Question about Toro Lawn Mower With Toro Power Tools
Toro GTS-5 5.5hp lawnmower
There seems to be no spark coming from the spark plug when I pull out the plug and have my son watch as I pull the starter rope. This happens every year and I'm getting tired of paying the local fix-it shop $150 to start the mower...
  • shawn clarke May 11, 2010
    make sure the spark plug is dry and clean. try a different plug. champion plugs are junk. make sure the gap it at .30 and make sure the shut off isn't shorting out.
5 Suggested Answers
boscia
  • 163 Answers
SOURCE: Toro Mower Recoil Assembly
try turning it clockwise. if it doesnt work it means the inner coil may be broken. its pretty difficult to fix those but if you would to try let me know and i'll talk you through it
Posted on Nov 30, 2008
  • 202 Answers
SOURCE: Toro 22in Lawn mower. Loud gear noise when try to engage drive.
sounds like the transmission engagment lever is broken or cracked. if you can reach the lever see if it has play when the cable is tight. you will need two people one to hold the lever and one to check the lever. easiest way is to invert the mower and have someone hold the lever on the handle. do not try this wioth mower running. the lever should be tight with the transmission lever engaged.another note here the clutch lever will not feel solid but kinda spongy. usually caused by overtightening the cable.
Posted on Jul 07, 2009
mowerman1857
  • 389 Answers
SOURCE: the starter rope broke on my Toro mower and the
I cannot believe that someone suggested grinding off the rivets. If the bottom portion of the rivet falls down and gets caught by the magnet on your flywheel and you try to start it you are going to do some SERIOUS damage.
Here is the instructions DIRECT FROM BRIGGS & STRATTON:
This is a relatively simple process, but you have to be VERY careful when doing this. The spring is long, under some tension and has sharp edges. Anytime you are dealing with the manual rewind starter assembly, there is risk of the spring coming out and possibly injuring yourself or others. If you do not feel comfortable performing this repair, I strongly suggest visiting one of our many authorized dealers in your area and have them do this for you.
You will have to remove the gas tank2.gif to get at the rewind and blower housing. Remove the entire blower housing and rewind assembly and turn it upside down.
NOTE:You do not have to drill out the rivets to get to the back of the rewind assembly. This is only necessary if you are removing the ENTIRE rewind assembly, (metal housing and all) and are separating it from the blower housing.
You'll need a pair of vise grips or a screw driver, some rewind rope, a long thin sharp tip flexible object (the wire from a coat hanger may work) and a lighter handy.
  1. Take the pulley and start to turn it so that the rope becomes loose.
  2. Remove the rope.
  3. Once the pulley is all the way out, with the most tension, either use the screwdriver between the spokes of the pulley, or use the vise grips to hold the pulley in place; be careful not to place too much pressure on the vise grips, the plastic pulley may break!
  4. Make sure that the hole in the pulley lines up with the hole on the rewind assembly.
  5. Using the wire from the coat hanger, push the rope through the hole of the rewind and pulley. Pull the rope through the pulley and tie it off. Now use the lighter to burn the end of the rope to prevent the not from coming off.
  6. Now, remove the screwdriver or vise grips, while holding on to the pulley.
  7. SLOWLY let go of the pulley and the rope should feed back into the pulley as you do this.
Posted on Sep 18, 2009
  • 5 Answers
SOURCE: I have a Toro Personal Pace Recycler mower with a
It's not that hard. I've never done it on my Toro GTS 5.0, but I have done it on a Briggs and it's pretty much the same. Start by removing the 10mm bolts around the perimeter of the engine shroud. DON'T remove the 4 top bolts on the recoil housing. You might have to remove the fuel tank first. Drain it, then loosen the 2 8mm screws and lift it straight up. No need to disconnect the fuel line, just set the tank aside. After removing the 10mm bolts, the shroud should lift right off. Flip it over and you will see the recoil pulley. Remove any leftover cord from the pulley. Now you need to wind the pulley against the spring in the direction it goes when you pull the cord. It might wind 2 or 3 revolutions but don't overdo it. Now you will need some sort of clamp to hold the pulley in place as you line up the slot in the pulley with the opening where the handle goes. Next, feed the new cord through the opening and into the pulley and tie a knot to keep it from slipping out. Carefully release the clamp and let the pulley slowly wind the new cord onto itself. Finally, attach the handle on the other end of the cord and test it. If you can pull the handle and the cord comes out and it retracts normally, re-install the shroud and tank.
