Question about Nokia 6300 Cellular Phone
Screen blank seemed to go partly now just the keys light up. This appears to be after airport scanner. Checked battery and is the right voltage.
  • 3 Answers
Tapon m na phone mo fake yan gago!!!!!!!!!!!!!!!!!!!!!!
Posted on Mar 29, 2008
Flashing background
On a Windows 7 system, right-click on a blank area of the sceen, click on Personalise at bottom of menu and select whatever theme or picture you want as the background. It is slightly different for other windows system, but you should start with right-clicking on a blank part of the screen..
Jan 30, 2012 | Samsung N150 (36725723009) Netbook
We have a Sony VAIO, VGC-LV290J. When plugged into an outlet, the machine's fan just revs. The "VAIO" splash screen does not appear and the screen remains blank. The Bluetooth keyboard does...
It seems that the 'POST' (Power On Self Test) is not starting, and thus is not displaying the "splash" screen. The fans will run at 100% until the POST completes.
But, if the POST does not complete, the fans will "roar".
Check for a defective CPU, or defective RAM, or a defective motherboard.
It probably is *NOT* the CMOS battery -- if that battery is dead, then the "default" settings should allow the computer to start (with the wrong date/time).
Mar 15, 2011 | Computers & Internet
My son was using the ti84 plus calculator.All of a sudden the screen went blank and now it appears to be dead.we tried changing the batteries but it didnt help.we last changed them about two weeks ago
It may not be as bad as you think. The batteries were depleted and the calculator turned itself off due to lack of electric energy.
So you changed the batteries. However after you put new batteries, the screen did not appear to be alive. It may just be too dim.
  1. Make sure batteries are good, and placed correctly (respect the polarity diagram)
  2. Press ON button once ( or if you have the TI SilverLink cable, insert it in the IO port)
  3. Press [2nd] key once
  4. Press the [UPArrow] and hold pressure
  5. The screen should start darkening.
  6. As you keep pressure on the UP arrow, a number should appear on the top right corner of the screen.
  7. Release the UpArrow key when screen contrast is adequate.
  8. If you make it too dark, Reverse the process : [2nd] key and [DownArrow]
Feb 16, 2011 | Texas Instruments TI-84 Plus Calculator
How can i fix my laptop black screen? I can hear it coming on, but no image on the screen.
Instructions Things You'll Need:
  • AC adapter
  1. 1 Check the power source. While you have presumably already attempted to turn your laptop on and off, the problem may lie with your AC power adapter. Is the power-indicator light on the adapter on? If not, your problem may lie here. However, whether or not you have a power indicator light on your adapter, consider unplugging it and plugging it into another outlet. This may turn on your laptop and take care of your blank-screen problem.
  2. 2 Check your brightness settings. While it seems like a simple oversight, the brightness on your laptop may sometimes be turned all the way down. Thus, the screen appears to be black, off or defective, when the problem is simply that the brightness is on its lowest setting. To fix the brightness, check your laptop keyboard. Most laptops have the brightness settings mapped to two keys at the top left of the keyboard, accompanied by a symbol (often a sun). Use these keys to fix your brightness, but keep in mind that some laptops require that you press the Function key at the same time as the Brightness key.
  3. 3 Check the status of your laptop battery itself. There should be a battery indicator on the laptop that is connected to the battery. This indicator is either on the bottom of the laptop or (likely) on the side. If there is no indicator, your battery itself may be the problem, and may require replacing. Keep in mind that older batteries of the nickel-cadmium variety are more likely to decharge over time and forget their initial maximum charge level; this may be a particular issue to users of older laptops.
  4. 4 Find a VGA connector and hook up your laptop to an external monitor if the above steps have not alleviated the blank-screen problem. Turn on the computer and the external monitor. Does the external monitor light up? If so, the blank screen is likely due to a video subset problem/LCD problem in your laptop.
Oct 04, 2010 | Computers & Internet
The sony cybershot screen is bright white with unclear images.
It is problem of lcd screen that will be replaced to get correct picture view.
Local camera repair shop will replace it or if you have expertise then can replace lcd screen by yourself.
Let me know if you need part number of lcd screen for DSC-S930 camera.
Thanks.
May 23, 2010 | Sony Cyber-shot DSC-S730 Digital Camera
Frozen. Yellow light on, Buttons appear to do nothing.
Holding down the Enter key on the keypad for 30 seconds forces the scanner to reset. It is called a forced power down.
May 26, 2009 | Symbol P470-SR1211100FB Handheld
My hp jet scanner 6200c doesnt scan.
I lost the CD of the hp jst scanner 6200c, but i down loaded the program on line. However, when I scan nothing appears on the screen and the scanner makes a lot of noise. The light does go on on the scanner but it doesnt scan i get a blank
Nov 22, 2008 | HP ScanJet 6200C Flatbed Scanner
6310i has blank screen
sir if ur display is ok then just clean the pcb and display connector with pcb cleaner or molycote it will work its been tested
Aug 22, 2008 | Nokia 6310i
Nokia 6300 Cellular Phone Logo
90 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
