I am trying to use a Samsung LCD TV Model LE 19R8 as a second PC monitor for my Sony Vaio VGN-Z11WN. With an HP pavilion f1723 monitor connected to the Sony laptop?s VGA port the system works perfectly. When I try to connect to the Samsung TV in place of the HP monitor the Samsung doesn?t appear to ?see? the PC, as the PC connection in the system settings screen of the TV is greyed out. The only difference I can see is that the VGA cable on the HP has 15 pins and the cable I?m using for the Samsung has 14 pins the missing pin is in the middle row, second from the right. Could this be why the Samsung doesn?t ?see? the PC? What is the function of the missing pin? I have used the 14 pin cable with other PCs and monitors successfully. Before I buy a 15 pin male to male cable I would like to know if you think this will solve the problem>
  • 2 more comments
  • guthriegus May 01, 2010
    Many thanks Halbrook, I'll purchase a 15 pin VGA cable right away, in the meantime I have another question as follows: -
    Normal
    0
    MicrosoftInternetExplorer4
    /* Style Definitions */
    table.MsoNormalTable
    {mso-style-name:"Table Normal";
    mso-tstyle-rowband-size:0;
    mso-tstyle-colband-size:0;
    mso-style-noshow:yes;
    mso-style-parent:"";
    mso-padding-alt:0cm 5.4pt 0cm 5.4pt;
    mso-para-margin:0cm;
    mso-para-margin-bottom:.0001pt;
    mso-pagination:widow-orphan;
    font-size:10.0pt;
    font-family:"Times New Roman";}
    Further to the question about connecting a Sony Vaio to a
    Samsung LCD TV I posted a few minutes ago, I have a further question.
    Rather than use the VGA ports on the laptop and TV, could I
    use the HDMI ports? If that is possible what settings must I use on the laptop
    to send the screen signal to the TV via the HDMI port and cable?
    Normal
    0
    font-size:10.0pt;
    I don’t know how the pins are numbered, but the top and
    bottom rows each have 5 pins, the middle row has 3 pins, then the missing pin,
    and then one pin, making 4 pins in all. Counting one way it seems to be pin 9
    that is missing, from the other it could be pin 7
    Hello again Halbrook, I have an HDMI cable and will try that solution before buying a new VGA 15 pin cable. will let you know how I get on. The link you provided is very helpful. Thank you
    Very helpful, thank you. I haven't tried it yet as I need to make some purchases in order to try it out, but will come back to you if it doesn't solve the problem.
  • 560 Answers
This is the PIN assignment of VGA cable:
Pin Signal
1 Red Video
2 Green Video
3 Blue Video
4 Monitor ID - Bit 2
5 Ground
6 Red Ground
7 Green Ground
8 Blue Ground
9 [KEY]
10 Sync Ground
11 Monitor ID - Bit 1
12 Monitor ID - Bit 0
13 Horizontal Sync
14 Vertical Sync
15 N/C (Reserved)
I believed you are missing PIN 8 on your 14pin cable. Without Pin 8, your LCD-TV will not work because the Blue Video color (Pin 3) will not work without the ground (Pin 8). I am very positive that a 15 pin VGA cable will solve your problem.
Posted on May 01, 2010
Sony VAIO VGN-NS230E vga
Look and see if it appears as a monitor in your display settings, if it doesn't, then another good first step would be to update your video card drivers (go to this page and select "Video" then download " Intel Graphics Driver"). If none of this fixes it try the VGA cable with a different PC and see if it works.
Oct 20, 2012 | Sony VAIO VGN-NS230E/W Notebook
I want to connect my Sony Vaio VGN-NR120E to my TV Samsung. But I have no idea how to do that. Could you give me advice ...
Your Sony vaio does not have any TV-out port to output the display on any analog TV. You can use your VGA (by using VGA cable) port to output your laptop on LCD / Plasma / LED TV (with a VGA port also)). If you still want to project to analog TV via the VGA port, you need to find a VGA to RGB adaptor. But bare in mind, it's hard to find one.