Posted on Oct 03, 2010
Changing spark plug on toro GTS lawnmower
How to Change the Spark Plug on your Toro Lawnmower - YouTube
JHope this gives you a heads up on the issue, Jesus loves you, John 3:16-17 (KJV)
Jun 05, 2018 | Toro Garden
Toro gts model 20016. Engine will not stop after hand bar released
adjust the cable to the stop on the end of the bracket behind the carby body
remove the recoil starter and replace the spring
Aug 28, 2016 | Toro Garden
Why does my Toro GTS 6 hp lawnmower start then die?
Have you cleaned out the fuel jet ? if you have a fuel bowl on the bottom of your carb take it off and clean it out anbd look at the bolt that lolds the bowl on I could have little holes in it. This is the fuel jet and will not run if it is plugged.
Jun 22, 2014 | Toro Power Lawn Mower
Lawnmower won't spark
check to make sure your safty switch is not engaging causing no spark other than that your coil would be bad but they hardly ever go bad i think your problem is with the safty switch
Apr 13, 2014 | Toro Lawnmower 20099 Mower Mowers Lawn
TORO Model 20016 6.5 hp GTS Engine pull cord is stuck and won't pull out more than 5 inches
Did you check under the deck for clogs? If its not clogged, DISCONNECT the spark plug wire, and try to turn the blade by hand... Oh yeah, did I mention DISCONNECT the sparkplug wire FIRST! If the blade won't budge, you might have a seized engine. If the blade does move, the problem is in the starter recoil. Rewind the starter string, and check the spring for damage. Good luck!
Sep 26, 2011 | Toro Lawn Mower With Toro Power Tools
Try to pull cord but seems seized on my self propelled lawnmower
Look underneath at your blade - it could be bent and hanging up. If not, remove spark plug and try to pull starter cord. If it won't move then you may have seized the motor and a new mower may be in order.
Hope this helps!!
Nov 16, 2010 | Toro Lawn Mower With Toro Power Tools
I can't pull the pull string on my lawnmower and it seems oil is leaking out of the side. i don't even know where to find the sparkplug! i am handy, but this lawn mower is completely alien to me. i have a...
have you tipped mower over at any stage? oil will be in a/c and cyl/head ...any time you tip mower pull high tension lead off s/plug and tip mower so that spark plug points to the sky...you will need to remove spark plug (suspect it will be full of oil) replace air cleaner....and retop up with correct oil...
Jun 21, 2010 | Toro Lawn Mower With Toro Power Tools
Toro GT5 lawnmower - the pull cord (to start the engine) only comes out about 3 inches - I'm afraid to pull to hard for fear of breaking the line.
First - remove spark plug and squirt 3mls of engine oil in there - replace spark plug and leave overnight.
Try pulling that start handle !
Two things may happen - it snaps or - it turns over.
If it turns over - prime fuel and start in choke setting.
If the cord snaps - undo the pull start block - and take it to a lawnmower spares depot, and buy some more cord. It's quite cheap.
Get the length right so you don't have too much.
Next - the engine is probably seized - so needs freeing up. You may be able to do this with the new cord, Otherwise - take the head off the cylinder and tap the piston down with a wooden drift while turning the crank.
Use a non-setting gasket sealant like hematite red to re-use the old gasket. Lawnmowers are quite resilient.
Jun 29, 2009 | Toro Lawn Mower With Toro Power Tools
Toro Lawn Mower With Toro Power Tools Logo
1,552 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
