depressed, but will cut off as soon as start button is released. Any idea of what the problem may be?
  • Kenmore Master
  • 8,220 Answers
Open the door and depress the door switch and start the motor. Does the drum turn? If not broken belt, if it does turn, bad motor.
Posted on May 01, 2010
KitchenAid KFPM770 motor runs 3 seconds and stops
Determine first if it really is the motor. Does it only cut out if loaded or will it happen without any load? Remove all bowls and blades, plug it in and turn the power on and press the on button. With something plastic press the small white button that is in the middle above the switch panel and normally hidden by the bowl. This is the safety cutout switch avtivated by the bowl, lid and pusher being in position. Does the motor run while the button is depressed or does it again cut out after a short time but with button still depressed. If it doesn't cut out it's likely that wear in the complicated mechanisms in the lid and bowl handle are releasing the cutout switch with small vibrations of motor running. I figure out which one to replace by swapping out one of the 2 parts for a new one as I try to carry both parts in stock for that purpose.
Jul 11, 2016 | KitchenAid Food Processors
Tip
Ford-Lincoln service light 1988-01
LS
2000-01
To reset CHANGE OIL SOON/OIL CHANGE REQUIRED message on the Message Center, press the STATUS control to access the System Check mode. Press the RESET button to display OIL LIFE _% RESET FOR NEW. Press and hold the RESET button until OIL LIFE IS 100% is displayed.
Mark VIII
1993-97
When "CHANGE OIL SOON" or "OIL CHANGE REQUIRED" is displayed on the Message Center, turn the ignition on. Press and hold "OIL CHANGE RESET' or the "RESET" button until "OIL LIFE RESET TO 100%" is displayed on the Message Center.
Continental
1989-94
When "SERVICE" is illuminated, on the Message Center, press the "SYSTEM CHECK" button on the right of the display. Then press the "RESET" button. The "SERVICE" symbol and mileage will start to flash. Next, press the "SYSTEM CHECK" and "RESET" buttons at the same time. The display will show "7,200 miles/11,580 km" and will count down from there as long as the buttons are depressed. Release the buttons at the desired service interval.
Continental
1988
When "SERVICE DUE" is illuminated on the Message Center, press the "CHECK OUT" button located below the display. Then press the "RESET" button. The display should now read "SERVICE DONE?" Next, press the "CHECK OUT" button and "RESET" buttons at the same time. The display will show "7,200 miles/11,580 km" and will count down from there as long as the buttons are depressed. Release the buttons at the desired service interval.
on Dec 07, 2009 | Ford Lincoln Continental Cars & Trucks
When I insert the film, it won't catch, therefore I keep winding until the roll is done (also, the shutter release button won't depress). What does this mean? Is there a way to fix it?
When you say 'vintage', are we talking 35mm or roll film ? If 35mm, looks as if the interlock between shutter release and wind-on spool needs adjusting, but no idea if this is possible.
Aug 31, 2015 | Kodak Vintage Automatic 35 1959-64with...
Coffee button hard to depress
twist the depress button to release for depression
Jan 17, 2014 | DeLonghi Coffee Makers & Espresso Machines
Green light on camera back to the right of the 'delete' button continually flashes on-off about 1 second intervals as soon as battery is inserted as long as CF card is in place. Switching camera ON...
I would start by looking into the memory card slot to see if you have a bent pin. You may need a small light and a magnifying glass to see them.
If the pins are okay, then you can try a reset by holding down the BKT and metering buttons together for 2 seconds. The metering button is on the left, behind the off/on/release.
Thirdly, you can try a firmware update on the camera which can be found here:
NikonTech.com
Jan 07, 2010 | Nikon D70s Digital Camera with 18-200mm...
Dryer will not stay on after pushing start button
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Dec 21, 2009 | Kenmore 63942 Dryer
Nikon D70 Flashing
ERR is i think an error message generated when the camera can not read the cf card ? have you had an problems with corrupted images ?
Sep 24, 2008 | Nikon D70 Body Only Digital Camera
Dryer starts when start button is pressed and held but will not stay running when button is released
there is a holding contact at the motor wiring, check the schematics and trace that holding contact. it should hold the motor running as soon as it starts.
tnx 4 using fixya,
drcool
Sep 14, 2008 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
