Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
GE PSS26NGPA Water dispenser not working - tried replacing filter
roadbird383
  • 40 Answers
SOURCE: Fridge Makes Cubes But No Water
Sounds like a bad water solinoid valve.
Posted on Dec 09, 2007
  • 3 Answers
SOURCE: GE Refrigerators - Water dispenser not working ? I
remove front grill then disconnect the water line at the quick connector. Place line on right side into container and push lever for water. If no water flows the problem is a solenoid on the left side of the back of refrig behind lower panel. If water flows into container the problem is related to freezing of the water line in the freezer door. GE fix is a $500 plus door replacement. Thaw from back of door behind the dispenser with hair dryer (do not get plastic too hot). Cheap fix is to insulate back of door with insulation such as a foam sleeping bag mat or the foil and bubble wrap type of ducy insulation
Posted on Dec 04, 2008
SOURCE: GE GSH22SGRE - water dispenser not working but ice cube maker working fine
I just used the hair dryer and it worked the water is flowing again out of the dispenser
Posted on Dec 19, 2008
SOURCE: GE GSS25SGRE side by side water dispenser...
The same thing happened to me. If you pull the refrigerator out and remove the large silver panel, you will see the water lines on the left. The line going to the ice maker was fine, but the line going to the water dispenser was split. You may have the same issue.
Posted on Feb 05, 2009
  • 19 Answers
SOURCE: water dispenser not working ice maker is fine
The refrigerator has a dual water valve. The water dispenser side of the valve may be defective, but, my experience has shown the problem to be in the water reservoir, located in the bottom of the fresh food section, which, might be frozen or the water line through the freezer door is frozen. Scenario #1: Remove the kick panel, disconnect the water line from the fitting. Have someone depress the water actuator, while, holding a cup to collect any water which may come through the line. If water comes through the tube. The problem is a frozen water line in the door. My best advice for this problem is to remove any frozen goods from the door. Take a piece of cardboard and seal the freezer section of the refrigerator with any kind of tape. Make sure you tape the door switch in the closed position, so, the refrigerator will continue it's normal operation. The frozen goods will remain frozen and the fresh food section will be okay. Leave the freezer door open. You might want to put a towel under the door. The water line will thaw. It might take 15 minutes. It might take 3 hours. Periodically check the water dispenser operation. When the water flows remove the cardboard. Scenario # 2:if, after disconnecting the water line and depressing the water actuator there is not water. The reservoir is frozen. Use a hair dryer to that the reservoir. You will have to remove at least a couple of crisper drawers to perform this action. The cause of a reservoir freeze is too little stuff in the drawers or too low a temp in the crisper drawer area.
Posted on Jun 18, 2009
No dispensing water...GE refrigerator
There may be an interlock switch on the housing where the filter or dummy stopper is inserted. If this interlock is not satisfied, then the water dispenser won't turn on. This would prevent water from spraying all over the inside of the refrigerator if the filter is not seated properly. Check to make sure the filter or plug is inserted properly.
Apr 01, 2014 | GE Refrigerators
GE Profile PSS26SGPA Water Dispenser won't stop dispensing water
water shutoff valve bad or dirty,could be minerals in your water
Nov 23, 2013 | GE Refrigerators
Refridgerator Not Dispensing Water
did the water work before you changed the filter . water when chilled may have frozen in line. . i would before major work adjust tempt of both freezer and frig . if too cold / forzen line .. are you freezing any thing in crispers. this is a good clue.. hope this might help .. mm
Dec 07, 2009 | Kitchen Ranges
Water will not flow out of dispenser
This is common when the water filter needs to be replaced. GE recommends:
Water filter clogged. Replace filter cartridge or remove filter and install plug. Air may be trapped in the line: Press the dispenser arm for at least two minutes.
Dispenser is LOCKED. Press and hold the LOCK CONTROL pad for 3 seconds.
The water line may be turned off or disconnected.
Sep 07, 2009 | GE Refrigerators
See my earlier post of 6-4-09 for the solution to this problem. There is a GE part you can buy the solves the problem. It is part #WR49X10173 -- it's called a "Dispenser Water Tube Heater Kit". The part costs $32-35. GOOD LUCK!!
Apr 12, 2009 | GE GSS25SGPSS Side by Side Refrigerator
Water Dispenser not working
I removed the water filter overnight and then replaced and reset filter setting over the dispenser. I then waited a little while and then tried the dispenser and water began to flow out normally.
Apr 08, 2009 | GE GSS25LGM Side by Side Refrigerator
Water/Ice Dispenser is not working
at the very least replace that water filter.clogged water filter will reduce water pressure to the line.
Feb 24, 2008 | GE Profile PSW26P Stainless Steel Side by...
In operative water dispenser.
I have GE side by side refrigerator - 2004 model GSH25SGRB SS. From the blog I found out the problem is with frozen water line. If I keep the door water would dispense ( thawing). Or if you disconnect at the bottom ( take the grill out and disconnect) the water would dispense.
I placed a call to GE. The service person came. He said GE could fix with a 3 watt heater. He opened the panel. Pasted a heater. It came in a Y shape form. He connected that to the internal wiring. After some time the water started working.
Part $40. Labor for 15 min work = $210. Total = $250.
This is really should be a recall case. No part broken. They had to design a heater to solve this problem. What a rediculus thing is this. I am trying to call GE and ask to refund.
What a cheat GE!!. F them.
Feb 11, 2008 | Refrigerators
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
216 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