VGA port is like the port on computer monitor. RBG consist of three colored port.
Good luck ;)
Mar 09, 2011 | Sony VAIO VGN-NR120E/S Notebook
Como activo la camara de mi sony vaio VGN-CS290T
click al manual de su computadora aqui.. y baya a la pagina 41. alli le explicara como hacerlo.
http://www.docs.sony.com/release/VGNCS200series_ES.pdf
espero esto le ayude
Feb 04, 2011 | Sony VAIO vGN-NS235J/L Notebook PC
I have been connecting my Sony Vaio VGN-FE21M for several months with the LG LCD monitor to watch TV while online. Then yesterday all of the sudden the laptop shows blank screen, but the LG monitor is...
I need to know what operating system you're using (like windows vista). However, it seems like the control has moved to the LG screen, and not laptop. You can set several options when connecting a monitor to a laptop - both screens are available, one screen is off and the other screen is off.
Please post your operating system so that I guide you how to change these settings.
Nov 23, 2010 | Sony VAIO VGN-CR240E/B Notebook
Screen goes dark after approx 2 seconds?
h10032.www1.hp.com/ctg/Manual/c00264775.pdf
http://www.fileden.com/files/2007/4/4/956157/HP-vf17-FP17-f1723-FP7317.pdf
Above is your service manual, above that is a user manual. With the service manual, you can troubleshoot and hopefully repair your unit. The service manual,is what engineers used to troubleshoot and repair these units.
May 15, 2010 | HP Pavilion F1703 17" LCD Monitor
Not able to connect sony vaio to projector or LCD TV
The monitor switch on a Sony is usually done by holding down the Fn key and tapping one of the F keys that has the icon of a monitor on it, sometimes you have to tap that key a couple of time for the switch to activate.
Regards.
Aug 01, 2009 | Sony VAIO VGN-FE880E/H Notebook
Hi i am trying to find somwere that sells spare parts for my hp pavilion f1723 monitor as my screen has cracked and the ink or wotever it is is coming out
go to ebay. they are cheap there. put in search hp pavilion f1723 lcd and you are in business. they should run you about 80-120 dollars. most places that sell them on there have a generic tutorial in how to replace them
Good Luck!
Ruben
Jul 23, 2009 | Computers & Internet
How do I connect my sony vaio vgn-fs920 to a tv?
As far as I know I need:
1) to purchase that VGA - S-Video Adapter ?
2) to purchase S-Video Cable itself ?
3) to purchase something like audio AV cables as well ?
Does anybody know where I can buy VGA - S-Video Cable (without Adapters) if it's possible and DO I NEED TO BUY AUDIO CABLE IF I'M GOING TO CONNECT THRU S-VIDEO?
May 14, 2009 | Sony VAIO VGN-FS920 Notebook
Sony Vaio VGN-NR120E cracked lcd screen.
You won't be able to see video if your LCD screen is cracked.
Connect a monitor to the VGA port , the hold the Fn key and hit F7.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Mar 07, 2009 | Sony VAIO VGN-NR120E/S Notebook
Connecting a sony Vaio vgn-fe570g laptop to a Samsung Monitor
There is an issue with the vga port on 2006 - 2007 sony vaio laptops. It doesn't push enough power to samsung lcds. There are all sorts of complicated solutions suggested by all sorts of people. Don't waste your time. Get yourself a connection cable with gold contacts and you'll be straight. It costs approx. $33.99. I got this one and it works fine (and I have a weak-*** TZ):
http://www.circuitcity.com/ssm/Nexxtech-VGA-SVGA-Monitor-Cable-6-N6VGASVGA/sem/rpsm/oid/192558/catOid/0/rpem/ccd/productDetail.do
May 22, 2008 | Sony VAIO VGN-FE870E/H Notebook
Computers & Internet Logo
153 people viewed this question
David Payne
David Payne
