Question about Fiesta Blue Ember Gas Grill
Safety feature is activated, how do we clear it?
    Habit-Forming:
  • 15 Answers
Not sure what you are referring to.
Can you be more specific and describe, please?
Posted on May 02, 2010
  • GeoC May 31, 2010
    From the manual:
    The flow-limiting device may be activated. This safety feature
    restricts the gas flow in the event of a gas leak. The flow-limiting
    device can be activated by improper lighting procedures; if you open
    the LP tank valve rapidly or if more than one burner control knob is in
    an open position when opening the LP tank valve. The
    flow-limiting device can also be activated if there is a gas leak. If
    this is suspect please perform the following:
    • Shut off LP tank valve and turn all burner valves to the OFF position.
    • Perform a leak test to determine if a gas leak has caused the
      flow-limiting device to activate.
    If the leak test is negative perform the following:
    • Disconnect the regulator from the LP tank.
    • Re-connect the regulator to the LP tank.
    • Then carefully follow the lighting procedures.
    When you are done grilling always:
    • Turn all burner control knobs to the OFF position.
    • Turn off the LP tank valve last.
I've got a brand new brother see 400 just got it ready to embroidery for the first time never been used and it says safety device has been activated what is wrong
Um, it is brand new? Take it back and have the vendor check it out or get a replacement. If the safety feature has been activated, it probably is not safe to use in its current condition.
Nov 07, 2016 | Brother Sewing Machines
On 84 porsche 944 do you have to press clutch pedal to start engine even if it's on neutral.
Abel, yes, safety feature just in case it didn't happen to be all the way in neutral.
Feb 20, 2016 | Porsche Cars & Trucks
The safety device continues to activate on my Brother PE 770
it sounds like the machine needs to be serviced to see that wrong
with the machine
Jan 10, 2013 | Brother PE770 Computerized Sewing Machine
Back electric windows don't opern
Has the child safety swith been activated? Look in your manual for child safety features. Most cars can switch the rear windows off to stop the kids climbing out.
Nov 18, 2009 | 2001 Pontiac Montana
Error message "chiLd"
There is a Child Safety lock-out feature on some microwave ovens. This enables the user to lock the keypad to prevent children from playing with the control panel. The model number you have this question posted under has this feature enabled/disabled by pressing and holding the "CLEAR/OFF" button for 3 seconds. However, the display reads "LOC" when the feature is activated. I suspect your model number is different because of the display indication you are receiving. Review your owner/operator manual for how to disable the child lock feature. If you no longer have the owner's manual, or if you still have questions, please post back with your BRAND NAME and MODEL NUMBER, so that I may be able to provide you with better assistance. I hope this helps you.
Nov 17, 2009 | GE JVM1440 Microwave Oven
Problem starting
Usually ont these anti theft systems, there is a valet switch to de-activate the system, look near the fuse box or under dash on the drivers side, it might look like a regular toogle switch.
good luck, Pierre Le Mesurier
Jun 13, 2009 | 1996 Buick Century
Cannot receive calls and dial tone flashing
You have a feature active on your phone it's more than likely a call forward feature which would redirect you calls. The broken dial tone or stutter dial tone is an indicator a feature is active. Contact you system admin for the clear all feature code and the clear all call forwarding codes.
Feb 26, 2009 | Mitel 5220 IP Phone
I need a copy of teh manual for my 2004 Ford Explorer manual.
Wear your safety belt, or simply unplug the harness located at the seatbelt receptacle.
Jan 13, 2009 | 2004 Ford Explorer
Safety feature activated?
If you can return the machine and get your money back. this machine is nothing but TROUBLE and will continue to have problems.
Nov 07, 2007 | Brother SE-270D Computerized Sewing...
Fiesta Blue Ember Gas Grill Logo
97 people viewed this question
Top Fiesta Grilling Experts
paulcarew
Dan Webster
Dan Webster
Lawrence Oravetz
Are you a Fiesta Grilling Expert? Answer questions, earn points and help others
