Question about Dell Wireless Keyboard Optical Mouse w0147
Unable to log onto computer keyboard double spacing and double ch
Keyboard started double spacing and double characters. unable to type in correct log in information
  • Dell Master
  • 2,404 Answers
Try a different keyboard, if a different keyboard works properly then your original one is defective. If another keybaord does the same thing then its a setting in the operating system for the keyboard that needs to be changed.
Posted on May 01, 2010
Why dell inspiron doesn't print single quote/double quote chracter ?
Hi Cani
Assuming that the Keyboard keys are all functioning, I would try changing the current Font to something else to see if this changes the fault. You could also try re starting (Reboot) your machine in Safe mode, to see if the fault disappears....
Safe Mode:
http://windows.microsoft.com/en-au/windows/start-computer-safe-mode#start-computer-safe-mode=windows-7
Jul 14, 2014 | Dell Inspiron Computers & Internet
Unable to type characters and numbers
my keyboard xp50 roland when i started the keyboard screen showing user memory damage please help me
Dec 18, 2013 | Samsung Smart TV Wireless Keyboard /...
Error message 1324. The path My Pictures contains an invalid character. Version 2.5.2.36 Can I remove? Can I update so my Quickbooks program can update? Need help please!
There are 3 possible reasons why you are getting this error message:
1. An invalid character in QuickBooks installation path.
2. An incorrect path setting in the Windows registry.
3.Insufficient hard drive space available to install the QuickBooks program.
To fix this problem, please do the following:
  1. Restart your computer, and reinstall QuickBooks.
  2. Confirm that at least 2.5 GB of disk space is available for installing QuickBooks (Quickbooks 2010 requires 1.5GB of disk space):
    1. Double-click the Computer (for Windows 7 or Vista) or My Computer (for Windows XP) icon on your Windows desktop.
    2. Note the amount of free space shown in the window next to the drive letter where QuickBooks is being installed:
      • If the amount of free space is less than 1 GB, free up disk space before installing QuickBooks or install QuickBooks on a different drive.
      • If the amount of free space is greater than 1 GB, proceed with step 2.
  3. Remove invalid characters from the QuickBooks installation path:
    1. Right-click the Windows Start button and select Explore.
    2. Navigate to the path shown in the error:
      • If there are non-alphanumeric characters in the name of any folder in the installation path, right-click the folder and select Rename to remove them, and then reinstall QuickBooks.
      • If there are only alphanumeric characters in the installation path, proceed with step 3.
  4. Create a new user in Windows to rewrite any Windows registry settings that may be causing the error and log in as that user to install QuickBooks.
Note: You must be logged in as a Windows administrator or as a member of the Administrator group to add a new user.
If this solution does not resolve the issue, you can read discussions and post messages and questions relating to your issue on the Intuit QuickBooks Community site for free, or you can contact a technical support agent for additional guidance. Fees may apply.
Nov 30, 2012 | NTI Backup Now EZ
How to use accents when writing in Spanish in a Dell Precision m4500 laptop?
On Windows XP
  1. Log On
  2. Click the Start button
  3. Click on Control Panel
  4. Click Regional and Language Options - a new window will pop up
  5. Click the Languages tab
  6. Click on the Details button
  7. Click the Add button - a new window will pop up
  8. Select United States-International (keyboard layout menu)
  9. Click OK
  10. Click Apply
  11. Read the instructions for "Using the U.S. - International Keyboard" below.
Note: You will now have a keyboard icon on the taskbar (usually on the right side). To switch between keyboard layouts click the keyboard icon on the task bar and choose which layout you want to use. Changing the keyboard layout will only affect the log on profile used. No other users will be affected.
Windows Vista
  1. Start-->Control Panel-->Clock, Language, Region-->Change Keyboards
  2. New Window: Click the Change Keyboards button
  3. New Window: Click the Add button
  4. Select United States-International keyboard
  5. Click OK
  6. From drop down menu (Default Input Language) select United States International
Using the U.S. - International Keyboard If you followed the above directions carefully, your keyboard will now react slightly differently than it did before. First of all, notice that if you strike the single apostrophe (') key, nothing happens. To type the single apostrophe now, you must strike the single apostrophe key and then strike the space bar. When you strike the spacebar, the apostrophe will appear.
