Question about Frigidaire 30" Self-Cleaning Freestanding Electric Range - White/Black
Oven will not heat up properly.
Oven will not heat above 250 Appears lower element is not working.How is this element removed?
  • gparazader May 04, 2010
    TheMobilian,
    Took your advice and changed element. No change. Further testing showed it was the clock & control electronics. This priced out to $ 339.00 plus taxes & installation. Not worth it. Have to purchase a new stove. Excuse the delay in replying. Thanks for your help.
  • Frigidaire Master
  • 8,220 Answers
Unplug the machine. Remove the door and racks unscrew the element being careful not to loose the wires or you might have to get the stove out from the wall. Tip: pull the bottom drawer out and you can usually unplug the power without disturbing the stove.
Posted on May 01, 2010
  • Dan Webster
    Dan Webster May 05, 2010
    My friend Bruce can rebuilt your control for a little over a hundred bucks and garantee it longer than a new part
Kenmore plt083-2 won't heat above 200 degrees
Please check that model number again. The one you posted comes up as a refrigerator. Look inside the oven door or the lower drawer.
Feb 03, 2014 | Kenmore 91112 / 91114 / 91117 Electric...
Hotpoint oven won't heat above 250 degrees broiler works fine as well as the stove top
either its the oven sensor rod located at the top of the ovens cavity,or your bake element could be getting a hot spot which is when it gets a discolored spot in the element and can no longer pass sufficient current to heat the oven past 250 degrees
Jul 28, 2012 | Hotpoint Ovens
Our oven was working fine yesterday evening. Now there is no heat coming through. The grill works, as does the light and the fan. The oven has not been banged or damaged, the door seems to be closing...
ISOLATE MAINS BEFORE REMOVING ANY PANEL
Without going into the issue too deeply it sound like you have one of two possible problems.
The first would be a visual inspection, not worked on this type so I will generlise the solution, check element or elements on oven, fan assisted usually have the element in front of the fan, you may have to remove the fan to remove the heating element, checking power, a multimeter would be require and extreme caution as mains would have to be restored to the appliance while panels rear were removed.
Check on meter A/C above 250 volts range if not auto ranging meter, two terminals on heating element should read 230 volt A/C, if no voltage, the problem can be in several areas, check this first. Then send me the details, if mains voltage is detected then it is safe to presume the element is faulty.
AH also before the above look at the element if you have a Black Grey spot or blow out just replace the element. Elements are quite easy to obtain for most ovens a local electrical supplier or whitegood.co.uk
you will need the model and serial number of the appliance.
Hope this is helpful
john
May 19, 2011 | DeLonghi DEBIE24SS Stainless Steel...
The oven is taking forever to heat to 250...The broil works and the stove works...The oven will not heat above 250 on regular bake mode
Sounds like the bottom element is not working, Check it. If it is, there is a high limit, that shuts the oven off it it overheats. When they go bad, they shut down at lower temps. Sounds like that might be your problem
Mar 31, 2010 | Maytag MER5755QAS CleanDesign Electric...
The oven does'nt seem to be able to heat up above 150, the fan is working, the bottem half of the oven does'nt seem to heating up. Is this fixable or do i need a new oven?
Hi.
If the part that is not heating is only the bottom element, and the top element is heating regularly, then you may need to replace the lower element.
Before replacement the element can be tested removing it from the cavity and reading Ohms at the element terminals, with a multimeter set at Rx1. Disconnect power before removing the element.
If both baking and broiling element do not heath above a certain temperature instead, then the part to be replaced is the temperature probe, still located inside the oven cavity.
Regards.
Mar 04, 2010 | Whirlpool RBS275PD Electric Single Oven
My oven still doesnt work after replacing heating element
it could either be a hot spot in the element where it can no longer pass all the current needed for proper operation in heating(look for a discolored spot on it,it may be whitish and dimpled from heat) or secondly,it could be the oven thermocouple located on the inside top of the oven cavity
Feb 22, 2010 | Amana AEW3530DD Electric Single Oven
Lower oven of my wolf built in oven doesn't get hot. Temperature doesn't move above 250 degrees
Could be heating element. Check power to the element with a voltmeter if needed.
Oct 27, 2009 | Kitchen Ranges
I have a frigidaire oven model # PLEB30S8CCB won't get above 290
The coils should glow red when working. If the lower (bake) element does not glow it may be burnt out. Some ovens cycle the bake and broil elements during preheat and that mey be why you are getting some heat.
Aug 27, 2009 | Ovens
Upper oven will not heat above 250 , lower oven works fine
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Jul 29, 2009 | Jenn-Air JJW8230D Electric Double Oven
Older Whirlpool RB170PBX both ovens out
these ovens have a fuse in them called a tco thermal cut out switch if the ovens over heat for a varity of reasons it cuts the power and must be replaced most are on the back of the ovens and are metel disc with two wires on them
Jan 31, 2008 | Whirlpool RBD305PD Electric Double Oven
Frigidaire 30" Self-Cleaning Freestanding Electric Range - White/Black Logo
194 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
