My all in one inkjet printer A940 will not print Tried everything to no avail They said there is a connection problem, but cannot find where
Uninstall the software for your printer. Go into add/remove programs and remove the programs for the printer that are listed in there.
After that reconnect the printer and reinstall the software. Make sure it goes thru properly with no errors. Then also make sure that this printer is setup as the default. Go into the control panel and into the printers icon and make sure this printer is setup as the default, right click on the printer and choose "set as default".
Once you do all of this, go ahead and try to print a test page. If it doesn't print it then you know at that point the printer itself is bad cause the drivers are installed properly.