The next thing to note is that the quotes (") key behaves the same way as the apostrophe key. You must first strike the quotes key and then strike the space bar in order to create the (") symbol. These two minor inconveniences are more than made up for by the ease with which you can now type the special characters.
To type the special characters, two keystrokes are required. To type the ?, you need only strike the apostrophe key and then the letter a. The other characters are just as easy:
  • ? = ' + a
  • ? = ' + e
  • ? = ' + i
  • ? = ' + o
  • ? = ' + u
  • ? = ~ + n
  • ? = " + u
To type the special punctuation characters, you need to hold down on the Alt key while you strike the appropriate punctuation mark. On some keyboards, only one of the two Alt keys will work for this.
  • ¡ = Alt (hold down) + !
  • ¿ = Alt (hold down) + ?
Using Cryptic Codes If, for some reason, you don't want to change your keyboard, you can always type in the troublesome cryptic codes. Using this arcane system, the following codes apply:
  • ? = Alt + 0225
  • ? = Alt + 0233
  • ? = Alt + 0237
  • ? = Alt + 0243
  • ? = Alt + 0250
  • ? = Alt + 0241
  • ? = Alt + 0252
  • ¡ = Alt + 0161
  • ¿ Alt + 0191
When using this utterly out-dated system, there are two important things to remember. First, when you type in the numbers, some keyboards require that you use the "numeric keypad" located to the side, rather than the numbers along the top. Second, on some keyboards, only one of the two Alt keys will work for this.
May 02, 2011 | Computers & Internet
I have a casio pcr t2000 and just can't figure out how to program our companies logo onto the register receipt
Turn key to Program mode
2 SUBTOTAL 132 SUBTOTAL Now type the characters for the first line of the receipt using the programming layout on your keyboard (see entering characters section in the manual) 00 (double zero button) CASH (maybe labelled CA/AT) 232 SUBTOTAL Now type characters for second line 00 CASH 332 SUBTOTAL Now type characters for third line 00 CASH 432 SUBTOTAL Now type characters for fourth line 00 CASH SUBTOTAL
NOTE: You might have to do 2 receipt prints in REG mode to see the changes
If anyone needs a Casio PCR-T2000 manual, c-tech has one here: http://the-checkout-tech.com/manuals/cashregisters/Casio_PCR-T2000_users_and_programming_manual.html
Oct 17, 2010 | Casio Parts Cash Register PC Desktop
When typing question marks & puctuation...French comes up
In Control Panel, double click "Regional and Language Options". Click the Languages Tab and then the Details button. Make sure that English is selected as the Default Input Language. If French is listed as an available keyboard layout and you don't need it there, you can remove it to make sure it doesn't switch itself again.
I hope this helps. Good Luck.
Jun 24, 2009 | Dell Spacesaver USB Keyboard J4624 SK-8115...
I cannot sign onto my computer.
If you note which keys type double characters you can use the backspace key to backup one character as a work around, but it sounds like you may need to replace it. If it is wireless, try new batteries first and also try another keyboard if you can borrow one.
Feb 14, 2009 | Averatec 7171000100 Keyboard
Olympia supertype 330 types wrong characters
check the pitch setting to make sure that it matches the printwheel. It is the switch that is marked 10, 12, 15, PS. PS is proportional spacing and will only type correctly with a PS wheel. The number settings are for PICA ELITE and MICRO.. 10, 12 and 15. The numbers are characters per inch...so the larger the number, the smaller the character.. it is the opposite of FONT SIZE.
Feb 05, 2009 | Olympia Supertype 330 Typewriter
Dell Wireless Keyboard Optical Mouse w0147 Logo
mukhtar21 shaikh
mukhtar21 shaikh
